Nous sommes actuellement le 09 Mars 2026, 03:43
Arkos Tracker revealed
Publier un nouveau sujet Répondre au sujet  Page 4 sur 4
 [ 56 message(s) ]  Aller vers la page Précédent  1, 2, 3, 4
 Sujet du message : Re: [UTIL] Arkos Tracker II revealed
Message Publié : 28 Fév 2018, 22:24
Arkos Tracker v2.1.0a2 - (27/02/18)
New features:
- Added the Generic player, with sound effects.
- Added a stand-alone sound effects player.
- Added a NOP-accurate AKY player (for Amstrad CPC).
- Breaking change: the players are now initialized with HL, not DE.
- MOD: Silently corrected old MOD (15-instrument) which loop offset was wrong. Some old MOD will now load.
- UI: Allowed the use of the native title bar (in the Setup).
- UI: Corrected a small bug on the Lightweight extension on export, was using AKY instead of AKL (thanks AST).
- Added a message when playing a song if there is no sound card.
- Added a log file in case of a crash.
- A dialog opens while loading and saving a song, the operation is done asynchronously.
- Tweaked the generated output of the Sound Effects source.
- Reduced the height of the Song Properties window, too big for some screens.
Bug fixes:
- CRASH: Corrected crashes when exporting as binary while using a Source Profile not understood by the embedded Rasm.
- CRASH: Corrected a crash that could happen when exporting as RAW.
- CRASH: Corrected a crash happening when there was no sound card.
- Corrected some IO problems in all the players.
- Corrected a small bug in the volume for the sound effects in the Lightweight player.
- Corrected a bug in the Instrument Editor: the software pitch (in a Hard To Soft line) was in wrong direction.
- Corrected the export as binary for Sound effect: it exported as source. The command line tools also have now a security preventing this.
- Improve the readability of the JUCE File Chooser, used in case the OS doesn't have kdialog/zenith.
src: http://www.julien-nevo.com/arkostracker/
 Sujet du message : Re: Arkos Tracker revealed
Message Publié : 12 Mai 2018, 19:13
Arkos Tracker V2.1.0a3 (11/05/18) released!
New features:
- Adapted all the players to MSX, Spectrum.
- Added a MOD player (CPC-only, limited effects).
- Created a specific Lightweight player for the SHARP MZ 700, as well as the sound effect player.
- Adapted the Lightweight player to MSX, Spectrum, Sharp MZ 700.
- Added a AKY player that uses the 6-channel of the TurboSound extension for Spectrum.
- Added a AKY player that uses the 9-channel of the Spectrum Next.
- RAW and AKG export (via UI and command line) now integrate sample export.
- Added new parameters in all the command line tools to set the source profiles (change mnemonics, etc.).
- In the PSGs, the mixing type can be set (ABC, ACB, BCA etc.).
- In the Output Panel of the Setup, and the WAV Exporter, the volume of each channel (left/center/right) can be defined.
- In the Source Profiles, added the possibility to encode "one mnemonic type per line" (especially useful for 68000 assemblers). Also available for all the command line tools.
- Added a basic DC offset removal on WAV export.
Bug fixes:
- Corrected a big bug that made the Save option fail when exiting (thanks XiA).
- Corrected a bug in AKY that could make the Hardware-only sounds sound bad.
- Corrected how the MOD import wrongly transposed its notes.
- Corrected a crash that could happen when exporting as RAW with Pitches.
- The center volume has been corrected (too low according to the real CPC).
- Saving a file could fail if its name was illegal (instrument with a strange name, etc.).
- Corrected a bug in the MOD import, making the channel mixing option ignored.
- Corrected some minor display problems when changing the height of a Pattern, if the cursor was outside of the new height.
- Corrected possible crash when erasing patterns from the linker.
Breaking change:
- RAW format slightly modified.
- MAC native menu bar has been DISABLED. A JUCE bug (it seems) made it disabled when popups+file choosers are shown.
I've filed a bug report, waiting for it to be corrected... As a workaround, I disabled the native MAC menu. Sorry. But at least, you can use the software.
- Windows XP is no more supported. Not my fault, the cross-platform framework I use (JUCE) does not support it anymore.
Other additions:
- Displayed the song name in the title bar, if any.
- Added another demo song by Excellence In Art (thanks!).
- Optimized the AKY Stabilized player from 1183 to 1174 nops, thanks to Hicks.
- MOD import: the volume in the effects are converted to logarithmic values to better fit the PSG.
src/url: http://www.julien-nevo.com/arkostracker/
 Sujet du message : Re: [UTIL] Arkos Tracker revealed
Message Publié : 06 Nov 2018, 20:41
Arkos Tracker V2.1.0a4 released! (01/11/18)
Finally! After 5 months of work, here is it. It includes some cool features, such as:
Breaking changes:
- The Z80 assembler target now Rasm (by Roudoudou). Minimum effort are needed to convert them to SJasmPlus though.
This was required to implement the player configuration feature (see below) in a better way.
Please check the "players" page on the website to find tricks on how to use it on any assembler.
New features:
- Copy/cut/paste in the Pattern Viewer.
- Added a contextual menu in the Pattern Viewer.
- Changes in the keyboard shortcuts in the Pattern Viewer (transpose, octave, instrument, solo, mute, etc.).
- Added an Arpeggio Generator in the Pattern Viewer. Enter notes, select them, right-click and generate an arpeggio from them!
- UI changes:
- Changed the location of the Meters, now besides the Linker. More space!
- Changed the layout of some pop-ups to make them more small-screen friendly.
- Player configuration:
- "Player configuration" source files can be created when exporting songs or sound effects.
Using such files, the players only compile what the songs require (CPU and memory gain!).
- Done for AKG and its sound effect player.
- Done for Lightweight and its sound effect player.
- Done for AKY (Z80 version only, "normal" version (accurate/stable not done)).
- Song optimizer: on export, the Songs are more optimized (will introduce "clean song" options in the UI in later releases).
- Added a Vortex Tracker 2 import (.VT2/.txt).
- Added a Chip'n'Sfx import (.CHP).
- YM Analyser tool: load and play YMs, extract sounds from them.
- YM are now exported with digidrums.
- Atari ST:
- The AKY Player has been converted to 68000 for Atari ST, by GGN. A huge thanks to him!
- Added an option in the AKY export to encode all label references relative to the beginning of the song (useful for Atari ST players).
- Sample export:
- Added a fade out option to prevent clicks, for non-looping sounds. It can go to 0 of to the middle value.
- The padding value can also be 0, or the middle value.
- Added an option to export only the necessary length.
- Source profile:
- Added a mnemonic for strings.
Bug fixes:
- Corrected a big bug when inserting/deleting an item in Speed/Event Tracks (the wrong track could be changed).
- Corrected a source compilation problem when exporting samples in AKG format (thanks Hicks).
- Corrected a bug making the "export samples" dialog disabled, if in AKG/RAW export, export samples was off.
- Corrected a bug with the "source to Orgams" Python converter (thanks Hicks).
- Improved/corrected how the Retrig in instruments is exported (AKG, Lightweight, sound effects).
- Corrected a small UI bug about the selection when collapsing tracks.
- Corrected how the PSGs are addressed on SpecNext (stereo wrongly applied) (thanks Emook).
- Limited the export binary to 4 digits (#ffff) max. Handled correctly out-of-bounds assembling.
src/url: http://www.julien-nevo.com/arkostracker ... -released/
url: http://www.pouet.net/prod.php?which=80888
Message Publié : 13 Mai 2019, 08:03
2.0.0a5 - 11/05/19
New features:
- Converts all the sources from Rasm to ANY OTHER ASSEMBLER, thanks to Disark, a new command-line tool! Read the compatibility page for more information.
- New format AKM (minimalist), for ultra-lightweight (yet powerful) music and player (also sound effects)! Makes Lightweight format rather obsolete.
- Midi in: plug your keyboard and play! You can also change instrument from your keyboard. Only "Note On" and "Program change" MIDI messages are recognized (from any MIDI channel).
- Midi import (see the Midi import page on the website about how to get the best results).
- UI overhaul:
- Expressions (Arpeggio/Pitch) have now a dedicated tab. More space for everything else! Watch out for the F1-F4 shortcuts, they have changed.
- A small square shows which line is played in the Instrument Editor, and the Arpeggio/Pitch tables.
- Improved how the focus on components is shown.
- Harmonized the colors.
- ROM players! Using a simple flag, the following players can be used in read-only area (such as ROM) while using a small buffer you can put in RAM:
- AKY (only the main player).
- AKG (sound effect player included).
- AKM (sound effect player included).
- Stand-alone sound effect player.
- Lightweight NOT done, unless I'm asked to (you should use AKM now, it is more powerful).
- Sound effects code changed: speed is now included, allowing major optimizations for slow sounds.
- The Sound Effect Export dialog now has an option to find the notes directly from the Song.
- Clicking on the instrument symbol in the instrument list to listen to the instrument.
- MSX: R7 now has its bit 7 set and bit 6 reset (hardware compatibility).
- The latest folder is saved according to a context (song, instrument, export, other).
Breaking changes:
- As stated above, the sound effects must be regenerated to use the new players, as the format changed.
- There is no more one player for each platform: one player for them all. It makes maintenance easier for me (they were generated anyway).
- Players are now using special features from RASM. Please check the compatibility page, a new source converter is available (Disark)!
Changes & smaller features:
- Pattern Viewer:
- Shift+left click selects from the cursor to the pointed area.
- Removed the ugly "collapse effects" icons, now unified into a single icon. More space for later features.
- When record is off, you can now play notes in every column (thanks Mr Lou for the suggestion).
- Mouse wheel can be used in the Test button of the Test Area, but also in the Sound Effect Export dialog.
- Loaded samples can only be 64kb maximum, instead of 128kb. This was necessary, because it made source impossible to encode the sample length if >64kb.
- Shortcuts:
- Added the "toggle play/stop" shortcut (Space). VERY USEFUL, USE IT! Thanks Mr Lou for the suggestion.
- Added the "select whole track" shortcut in the Pattern Viewer (Ctrl+T).
- Added Escape as a Stop shortcut.
- "Play line" is now Return.
- "Capture Instrument" is now Shift+Return.
- F1->F6 are now changed to reflect the new interface.
- Added a default key for loop pattern: Shift+space.
- Added Ctrl+I/O to set the start/end in the Linker/Expressions/Instrument editor.
- Added Ctrl+P to toggle the loop in the Instrument editor.
- MacOsX: RST in the PatternViewer is now "-", as the original key ("*") was unreachable.
- Removed the "AKY accurate" player. Its maintenance cost outweighs its usefulness.
- Space to duplicate in the Linker has been disabled, because it was too easy to mess things up, now that Space is used to Play Song. Space in the Linker will also Play song.
- Corrected the template instruments, added two new ones, changed the selected default instrument.
Bug fixes:
- AKG player:
- Corrected a small bug that could happen when using the Force Instrument Speed effect.
- Corrected a bug in the PLY_AKG_Stop method, forgot to save the stack (thanks wlcracks).
- AKY player: corrected a possible bug when using a certain player configuration.
- Corrected sample export when the sample is >64kb: an error is shown instead of a crash (thanks Arnaud).
- Corrected a possible crash when pasting, if going beyond the last line of a pattern.
- Corrected a crash that could happen when loading an instrument on Linux (thanks Roudoudou).
url: http://www.julien-nevo.com/arkostracker ... /download/
 Sujet du message : Re: Arkos Tracker II revealed
Message Publié : 25 Juil 2019, 17:36
2.0.0a7 - 22/08/19
New features:
- Undo/redo for the PatternViewer (only!). Functional, but changing the song properties will clear the history (will improve that later).
- YM chip support.
- 6502 AKY player for Oric and Apple 2, thanks to Arnaud Cocquière!
- Sound effects support for AKY player.
- Pattern viewer:
- Added colors to instruments, that are also shown on the pattern viewer (notes and events).
- Effect chooser, with a possibility to overwrite the effect under the cursor.
- Disark: music and sound effects now export their start label (useful for SDCC).
- Better optimization when exporting and importing (useless effects are better optimized).
- Pattern viewer:
- Taller middle line in the pattern viewer, slight changes of colors.
- Capturing an instrument in the pattern viewer also changes the current octave from the note.
- New keyboard shortcut to play from the cursor (only from the pattern viewer: Alt+Space or Ctrl+Shift+Space on Linux).
- Song to WAV can loop multiple times.
- Improved the import of VT2 old files, in case the PSG frequency wasn't set in the file.
- ESC in the Test Area now stops the song and all sound too.
- Added an example to use a music from BASIC (CPC) in the AKG/testers folder.
- 6502: Added a source profile for 6502 (ACME assembler).
- Linux: Reduced the size of the executables (thanks ellvis for testing).
Bug fixes:
- Corrected a Disark bug on SBC+immediate instruction with SDCC (thanks teopl).
- Corrected a "player configuration" bug if using sound effects. If everything sounded right, don't worry. Else, export the sound effects again and use the latest players.
- Corrected a bug when exporting samples in an YM (if the end was not the same as the size) (thanks Le Glafouk).
- Corrected a small bug in the AKY ROM buffer management (a few bytes were wasted).
- Forgot the MIDI files to show in the file picker when opening a file (thanks Pulkomandy).
- Corrected the tooltips disappearing on Windows 7 + Aero theme (hopefully! Thanks znanarz).
- Corrected a bug when loading a new song, the mutes states were shown but the sound were still on (thanks Xia).
- Corrected a bug when importing .128, instrument pitches were inverted.
(2.0.0a6 - never released)
url/src: http://www.julien-nevo.com/arkostracker ... /download/
Message Publié : 18 Juin 2020, 08:02
2.0.0a9 - 15/06/20
Small features:
- Now stores the PSG reference frequency (440Hz, for example) as a float for more accuracy.
- Option in the setup to save the AKS file in an uncompressed way (useful to transform the XML more easily).
- Added more warning and error output on the Command Line tools.
- Added an option on some Command Line tools (AKM, LW) to consider all warnings as errors, as a security.
Bug fixes:
- AKM player (thanks Arnaud!):
- Corrected a problem with Arp and Pitch that could alter the note of the next tracks.
- Corrected a possible crash when unknown effects are found.
- All ROM players:
- Corrected ROM players + SFX that could have a problem if the buffer was not cleared before (no need to do that anymore).
- Corrected a problem in the player configuration generation in some rare cases.
- Corrected a possible MIDI import crash (thanks Pulkomandy!).
- Corrected a huge bug on Mac in the Pattern Viewer: a click on effects would select it, not make a simple "go to" (thanks RedBug!).
- Corrected a copy/paste bug in the Pattern Viewer if a single note was copied (thanks Pulkomandy!).
- MOD import: managed speed better if BPM used instead of old-school ticks (thanks Megachur!).
- Disark:
- Forgot to consider a few instructions as "undocumented" (ld e,ixh, ld e,ixl and ld iyh,n) (thanks Cpcitor!).
- Corrected how some undocumented instructions were encoded ("rl (ix+r),b" for example), when using the "as bytes" option (thanks Roudoudou!).
- More output if an area is invalid.
- Corrected a bug in AKG generation, if no effects were present (Disark would fail) (thanks Cpcitor!).
- Corrected the broken small application icon on Mac.
2.0.0a8 - 01/02/20
New features:
- Serial: connect to your machine (CPC...) in real-time via Serial (COM port, etc.) to transmit the sound!
- The client supports CPC only for now, because I have no other hardware to test, but it's easy to implement new hardware.
- The supported Serial interface on CPC are CPC Booster, Mini Booster, USIfAc, and Albireo. AT2 can support any kind of interface.
- Can support any kind of extensions. Right now, supports bare PSG and PlayCity (9 channels).
- Look at the Serial source folder to test, a ready DSK is also available!
- A toolbox in the pattern viewer allows to transpose, swap, remap specific instruments (in the pattern viewer only).
- Instrument preview when loading them.
- By default, on Linux and Mac, a "non-native" file picker will be used, because the preview might not be visible depending on your OS. You can change this behavior in the File > Setup.
- MOD import can now generate directly PSG instruments instead of samples (detecting drums from the instrument title).
- Splash screen with tips.
- New icon and logo!
- When saving, extensions are automatically added (especially useful on Linux where is wasn't already the case).
- Put the Record icon the pattern viewer, not in the main toolbar.
- Added an option in the pattern viewer not to write an instrument when a note is entered (works also for Midi notes).
- Added shortcuts (numpad 7/8/9/4/5) to move the cursor to each quarter line of the pattern.
- Midi import detects empty tracks (like "conductor" tracks) and don't import them by default, correcting some Midi imports that could miss the first track (thanks Gurneyh).
- Optimized the midi import, which could be slow (actually, optimized the song optimizer).
- In any grid, added the S shortcut to invert the sign, if possible.
- Capturing an instrument in the pattern viewer also changes the note in the test area.
- Pressing Enter in the test area (F6) plays the current note in the test area.
Tweakings:
- Added a Step icon in the pattern viewer, instead of a text.
- In fullscreen, no more border around the application window (thanks LeeBee).
- The "clear cell" in the Pattern Viewer is now Shift+Backspace, and "delete selection" Ctrl+Backspace.
Bug fixes:
- Corrected Disark to manage EQUs with SDCC.
- Corrected a bug in the AKY multi-PSG player, for songs without noise (thanks Andrew Owen).
- Corrected a copy/paste bug in the pattern viewer, preventing effects to be copied "to the left".
- Corrected a small bug on player config generation when using B and C effects, but never A (thanks Robert Pearmain).
- Corrected a bug on WAV export, where unwanted sounds could be heard at the beginning (thanks MrLou).
- Corrected the Midi recorded note that were also clearing the effects.
- Midi notes cannot be recorded anymore if the Pattern Viewer is not visible (too much error-prone) (thanks JB Le Daron).
- Corrected a crash when songs or instruments are loaded with a broken or unknown XML structure (thanks Gurneyh).
- Corrected a possible crash when mixing tracks on Midi import.
- Fixed the broken tray logo on MacOsX.
 Sujet du message : Arkos Tracker 3 revealed
Message Publié : 19 Oct 2024, 10:23
Arkos Tracker 3 is here!
With a whole new design and a pack of new features!
- still the reference tracker for AY-3-8912 and YM-2149F!
- cross-platform (Windows, Mac, Linux)
- now open source!
- user-friendly interface
- efficient and powerful players for Z80, 68000 and 6502 CPUs.
src/url: https://julien-nevo.com/at3test/ ;linked:
Message Publié : 26 Déc 2024, 08:26
Features
Tools:
- Added a "Rearrange patterns" to sort the patterns in ascending order.
- "Rearrange patterns" can also remove useless patterns.
- Added a "Clear patterns" to remove all the patterns and tracks of this subsong.
Tweaking
- IE: The position height is now in decimal if the lines are shown in decimal (thanks Reset!). Improved the Set Height dialog.
Bar editors:
- Space to duplicate now fills the other values better, when out of bounds.
Bugfixes
- The shift parameter in Expressions wasn't saved!
- Arkos Tracker 1 song couldn't be loaded unless unzipped (thanks Reset!).
Linker:
-Cannot cut all the patterns anymore (thanks Reset!). Cut and Delete contextual options are greyed out if the whole song is selected.
YM Export:
-Non-used hardware envelopes/periods aren't encoded as 0 anymore.
-Corrected how simple event could produce a corrupted file.
-Corrected a possible crash on export.
3.2.2 - 01/12/24
Features
Linux: The app icon is well set, as app is well declared to the OS and can be found (thanks Shalafi!).
Mac: Run now on both Silicon and older Intel processors.
Instrument Editor:
- Most rows can now be hidden. The arrow is shown only on hovering. Empty rows are automatically hidden.
- Moving from an instrument to another keeps its hidden/shrunk features.
- Rows can also be shrunk according to their maximum values.
- Shift/ctrl+F to toggle the visibility of the row above/below the cursor.
- Shift/ctrl+G to grow/shrink the row where the cursor is.
- Shift+H to hide all the empty rows and shrink all rows. Ctrl+H to also shrink to a maximum.
Bar editors:
- Backspace to reset the value where the cursor is.
- Space now only duplicates the value where cursor is (shift+space to duplicate the whole column).
Test area: the currently used expression is written below each icon.
Streamed music analyzer:
- Last loaded song and playing position are kept in memory for reopening.
- Added a "lock length" icon for the loop end to follow the loop start.
- Press Tab to go from a panel to another, Shift+Tab to go reverse.
Command line tools (AKG, AKM): added a "s" parameter to export only specific subsongs. As a convenience, if not present, all the subsongs are exported (different behavior from AT2 where only the first one was!).
Selecting the instrument/pitch/arpeggio editor panel automatically opens the related list.
Bugfixes
- Creating a new song wouldn't clear the path of the previous song, so saving it would overwrite it!
- Corrected the width of the caption background in the bars when there are 3 digits.
- The default song doesn't have a second empty arpeggio/pitch anymore.
3.2.1 - 21/10/24
Tweaking
- PV: Changed how clone pattern would treat linked-to tracks: cloned tracks are linked.
- Some wording in contextual menus.
Bugfixes
- LK: Corrected a few bugs when moving patterns (thanks Zik!).
- PV: Special track names were not saved (thanks Zik again!).
WAV export: Corrected a wrong looping behavior (thanks Zik again again!).
3.2.0 - 21/09/24
Features
- An instrument optimizer tool window allows to see what instruments are unused, and delete them.
- PV: Toolbox to transpose, map/remap instrument.
Tweaking
- PV: Crt+T to select the whole track can also select several tracks according the current selection.
- PV: Crt+A to toggle between selecting the whole music tracks/tracks.
- PV: Space behavior changed: if there is no block, plays the whole pattern instead of creating a block.
- TA: Muted channels are now skipped in both monophony and polyphony.
- LK: Cloning a position doesn't duplicate the tracks names (to make the Link feature work better) and marker.
- LK: New shortcut to increase/decrease the pattern index (ctrl+shift+up/down).
- IE: New shortcuts to set/toggle the loop/auto-spread (Ctrl+I/O/P, add shift for auto-spread).
Bugfixes
- PV: Corrected the MIDI record which failed.
- IE: Corrected a crash when moving the cursor to the start.
- TA: Corrected a crash when changing a toggle (regression).
3.1.0 - 15/06/24
Breaking changes
- Due to the new Link feature, songs created with 3.0.0 will NOT be compatible!
- AKY export has been fixed for hardware+noise. All AKY must be exported again with AT3 to sound correctly with the new player.
Features
- PV: Tracks can be linked/unlinked, Special Tracks too. Context menu possible.
- PV: Effect dropdown overhaul.
- PV: Capture the instrument is extended to capture effect and arp/pitch.
- PV: Red border when recording.
- PV: Reordering/adding/removing instruments/expressions does not erase illegal items in the patterns anymore.
- LK: Added hovering icons to add new/repeat positions.
- LK: Enter and double-click on a position now opens the Pattern Viewer.
- LK: Click on the color swatch to edit the position.
- IE: A cursor is now present. Use cursor, space to duplicate, Enter to edit. Insert/delete/generate actions perform from here.
- IE/PV: Alt+mouse wheel to scroll horizontally.
- Ability to import/export Themes from/to XML.
- Added changelog to the build.
Bugfixes
- AKY: Hardware sound with noise was broken on exporter and player config change interpreted in the player (thanks Zik).
url/src: https://bitbucket.org/JulienNevo/arkostracker3 ;linked:
Message Publié : 04 Oct 2025, 06:40
Breaking changes
Glide effect: It now requires the instrument to be removed. This is to be more logical, but also to prevent mistakes from the user. Please review your songs! Use the new Error Checker :). As a convenience, imported AT2 songs with note + instrument + glide will have their instrument removed. However, AT3 songs are not modified.
Features
- New player "AKY SPL" to play one sample (on any channel - but one sample at a time) along with PSG. Check the AKY SPL player and the related page on the website (https://www.julien-nevo.com/arkostracke ... sg-player/)!
- Error Checker:
* Added an Error Checker (in the Tools menu) to check whether any effect is malformed in your song.
* A warning icon shows in every Export dialog if the song contains errors.
- Added a new "Export to RAW Linear", useful for the new sample player.
- Added a MIDI export (thanks Doclands for the testing!).
- Added a MOD export. Please bear in mind the harsh limitations of this format (see the related page on AT website)!
- Added a "Export instrument to WAV".
- Added an option in the Audio/Midi Setup to add the current octave to all the MIDI input notes. Useful if you have a tiny MIDI keyboard!
- YM export can now export to YM3 (for legacy projects or specific converters).
- Pattern Viewer:
* Added "paste and move below" (shift + V), very useful to spread the clipboard around.
* Added a "paste continuously" (ctrl + P) to spread the clipboard till the end of the position.
Tweaking
- The MOD player now uses a new period table, more accurate (the same as the AKY+SPL player).
- Added a "Load instrument" option in the main menu.
- Mixed the Edit Subsong properties and Select Subsong menus into one.
- Pattern Viewer:
* When an action is forbidden because Record is off (paste, insert, etc.), the Record button flickers for you to understand why.
* Legato and glide are shown in the color of the first instrument above, if found.
* Glide/pitch up/down with value 0 when a note and instrument are present is considered an error, because useless.
- Linker: When hovering over a position, the small "+" icon can be right-clicked to clone the position.
- The color of the note and instrument for glide effects and legatos is the same as the above instrument, if any (was previously neutral).
- In some CLI tools, removed the "exportPlayerConfig" which didn't make sense for them.
- Added demo songs from Doclands (thanks!): Pong Cracktro (3 and 6 channels), and Tiny Things (3, 6 channels, PSG or samples versions).
- Players:
* In the Z80 players that use RASM mnemonic REPEAT, added a control to make sure "startingindex" is well set with default (thanks Roudoudou!).
* In AKM and AKY, modified a case problem with one constant, problematic if you used BASM or other case-sensitive assemblers (thanks Krusty!).
- Stream music analyzer:
* Right-click on the previous/next arrows to move faster.
* Click on the progress button to type a specific frame to go to.
* Changed the font below the logo (shown in the splash screen) to the main software font.
* Replacing a sample keeps the amplification ratio.
src/url: https://bitbucket.org/JulienNevo/arkostracker3/
Message Publié : 12 Déc 2025, 07:28
The latest version is 3.5, released on 11/12/2025
3.5 - 11/12/25
Features
  • Added a new command-line tool, Z80 Profiler, to count how many NOPs are spent calling Z80 code. Yep, it can profile music player, or anything else! Check out the online doc for a complete example. Thanks to Krusty for the idea, and Roudoudou for the accurate NOP asm file and log!
  • Added a new frequency viewer, visible when clicking on an icon in the meters view (hover the mouse over to show it).
  • FAP:
    - Generated an asm file along the FAP binary file (called "..._fap_constants.asm"), to include it directly to your production instead of using hardcoded values (buffer size, etc.).
    - Allowed to force a PSG frequency when exporting (also on the command line tool).
    - Added an "Export YM to FAP" option to directly convert any YM to FAP.
    - The SongToFap command line tool can directly have an YM as an input.
    - Clearer report shown on export.
  • YM: SongToYm command line tool can directly have an YM as an input. Useful to convert YM3 into YM6 (...or the opposite)!
  • Source profiles: a "constant declaration" field is added (needed by FAP constants generation).
  • Streamed Music Analyzer:
    - Now plays digidrums! Note that some digidrums may sound different from ST-Sound: the latter does not apply the logarithmic volume of the PSG!
    - Corrected the reading of badly encoded hardware envelope ("Warheads" from Turrican 2 and "Chinese Revolution" from Chambers of Shaolin now plays well).
  • Pasting/duplicating an instrument/expression prompts for a rename (but only if there is one selected item) (thanks Giherem!).
Tweaking
  • Mac: Major UI performance can be done by setting using "OpenGl" in File > Setup > General (else the UI is constantly refreshed for some obscure low-level reason). It is now default on Mac.
  • Added a new demo music, "Aganamemnon" straight from BND#5 party (first place, woohoo!) (original version in the digidrum folder, plus a digidrum-less version).
  • Added ST-Sid music from Doclands (thanks!) (these SIDs can only be played using ggn player on Atari ST, no SID is actually heard in AT3. See the link in the songs comment).
  • Added a music from Ok3anos (thanks!).
  • AKY: Added a tester for MSX (FPGA PSG, 6 channels), with sound effects (PlayerAkyWithSoundEffectTester_FPGAPSG_MSX.asm).
Bugfixes
  • SongToAkg: corrected a regression: crash because of badly handled optional parameters (thanks Krusty!).
  • Pattern Viewer: playing a single line without note would restart the possible arpeggio/pitch.
  • Effect Context: on slower computer, some latency could be heard after entering a note in complex music. This has been optimized.
  • AKG: Corrected a small configuration player bug, which could mess glides up (happens if Glide effect is used without Pitch being ever used) (thanks Giherem!).
  • The amplification ratio for exported samples was not well applied (too harsh).
  • SE: Added "DisarkGenerateExternalLabel" to the "PLY_SE_PlaySoundEffectsStream" label, for SDCC/CPCTelera to be able to see it (thanks SagaDS!).
  • YM export:
    - Corrected a possible crash when exporting samples.
    - Only the used part of the samples are exported.
3.4 - 19/10/25
Features
  • Added a Merge Song option, to add a newly loaded song into the current song, as additional subsongs.
  • Added an Export Songs to TXT. It actually follows the same structure as the AKS XML, with less overhead.
  • Added support for Spectravideo SVI 318/328 for the AKG player (thanks NYYRIKKI!).
  • Added support for PCW (thanks Kachorro!):
    - For the AKG player.
    - For the AKY player.
    - For the AKY MultiPsg (6-channel for the Turbosound).
  • CHP'n'SFX:
    - Added instrument pitch/vibrato from the CHP file.
    - Improved noise and volume management.
    - Corrected some files that couldn't be loaded (thanks Arnaud!).
Tweaking
  • AKY: Added a PLY_AKY_Stop method to stops the sounds, if the PLY_AKY_ADD_STOP_SOUNDS flag is present.
  • Z80 players: adaptation to Rasm 2.3.9 by removing ":" before EQUs.
  • ROM players have their size in the comment of the player (using sound effects increased the buffer size, which wasn't always indicated) (thanks ZXJogv!).
  • Added a choice is the Edit PSG dialog to select MSX frequency (thanks NYYRIKKI!).
  • Added 60 Hz as a radio button in the Subsong Properties (thanks NYYRIKKI!).
  • The behavior of option in the Audio/Midi Setup to add the current octave to all the MIDI input notes has changed: Octave 4 in AT is the reference, and means +0. 3 means -1, 5 means +1, etc.
  • Creating an instrument or an expression opens the related panel.
  • Amsdos headers are skipped when loading .SKS and .128 songs.
  • Added optimizations on export for speed tracks. It may save a few bytes.
Bugfixes
  • AKG and AKM players: Corrected a small player configuration bug when the SFX used hardware sounds, and not the song itself (thanks Arnaud!).
  • The MSX frequency is now 1789773 Hz (thanks NYYRIKKI!). : AKG and AKM players have been updated accordingly.
  • CHP'n'SFX: Corrected some imports which could fail (thanks Arnaud!).
url/src: https://www.julien-nevo.com/arkostracker/release/ ;linked:
Message Publié : 05 Jan 2026, 15:05
The latest version is 3.5.1, released on 05/01/2026:
Tweaking
- Added more effect optimizations when exporting to AKG/AKM. You might save a few bytes and CPU cycles!
- AKM: The first Disark label has been added "Start" to match the first label, just like in the AKG player, and helps CPCTelera refer to it in the same way for both players.
- YM export: Vastly improved the speed of the interleaved YM export.
- Z80 players: removed the RASM test about "startingindex". The REPEAT now explicitly states the start index, so callers don't need to reset it too (thanks Krusty!).
Bugfixes
- Volume in/out was stopped when a legato note was used. This has been corrected, the legato does not stop the effect anymore. The AKG player already did the right behavior!
- AKM export: unknown effects were not correctly handled, possibly leading to crash on hardware. They are now well ignored (thanks Krusty!).
- UI only: on export to binary, the "generate a player configuration for players (as source)" option was disabled, which was not logical. It is now always enabled.
- Undo of Delete Subsong was broken.
- AKY: The Stop method was not reliable on CPC.
info: https://bitbucket.org/JulienNevo/arkost ... angeLog.md
