la finale est arrivé ...
2011-01-22: Exomizer v2.0 released Changes since the 2.0 beta 7 release: Fixed a bug in sfx decruncher setup where data was copied unnecessary. Added the i_line_number symbol to be able to change the default line number of the basic line of the sfx decruncher. Added various improvements and documentation of the desfx command.
vi j'ai utiliser le port de t&j. Si quelqu'un constate une différence entre la version beta et la finale de exomizer il serai bien aimable de nous poster ces conclusions
Release of 2.0.1 source code, Win32 and DOS binaries. + Fix bug in log.c that caused the desfx command to loop if the log level was lower than debug. Bug report by iAN CooG.
nouvelle maj..
2011-08-19 Release of 2.0.2 source code, Win32 and DOS binaries. + Added 6809-decruncher contributed by Edouard Forler. + Fix language errors in the documentation. Thanks to Csabo/LOD. + Remove bogus printout about the default decrunch effect when using a custom decrunch effect. Bug reported by Csabo/LOD. + Fix bug that prevented the correct error message from showing when trying to combine a basic start and a non rom config for the sfx command. Bug reported by iAN CooG.
