Beta Release 17.11, 17 November 2017 ==================================== - Fix FDC engine to pass most of Kevin Thacker's New 'acid' tests: - write sector with wrong cylinder; - write sector with bad cylinder; - Fix FDC engine to pass old Kevin Thacker's 'acid' tests for Amstrad CPC 6128 only; - Load disk and tape images inside ZIP from menu; - Update fullscreen dialog windows; - Add AMX Mouse simulation; - Improve support of second joystick; - Add display option to reduce text during pause; - Add dialogs GUI skin customization; - Fix minor bugs.
Beta Release 18.4, 7 April 2018 =============================== - Fix CRTC regression with "Turrican" but involving issues with "iMPdraw"; - Add Audio Speaker and PlayCity Line OUT or Internal option; - Add Audio PlayCity invert channels option; - Fix FDC regression to load "The Real Ghostbusters"; - Add Graphics explorer and Tile editor; - Drop ROM file for testing purposes; - Fix minor bugs.
J'ai l'écran qui reste noir ! Si je fais del j'entends le bruit du curseur qui efface. Faut-il installer des roms ? Comment ? J'ai joint le fichier debug. Merci
Inscription : 26 Nov 2008, 10:04 Message(s) : 174 Localisation : Saint Ouen l'Aumône
Est-ce la première fois que tu lances Caprice ?
Par défaut, la configuration est 6128 UK.
Peux-tu essayer avec OpenGL ? (Option UseOpenGL=1 dans le fichier Caprice.ini). Si cela ne marche pas, peux-tu essayer en GDI ? (Option ForceGDI=1 dans le fichier Caprice.ini)
Beta Release 19.7, 6 July 2019 ============================== - Update overall GUI; - Free CPU resources; - Fix CRTC1 display with "Post Scriptum" demo; - Fix FDC problem when using ProCopy; - Fix 4M RAM addressing issues; - Add files manager for direct operations with Windows; - Fix minor bugs.
Release 20.2, 28 February 2020 ============================== - Add files extension registration; - Add Disk and Tape fast loading feature; - Add ROMDOS D1 disk format support for files management; - Improve split rasters display; - Fix minor bugs.
Release 20.10, 11 October 2020 ============================== - Add Action Replay to filter RAM memory content; - Audio devices list review; - Fix some keyboard issues with CTRL key; - Fix crashes when CSW tape is inserted; - Fix autotype issues in hardware mapping mode; - Improve PPI emulation using Arnold PPI tests; - Improve Input/Output decoder with PPI settings; - Fix minor bugs.
Release 20.7, 14 July 2020 ========================== - Patch Pasmo assembler to accept "EX HL,DE"; - Allow up to 32 upper roms; - Add Memory Editor differences highlighting; - Allow unlimited breakpoints; - Fix crash at joystick removal; - Fix FDC head position after stepping; - Detect AMSDOS header when loading ROM; - Support X-MEM memory expansion; - Fix minor bugs.
Release 20.5, 8 May 2020 ======================== - Adaptation for Win64 platform; - Improve Memory Editor; - Change lightguns and AMX mouse shortcuts; - Add direct shorcut for custom speed turbo; - Add access to main display size zoom factor; - Autotyping at full speed; - Patch Pasmo assembler to accept "OUT (C),0", "SBC N", "ADC N", "ADD N"; - Fix FDC Wrong Cylinder and Bad cylinder flags issue; - Fix minor bugs.
Release 20.3, 25 March 2020 =========================== - Fix some Z80 instructions timings; - Fix color issue when loading snapshot; - Fix minor bugs.
Release 22.4, 1 April 2022 - Improve Amstrad PLUS ASIC emulation; - Update some Z80 instructions behaviours; - Almost all keyboard shortcuts are configurable; - Fix minor bugs.
Release 21.11, 11 November 2021 - Improve FDC Read ID function using accurate timings; - Introduce preliminary support of Amstrad 6128 PLUS model; - Show monitor boundaries; - Fix minor bugs.
Release 21.6, 23 June 2021 - Improve loading of CDT tape files; - Improve CDT conversions; - Add Tape counter; - Support direct binary file load and execution; - Improve CRTC behaviour using Kevin Thacker tests; - Fix multi-origins assembler compilation issue using Pasmo; - Fix minor bugs.
Release 21.4, 1 April 2021 - Add Z80 instructions Trace; - Add CDT converter to CSW and audio WAV; - Improve loading of CDT tape files; - Fix minor bugs.
Release 21.1, 8 January 2021 - Add Multiplay Mouse emulation; - Add cursor capture option to improve mouse emulation; - Support X-Mem SST flash memory; - Add Simple Poke Window; - Fix minor bugs.
Release 20.12, 6 December 2020 - Remove Taskbar to Win32 release to keep compatibility with Windows XP; - Support X-Mass storage peripheral; - Remove X-Mem "Free" button; - Upgrade Graphics Explorer GUI; - Improve breakpoints to filter lower and upper roms; - Speed-up emulator shutdown; - AMX Mouse emulation review; - Add Symbiface Mouse emulation; - Fix minor bugs.
