Nous sommes actuellement le 19 Sep 2026, 10:58
[EMU] ACE-DL : ACE Linux/MacOS/Win port
 [ 28 message(s) ]  Aller vers la page Précédent  1, 2
 Sujet du message : Re: [EMU] ACE-DL : ACE Linux/MacOS/Win port
Message Publié : 15 Déc 2024, 15:18
Message(s) : 3700
Last official release O.D.I.L.E. - 2024/12/14
- added new traductions
- added FullScreen mode for Linux/Windows users (F11 key)
- upgrade width/height limit to 512 in Graphics Explorer
- added Amsdos header option for Memory import in configuration saves
- now you can resize Graphics Explorer window + size saved in configuration
- display an error message when a file is not supported (instead of simply discarding it)
- bugfix step over in trace with HALT, LDIR, CPIR and other 'looped' instructions
- bugfix number of selected Upper Rom, displayed in Gate Array window
- bugfix number of selected bytes after a successful search
- bugfix recovery of explorers coordinates after close/reopening
src/url: http://www.roudoudou.com/ACE-DL/
Message Publié : 28 Déc 2024, 09:12
Message(s) : 3700
Last official release Noël - 2024/12/24
- spanish translations for the GUI (see flags with F12)
- ability to use (L)abels to jump in memory from Graphics Explorer
- +/- from numeric keypad change emulation output volume
Message Publié : 24 Jan 2025, 13:48
Message(s) : 3700
Last official release JoooOOOOooonnnvier! - 2025/01/22
- upgraded iMPdraw rom pack to sept 2024
- new options for EDSK autosave and versioning
- ability to save Tiles/Sprites in graphic explorer
- ability to load RASM symbols chunk in Cartridge (get new Rasm!)
- ability to toggle all execution breakPoints from Trace with key 'T'
- execution breakPoints in watcher mode are now green in Trace
src/url: https://roudoudou.com/ACE-DL/
Message Publié : 12 Fév 2025, 11:12
Message(s) : 3700
Last official release Guy Leven - 2025/02/11
- Minor release solving the problem of moving windows when using lateral taskBar or upper taskBar
src/url: https://roudoudou.com/ACE-DL/ ;linked:
Message Publié : 24 Fév 2025, 17:36
Message(s) : 3700
Last official release SDL3 - 2025/02/24
- Now using SDL version 3 which include strong internal changes
- New joystick management engine (should fix xbox joystick issue, and more)
- Analog joystick support for Amstrad Plus/GX-4000 + bugs optional emulation
- Improve responsiveness of keyboard inputs in GUI
- Bugfix Virtual keyboard (wasn't exporting keys)
- Highlight modifications in Memory Explorer
- FullScreen now use hardware blit rescale
Message Publié : 30 Mars 2025, 16:38
Message(s) : 3700
Many ergonomics fixes, graphic glitches. Cathodic filter minor modification
New additionnal memory selection capabilities (see documentation below)
Last official release Mars - 2025/03/28
- Trim end of filenames to remove spaces (mostly a ManageDsk problem with existing names)
- Do NOT play Relay Click sample when using CRTC-3 (Plus/GX) model
- Fix window glitch when redefining joystick
- Fix double window blit with Graphic Explorer
- Minor Cathodic filter light propagation enhancement
- Keep line count display in HUD during paused emulation (Trace)
- Ability to click and drag for memory selection in Memory Explorer
- Ability to set end of selection with SHIFT-G (goto) in Memory Explorer
Message Publié : 13 Mai 2025, 19:39
Message(s) : 3700
Last official release MayLeven - 2025/05/11
- Update SDL3 to 3.2.12 version (more joysticks supported)
- Enforce window position inside available screens
- Cursor navigation in Label search window
- Raise window in case asking for it but already opened
- Stack values in Trace may be clicked to jump to these values
- Bugfix fastSearch in file selector with lower case + reloop on a key
url/src: https://roudoudou.com/ACE-DL/
Message Publié : 14 Oct 2025, 20:41
Message(s) : 3700
New build for Raspberry Pi - 2025/10/13
no update for the other OS, we are still working on expansion cards...
- Update SDL3 to 3.2.16 version (X11 fullscreen fixes, MacOS Catalina mouse fixes)
- Allow to change memory source in Memory Explorer without going to debug
- Ability to save media (F4 key) from floppy file management
- Ability to change audio driver from configuration menu + saved in configuration
- Fix extended cartridge slot count + NBBK endian read
- Fix SDL3 audio driver selection from command line
- Fix Mono/Stereo switch in Machine configuration (no need to restart emulator to be effective)
Message Publié : 04 Nov 2025, 10:09
Message(s) : 3700
BND-5 RELEASE (2025/11/03)
- Raspberry Pi version \o/
- Update SDL3 to 3.2.24
- bugfix hardware configuration option submenu
- bugfix joystick configuration (random consideration)
- bugfix interrupt order and ack (thanks to NoRecess)
- bugfix on CRTC-2
- little adjustment in free/adaptive/g-Sync management
- new plugin for MasterCity soundcard (ym2412) thanks to Syx
- Samples and OPL emulation for Play2CPC thanks to Syx
- plugin audio emulation rewritten to fit original ACE management
- cosmetics in AY module
- added interrupt pending in Gate Array visualization
- new command line to disable all windows but the emulator
- do not bother endlessly with DSK to save when user sayed No
- ability to load floppy image in A: or B: by prefixing their names
- added red border with disabled sprite or green border with sprite enable
Message Publié : 31 Déc 2025, 16:36
Message(s) : 3700
2025 Before New Year's Eve (30/12/2025)
- ability to execute data after load in memory explorer, with or without AMDSOS header (drag inside center box)
- bugfix Memory explorer emulator mapping in Plus mode... (nobody using it? ^_^)
- bugfix regression in keyboard selection for Mac
- added new translations in configuration menu
- added DSK watcher on all drives (see other misc options)
- added CPC+ chunk decoding when loading ACE snapshot
- added CRTC address next to memory address in graphic explorer
- added hardware sprite highlight (in most standard multiplexing cases)
url/src: https://roudoudou.com/ACE-DL/ ;linked:
Message Publié : 18 Fév 2026, 20:49
Message(s) : 3700
New release Saucisse! (2026/02/18)
- updated SDL to 3.4.0
- bugfix regression in breakpoint address mask selection
- bugfix crash when export listing without selecting a file
- bugfix wrong values in DMA debug
- ASIC debug also display current line in Hexa
- ASIC can be unlocked clicking on "Locked &" in ASIC debug window
Message Publié : 08 Mai 2026, 16:07
Message(s) : 3700
New release "Pico fragrance" : 2026/05/07
- added bank 0 support mapped anywhere for picoSave
- test coordinates to enforce each opened window inside a visible screen
- fix last written address may trigger a new command with picoSave
- fix picoGX trigger during TRACE display
- fix picoGX STOP command (must not write all the time ^_^)
New release"Focus" : 2026/??
- fix disassembling windows opening from trace shortcut D
- picoGX save support
- side-windows more responsive
- added BREAK ON VBL in breakpoint module
- default adress Mask with memory breakpoint is #FFFF
- display VBL nop count in debug title bar when BAD VBL trigger breakpoint
- added backspace+delete in label search popup when not using keyboard translation
New release "Enlarge your cartridge" : 2026/??
- handle legacy CPR up to 1.5M (XPR support remains for bigger cartridges)
- DSK history add timestamp to OLD version (not new...), the last version keep the original name
- memory explorer windows are now resizable + bigger font
- new option to add a grid over emulation window (see other misc options)
- new option to hide tooltips of the HUD
- do not save file if ESC pressed or focus lost with filename input box
- bugfix EDSK manager crash with kindah textbook case
- bugfix cartridge loader with unknown chunk
Message Publié : 15 Sep 2026, 20:23
Message(s) : 3700
=== 2026/9/14 Heat waves ===============================================
- updated SDL to 3.4.16 (more controllers supported + fixes)
- first version of web API server for remote control (inspired by Lone's work, see WEBAPI.html)
- new command line options to enable WEB API and activate borderless mode
- fix crash with snapshot+dsk not found (ooops) or wrong DSK tryout
- fix modules popup behaviour (intempestive closing)
- FullSpeed can be toggled from trace (HUD)
- Graphic explorer displays current byte/addr/crtc realtime
- Monitor+INFO merged into a single selection module menu
- had to slow down a little Clipboard send because of SHIFT inertia with the system
- do not try to refresh a minimized window
- reset existing breakpoints when loading at least one breakpoint from a snapshot
- clipboard Send now works with emulator mapping activated
- clipboard may be send either with SHIFT-INSERT or SHIFT-RETURN (for PI & Mac)
- during Trace, it's now possible to change CRTC by clicking on CRTC in the bottom HUD
=== 2026 Not yeeeeeeeeeeet ===================================================
- updated SDL to 3.4.10 (more controllers supported + fixes)
- ability to send text to emulator from clipboard with SHIFT-INSERT (fast mode in other misc)
- ask for drive change when floppy is too big for current drive (see also other misc options)
- when trace in high-speed (with SHIFT), reduce side windows refresh
- new debug window Register Explorer (left-click on trace to open this window)
- new debug window Memory History visualisation
- trace window is now resizable in width (in order to display longer labels)
- trace submenu can be opened using P key when you do not have right-click available
