Nous sommes actuellement le 17 Août 2026, 15:17
Seymour Seymour Goes To Hollywood
 Sujet du message : Seymour Seymour Goes To Hollywood
Message Publié : 19 Jan 2009, 19:01
carte : https://cpcrulez.fr/GamesSF_hlp/Seymour_ ... wood_2.png
 Sujet du message : Re: Seymour Seymour Goes To Hollywood 2
Message Publié : 03 Jan 2010, 15:49
Seymour goes to Hollywood (AA101)
Another request (or lips that we simply cannot Ignore is for that brilliant find-em-up featuring that Infamous tub of lard, Seymour Goes To Hollywood. Perhaps now all the baying thousands can stop bleating (or Indeed baying) and get down to finishing this mastorplece. Once again, David Hayes of Neilston in Glasgow comes up with the goods. Congrats, David. It's not often you get your name in Cheat Mode twice with the same solution.
1 Get the movie specs from the limo, then go right. Once part the security guard you drop them again.
2 Go right until you reach the first studio then left twice. Get the dictionary and give it to Pippa (the receptionist!.
3 Keep going right until you reach the first tree hut. Enter and get the jackot. Go to the top right hut. entor and get the spanner. Make your way back to the first studio and leave the Jacket outside.
4 Go to the lift and drop the spanner. Go to the first floor (press KJ and get the pom-pom. Go up another floor and work around to the deflated balloon. Pick it up and return to the lift.
5 Go to the top floor then go right. Get the studio key. Go back to the first studio (M to make the lift go down). Drop the key at the door. Leave the balloon and get the jacket.
6 Enter the Grease set. give jacket to the biker and get the pump. Go right, enter the Malt Shop and give the pompom to Slndy. Take the key and the parrot food.
7 Leave the set. get the balloon, go right into the second hut and drop the balloon and pump. Go to the top-right hut, drop the parrot snack beside the door. When the parrot leaves collect it. Exit the hut, go to the top-left platform and repeat. Go left and repeat until the parrot enters the hut. Get the key and the dagger.
8 Go to the first studio, drop the dagger, get the key. Go left five times and open the door. Go to the Grease set, then left, right and Dpen the door.
9 Go to second tree hut. get the balloon and the pump and drop on the platform. Ferry all four items across from the island.
10 Get the key. go up and left to the hut and get the key. Go to the Grease set. Go left, open the door and work through the set, collecting the key. Go left, open the door. Left twice again, open the door and return to the Grease set.
11 Get the gloves and go into the Sherlock Bones sot. Make sure the gloves are last on the Inventory, go right, get one coin and the cards, then the arrest warrant from Rick Bracy. Go to the Western set enter saloon, talk to Billy the Kid. then give the evidence to Rick Bracy.
12 Go to the Western set. climb the stairs in the saloon, go left and enter the green door. Talk to Sal and give the letter to Rick. Get the lollipop and coin from the Sherlock Bones set, go to the limo, then left and into Greasy Lil's. Give her the coin, than take a buttie and the key and go to the Grease set. dropping the lollipop off at the lime
13 Pop along to the Western set, and rop the buttle at the locked door to the left and then open the door to the right.
14 Get the bad from the tree hut and go to the Frankenstein set. Give Tow»er the ball.
15 Go to til's, collect the foot and men the hand from the llmo. Go to the Frankenstein set and get the other foot. Work through to below the table and drop everything.
16 Get key and open the last door (where the buttie is). Go to the Rick Bracy set, take the body and gloves and get a coin from the Sherlock Bones
set. Go to the Frankonstein sot. Leave the gloves and coin on the first screen. Put the body on the table.
17 Repeat for the hand (third floor lift), head (first floor lift), arms (from the island and the Western), and legs (second hut and the Western set).
18 Get coin and gloves Put the coin into the machine, then, wearing the gloves flick the bottom and top switches- Flick the top again, then the bottom. Go right, get the brain and drop it outside the Grease set. Get the dagger, mallet and buttie. then enter the King Kong set.
19 Make your way to the top. give King Kong the huttio and use the dagger to cut the girl free. Drop the mallet, get the medal and collect the brain. Then get the clockwork heart from the Flash sot.
20 Go to the Wizard of Oz set and give all three to Dorothy. Take the towel.
21 Get the lift to the third floor and collect the potion. Go to the Flash set.
22 Place the towel in the foloporter. operate the computer, then repeal to teleport yourseff.
23 Go right and get the lift. Go left, past Ming and get the detonator. Make sure that you are still carrying the potion. Pass Ming, drop the potion then teleport back.
24 Got the flowers from the island and the explosives from the Rick Bracy set.
25 Give the flowers to Pippa, take the key and get the lift to the top floor.
26 Go left and open the door. Drop the explosives in Iron! of the safe, drop the detonator on the settee. Enter room and collect the script
Once finished you have to find ail the Oscars. Good old David comes up with the goods again with all these Oscar-winning locations:
1 In the props department, hidden underneath a barrel.
2 At the lift underneath the Yukka plant
3 In the hut where you found the ball, underneath the window pane.
4 To the right of this hut. on the platform, under the leaves.
5 Top-right tree hut, underneath a barrel.
6 In the Wizard of Oz set - go to the top of the castle, fall Instead of Jumping up to the flying monkey and land on the platform Its under the leaves.
7 On the Rick Bracy set in a lock-up under a packing case.
8 First screen in the Sherlock Bones sot halfway up a tree.
9 In Sal's Saloon - jump on to the piano, then across to the last chandelier, then try to pick it up.
10 Under the packing case in the corridor of Sal's Saloon.
11 Under the bedknob in Sal's bedroom.
12 In the first room in the Frankenstein set. hidden under a railing.
13 In the Secret Lab. Frankenstein set.
14 In the Flash set - on transporting, Jump up and right to Ming's armoury.
15 In the space base under the first air vent.
16 Jump across the third chandelier in Sal's saloon, hold down enter and it usually appears - if not keep trying.
