Nous sommes actuellement le 17 Août 2026, 14:00
Monkey Island CPC+, blague ?
Publier un nouveau sujet Répondre au sujet  Page 2 sur 9
 [ 125 message(s) ]  Aller vers la page Précédent  1, 2, 3, 4, 5 ... 9  Suivant
DaDMaN
 Sujet du message : Re: Monkey Island CPC+, blague ?
Message Publié : 19 Juil 2010, 17:09
Message(s) : 21
fano a écrit :
Les espagnols sont pas mal pour nous faire de beaux mockup dont on a pas vu la suite , snif ! (cf SFII)
First, this guy isn't spanish and he is writting in english on an spanish forum... Something obvius by the way.
And about SF2 (yes, the spanish project you mean is mine), it's a big project for only one person (me). You can program it all the source code if you want and I can make / convert the graphics... or make all yourself... or play with french version with Gameboy graphics. There are a lot of options :D
Cheers,
DaDMaN
P.D.: There is a lot of mockups on this forums, RType in Mode 0, Toki for CPC Plus an Action Role Play Game (RPG) style for CPC Plus, and others, major part mockups from Hermol. And are marvellous all of them... What's the problem with it?
Message Publié : 19 Juil 2010, 17:27
Cheers,
DaDMaN
As theses mockups have been posted on Spanish forums , i believe it was a Spanish guy (For English speaking, reference forum is usually CPCWiki for me) , so please accept my apologies for this lame shortcut.
Hermol version with GB gfx is perfectly honorable because it is a hack, he add this to an existing engine, and i know well it is already a lot of work.
About SFII , i liked a lot your mockup that's why (if we are speaking about the same, the animated GIF with Ruy and his stage on the background) , as SFII fan, i've been disapointed to see nothing more after.I am very busy on CPC/+ projects (major part of my spare time) actually but maybe we'll be able to make this project real in the future :)
DaDMaN
Message Publié : 19 Juil 2010, 17:39
Message(s) : 21
Of course! I never said something against it. :)
Yes, it's mine :) DaDMaN and DaDoS2 are the same person.
As you I've a lot of projects started and in progress (software and hardware) like this:
http://www.youtube.com/watch?v=fovobdkym-Q
http://www.youtube.com/watch?v=yB5o4-LbFs4
I'm not only a mockup maker :)
SF2 project is on an stanby fase by the moment...
Cheers
Message Publié : 20 Juil 2010, 10:36
biensur que c'est réalisable sur PLUS, avec un minimum de motivation, j'ai coder ca vite fais ce matin en 5 minutes ... écran spliter en 2 , une palette pour le haut, et une pour le bas ...
- Exit le mode 2 pour le text, et vive l'anti-aliasing ...
- Exit les icons pour l'inventaire...
- 128ko de mémoire et vive les accès disque !!
Tout ca mis a part, je vois pas trop l'intérêt de faire un port 1:1 de Monkey Island 2 sur CPC .. Pour quel type joueurs ? je vois plutôt une compile d'une ambiance graphique de plusieurs jeux lucas LOOM+INDY+MI123 avec un nouveau scenario inédit.. bref un truc qui trou le cul.. qui donne l'envie au non CPCiste j'y jouer ...
Message Publié : 20 Juil 2010, 16:25
No problem, It's always a pleasure to see moke-ups !
If only one of those goes to come true, that will be marvelous !!! :winner:
Message Publié : 20 Juil 2010, 18:11
TotO a écrit :
If only one of those go to come true, that will be marvelous !!!
For sure , at least one !
Too much mockups kill mockups ! :mdr:
Message Publié : 20 Juil 2010, 18:57
@Hermol :
En retouchant un minimum pour avoir du mode 0 dans les actions pour avoir une meilleur visibilité ça pourait donner ça :
donc 3 split screens : 2 en mode 0 et un en mode 1 (le "look at").
Edit:
En fait 4 peut etre car les icons aen bas a droite on leur propre palette
Message Publié : 20 Juil 2010, 19:09
Il y a aussi la palette à retoucher, car les couleurs sont "hors" CPC+.
Sur les autres moke-ups, il y a même trop de couleurs dans les décors, et de nombreux éléments ne sont pas alignés au caractère.
Le soucis ensuite pour les sprites hards, c'est qu'ils ne peuvent pas passer derrière le portail, la clôture, ou tout autre avant plan.
Sans compter qu'il faut penser à gérer la profondeur de champs avec les sprites, pour donner l'impression de d'éloignement du perso.
Bref, faire un Monkey Island sur CPC, ce n'est pas une sinécure ! :sweatingbullets:
Message Publié : 20 Juil 2010, 19:10
@Hermol :
C'est sure qu'un "nouveau" Monkey Island serait génial.
Mais meme l'original aurait tout sa place dans la logiteque CPC a mon sens.
Redecouvrir cette fabuleuse aventure qui n'vais jamais existé serait génial !
Surtout que peut de machines ont eut droit a une conversion !
Comme je le disais, meme le ST n'a pas eu MI 2 !
C'est comme le mock up en debut d'année que j'ai vu ici de Toki :
Si vous aviez fait une retranscription 1:1 c'etait pas du luxe.
Surtout celui là ! y avait une version de prévu mais qui n'a pas vu le jour.
Donc une version CPC (plus) avait LARGEMENT sa place.
Faire des nouveaux levels prend ENORMEMENT de temps.
Donc, pour un premier jet, faire une conversion de l'original n'est pas dénuée de sens je pense.
On peut imaginer APRES des nouvelles choses.
non ?
Message Publié : 20 Juil 2010, 19:19
C'est vraiement pas possible sur CPC + ?
Des démos CPC+ me ferait penser le contraire mais c'est vrai qu'il yt a un fossé entre DEMOS et JEUX.
Pour les couleurs, le split screen permet un affiche superieur a 16 couleurs, non ?
TotO a écrit :
...Le soucis ensuite pour les sprites hards, c'est qu'ils ne peuvent pas passer derrière le portail, la clôture, ou tout autre avant plan...
Y a vraiement aucun jeux qui fait ça ? meme Prehistorik II ou Cauldron II ?
C'est si ingerable que ça la "pseudo" 3D (a la SNES) sur CPC+ ? (meme si sur SNES c'est carrément une puce qui gérait ça !)
Apres, de ce que je connais de Monkey Island c'est pas non plus dans l'integralité de faire des diminutions de sprite.
Je pense que c'est faisable, non ?
De meme que l'ouverture des porte qui peuvent etre en noir, non ?
Message Publié : 20 Juil 2010, 19:28
Je ne dis pas que c'est impossible, mais ce n'est pas aussi simple qu'un moke-up peut le laisser penser.
Il n'y a pas non plus l'affichage des textes en incrustation pour les dialogues. (et ça c'est coton)
Sans parler de la richesse des animations, qui font tout le charme du jeu.
Bref, c'est certainement possible de faire quelque chose qui s'en approche, mais avec de nombreuses concessions. (et beaucoup ... beaucoup de temps)
Mais oui, ça serait géniale si ...
(merci pour ta modif mode0 sur le moke-up, ça rend bien)
Message Publié : 20 Juil 2010, 19:42
Merci pour les compliments, ça fait toujours plaisir...
C'est vrai que j'avais oublié l'essentiel : les dialogues.
A incruster dans un CPC(+), il me semble que c'est pas une mince a faire.
Message Publié : 20 Juil 2010, 19:47
Tien, regarde ça :
http://www.youtube.com/watch?v=Q_rUHyGD ... re=related
Ca ne fait pas de mal de se remémorer les choses ! ;)
Message Publié : 20 Juil 2010, 20:21
TotO a écrit :
Tien, regarde ça :
C'est vrai que c'est pas du luxe de revoirt ça.
AU lins on se rend mieux compte des choses possibles a faire sur CPC(+).
Mais par pitié Her mol, va jusqu'au bout du truc.
j'suis sure que y a moyens de faire quelque chose.
depuis le premier post de ce sujet je me rend compte des possibilité du CPC(+).
Et meme faire une conversion 1:1 serait EXTRAORDINAIRE.
déja parceque les jeux point & click sont rares sur CPC.
de plus, ce MI2 est une reference.
De meme que arriver a en faire une conversion 8 bits serait un exploit jamais vu sur des machines de ce type.
Moi je serai le 1er a refaire l'aventure version CPC meme si y a pas de nouveauté, et j'suis sure de pas etre le seul.
Message Publié : 20 Juil 2010, 20:35
...et pour revenir sur une phrase dite ici, un Monkey Island est un "gros" truc.
OK.
Mai là pour le coups, quel interet de viser une conversion d'un petit jeux en 2010.
MI2 me semble un excellent challenge en soit, non ?
