Nous sommes actuellement le 15 Août 2026, 13:33
HERBERT'S DUMMY RUN
 Sujet du message : HERBERT'S DUMMY RUN
Message Publié : 02 Fév 2009, 17:14
POKES (tape+disk versions)
POKE &0204,00 .......Infinite Energy
POKE &1D08,00 .......Infinite Lives
 Sujet du message : Re: HERBERT'S DUMMY RUN
Message Publié : 02 Fév 2009, 17:15
TIPS
Where's energy
Energy appears at these places:
1st) 4 Doors [4th floor] & Music equipment [4th floor]
2nd) Ropes [4th floor] & Exit [1st floor]
3rd) Sports [2nd floor] & Lamps [1st floor]
4th) Library [3rd floor/4th floor] & Restaurant [2nd floor]
Energy item appears in two places at once; but when you pick an item, the other disappears. And appears the next items in the list.
[after this, the energy items appear again in the 1st place]
SOLUTION
[you begin on 4th floor]
Go to right [enter 4 doors' room]. Enter breakout room and complete the game. Change racquet by glove [1st item you need for completing the game] and get brick. Go to lift (by planes' or worms' room), select 2nd floor and right door.
[you're on the 2nd floor (sports' room)]
Change brick by pop gun. Jump to climb brick and pass through till to change the chocolate coin by a real coin.
Return to elevator (do this fast!). Select 1st floor and right door.
[you're on 1st floor (bedroom)]
Go cellar and load gun. Drop gun (you carry coin and cork). Return to elevator.
[you're on 1st floor (exit)]
Go to left door. Exit building. Change cork by rope and enter (do this fast!) - (you carry rope and coin).Return to elevator. Select 3th floor and right door.
[you're in 3th floor (sofas)]
Get box key (you drop coin) and return to elevator. Select 1st floor and right door.
[you're in 1st floor (bedroom)]
Go cellar. Get gun - you drop box key. Go right. Get coat of arms [this is an useless item] and drop rope.
Return to elevator. Select 2nd floor and go to left door.
[you're in 2nd floor (castle)]
(Soldiers can't kill you) Go to restaurant and get honey pot. Return elevator (by castle's room).
Go cellar and drop gun. (you carry key and honey pot). Return to elevator. Select 4th floor and right door.
[you're in 4th floor (ropes)]
Go to starting room. When you jump on box you'll reach top shelves. Replace honey pot by teddy bear. Go left door (use shelves - it's safer ). Return to elevator. Select 1st floor and right door.
Go room that has a door with a glove, get rope. Return to the floor. Select 4th floor and right door (ignore left side - you appear in a room with worms).
[you're in 4th floor (planes)]
Go 4 doors room, go ladder, go right room, you enter a 'space invaders' room. At tbe bottom of this room, the teddy is moving to the right, when it dissapears you can pass to right room. When you're in the split room (left side), reach the rope and jump - It'll be longer. Return to 4 doors room, get radio and glove, and return to planes' room (on your way to that room you can find several screens where you can recharge energy).
Climb rope - To do this, jump and then use left-right buttons repeteadly (it's like when you run in Decathlon). Change radio by BOMB. Go to elevator. Select 1st floor and right door.
Go to glove room. Drop glove in that room. Go to lamps room. Get light bulb. Return to bedroom and repair the torch. Drop torch. Enter cellar and get pop gun (make sure it's 1st item, not 2nd). Return to elevator. Select 2nd floor and left room.
Enter castle (Soldiers can't kill you). Jump to get flag. (a fast look at restaurant if you know there's energy). Return to elevator - using castle's room-. Select 1st floor and right room.
Go to lamps room. Get bomb - you dropped it here. Go cellar. Drop bomb - box key must be 2nd item. You're in the hardest room of the game: the pool. Get duck and return (if you fall in the pool you'll appear at right side).
Return to elevator. Select 4th floor and right room.
Go to breakout room, and continue walking to the right. Climb sandcastle and jump to get pebbles. Return to elevator. Select 1st floor and left room.
[you're in 1st floor (exit)]
Get catapult and load it with pebbles. Return to elevator. Go right door.
Drop pebbles. Get torch (you repaired it a long time ago). Go cellar. Continue moving to the left - but don't drop these items. This time you can see in dark room. Kill the birds. When you've finished, you can get the toy caps.
Go to right. Get bomb. Return to elevator. Go left door. Drop toy caps (you'll need it later). Return to elevator. Select 3rd floor and right door.
[you're in 3rd floor (sofas)]
Get coin and return to elevator - when you carry bomb and coin. Select 4th floor and right door.
Go to 4 doors room. Go to door with '10p' and enter another game. In this game you've to demolish all the buildings.
If you hit one of them, you'll lose a life. When you complete the game, change coin by cannon ball. Return to elevator.Select 1st floor and left door.
Get toy caps. Return to elevator. Select 3rd floor and left door.
[you're in 3rd floor (cannon)]
Walk through the cannon and make a hole in the wall. Go left. You're at the right half of split room
Get bouncy space hopper [it's the 2nd item you need for completing the game]. Return to elevator. Select 1st floor and right door.
Go to room that has a door with a glove. Get glove -you dropped it there a long time ago-. Enter room. With the space hopper, you can jump higher and reach the switch to turn on escalator. Herbert meets with Wally and Wilma. *END*
Note: If you want to finish the game with the maximum score (101 jelly babies), get all useless items and enter elevator's hole. (to do this, return to elevator using a wrong door).
BUGS
- You can load the pop gun only in sports room (2nd floor) or the wine cellar (1st floor).
- You can repair the torch only in bedroom (1st floor) or the lamps room (1st floor).
- You can load the catapult only in exit (1st floor) or the beach (4th floor).
