Petite question !
Je vois que tu prends GREEN (in) après sa résistance et SYNC (out) avant. C'est juste par commodité où ça poserai problème de prendre la synchro aussi après la résistance ?
Les sources ont dispo sur sourceforge, et assez compréhensible pour en refaire une implémentation (au moins en lecture, je n'ai pas essayé l'écriture, encore)
14 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.7.1a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder ) - QuickDisk support : Fix MB87013 based QD machines support (Akai S700/x7000, Roland...) -> Now support the special MB87013 sync method.
8 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.6.4a - New custom firmware page option : Ignore/disable /SIDE1 input. - QuickDisk support : Fix the /Reset input behavior : The /Reset input doesn't stop the motor if this /Motor-on is asserted but always clear the ready signal.
5 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.5.1a New direct raw format support : - BAS Embroidery machines format (*.IMG,*.DSK) (System Family menu : "BAS" / 7 digits display menu entry -> 01A )
3 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.4.6a - QuickDisk support : Fixes/Timing improvements. Data masked outside the read window. - OSD : Keys/Rotary regression fixed.
1 September 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.2.1a - QuickDisk support : Various write enhancement for Roland machines support (Roland S-10,S-220,...) - OSD : Keys/Rotary wake-up behavior changed/enhanced.
2 December 2019 : Firmware STM32 USB HxCFloppyEmulator v3.4.10.8a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder ) - USB stick browser Fix : "No file image found !" printed when no folder and no floppy image are found on the usb stick.
8 December 2019 : HxCFloppyEmulator 2.2.2.1 -> macOS Catalina support : Switch to 64bits build + minimum OS version needed changed to 10.9 (Mavericks) -> Internal environment variables support to tweak/change the default internal library settings/behavior. -> Script support introduced. -> GUI : New advanced parameters window added. -> GUI : Script execution menu entry added. -> Command line tool : Script execution option added. -> Floppy Stream dump analysis bitmap export support. (Stream HFE, SCP, KryoFlux Raw) -> SPS CAPS library loader support added for Linux. -> SCP loader : Fix/set the number of heads to 2 when the number of head(s) field is set to 0. -> New files Support : Kurzweil K25 (K2500) and K26 (K2600) file support. -> Game Doctor SF3 / SF7 file support added. -> zlib updated to v1.2.11 -> FLTK updated to v1.3.5 for all platforms. -> Linux build : Automatic FLTK package download and preparation. FLTK build : Use the fltk automatic flags to match with your graphic stack. -> General : Lots of code fixes and improvements !
22 January 2020 : Firmware STM32 USB HxCFloppyEmulator v3.4.10.9a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- Version code / splash screen : Now shows you if you are using the QuickDisk firmware variant or not. - Quickdisk : 64 bytes ("Very short") Read emulation pipeline buffer size option added to the custom firmware page.
2 February 2020 : Firmware STM32 USB HxCFloppyEmulator v3.4.10.10a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- New custom firmware page option : Bitrate override.
27 February 2020 : Firmware STM32 USB HxCFloppyEmulator v3.4.11.1a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- Last selected file image auto load : Restore the file browser folder position.
1 March 2020 : Firmware STM32 USB HxCFloppyEmulator v3.4.11.2a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- STARTUPA.HFE power up auto select : Fix v3.4.11.1a regression.
28 March 2020 : Firmware STM32 USB HxCFloppyEmulator v3.4.11.3a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- OSD : Atari ST High resolution (Horizontal refresh rate : 35.8KHz) : Fix horizontal front porch delay.
15 April 2020 : Firmware STM32 USB HxCFloppyEmulator v3.4.14.1a ( https://hxc2001.com/custom_fw/ and WIP_Firmware folder )
- Stream encoder : Amiga demo "Eon by The Black Lotus" random crashes fixed.
Et voici le nouveau membre de la famille "HxC" : Pauline.
Il s'agit d'un simulateur de lecteurs de disquettes et d'un dumper de disquettes. Sa particularité ? Elle est basée sur une carte FPGA. Cela permet d'avoir une très haute résolution d'acquisition ainsi qu'une très haute précision dans les timings. Coté simulation même esprit : Fonctionnement en interne en pure stream en haute résolution : TOUT les formats et systèmes sont par design supportés. C'est une simulation purement matériel : C'est donc comme pour un support magnétique, il suffit juste de formater. Jusqu'à 4 lecteurs sont émulés, sans latence d'écriture ! Coté "service", le FPGA ayant un double cores ARM fonctionnant sous Linux, les possibilités sont immenses : Serveurs HTTP/FTP/SSH, téléchargement des images, etc etc.
Bref, la seule limitation c'est maintenant l'imagination, plus le matériel
Une petite démonstration de la fonction de dump, avec analyse et affichage des tracks en temps réel. Plus besoin de labourer l'ensemble de la disquette pour savoir si les choses se passent bien ou pas.
Ce système a été développé en premier lieu pour les besoins des associations La Ludothèque Française (LLF) (https://www.laludotheque.fr/), MO5.COM (https://mo5.com) et GPS (https://www.gamepres.org), mais Lotharek devrait proposer les cartes piggy-back pour la de10 bientôt.
