JavaCPC Desktop is a brand new Amstrad CPC emulator. It is based on JEMU (http://sourceforge.net/projects/jemu) and is an extremely improved release from JavaCPC 6.7.
JavaCPC Desktop is designed to be used on Windows systems only, but maybe can run also on other systems, but a few features will be missing then.
JavaCPC is no freeware any longer! It's new license is "Donationware".
What does this mean? --------------------
- JavaCPC and all of it's contents are free, and are allowed to be shared. - It's available sources are not complete but you are allowed to use them. - If you register JavaCPC, please also think about a little donation. (JavaCPC consumes much time in it's development) - The only legal downloadplace is: http://sourceforge.net/projects/javacpc/ or also http://cpc-live.com - Other people who wants to offer JavaCPC on their own webpages, please contact me under webmaster@cpc-live.com
What is new, what can I expect as a JavaCPC 6.7 user? -----------------------------------------------------
JavaCPC Desktop is a completely rewritten emulator, which offers you a big spectrum of apps and tools. It comes with it's own desktop!
The tools and apps: ------------------- - Integrated Z80 Assembler: Feel free to create your own programs in Z80 Assembler. Compile them directly into the CPC's ram. - Improved Debugger - Virtual Keyboard: You cannot find your key you need? Use the virtual Keyboard then. - Alarm Clock: A simple alarm clock, which reminds you when you have something else to do. - YM-Control: Record and playback your own YM files. - Manage DSK (Windows only!): Copy files from your PC on a DSK or vice versa. - Audio Capture: Record your favourite CPC sound as WAV file. - TapeDrive: A fully controllable virtual tape drive. Supports CSW, CDT, WAV and MP3 - JavaCPC Paint: Paint your own screens in normal mode or also as Overscan pictures. Convert existing images to CPC format. (Supported import-Formats: PCX, TGA, BMP, PNG, GIF, JPG, SNA) - Mandelbrot: A simple app to paint Mandelbrot fractals directly on the CPC screen. - Tiled Mapeditor: You can use it to create game maps etc... - Poke Finder: A simple tool to find PEEKS and POKES to cheat in games. - Calculator: A scientific calculator which understands string input with brackets etc... - WebBrowser: A webbrowser - GameBrowser: Don't waste your time by downloading hundreds of CPC games without checking them! Just load them directly into the emulator and play them. - Virtual Floppy: A little thingie to see what your virtual disc drive does. - SubPopRadio: Listen to the best CPC-tunes available in WWW! - JavaCPC Chat: Chat with other JavaCPC users all over the world. (Experimental) - Favourites: Add and load your favourite DSK, CDT or SNA files with a few mouseclicks only! - DSK2CDT: Simple filetransfer to copy files from an existing DSK file on a new CDT file (Windows only!) - And much more!!!
JavaCPC Desktop correspond a une version complètement réécritre de JavaCPC. Il arrive avec son propre bureau et des applications intégrées. - Intégration d'un assembleur Z80. - Amélioration du débogueur. - Clavier virtuel. - Une horloge qui fournit une alarme. - Un contrôle YM : lecture et enregistrement de vos propres fichiers YM. - Gestionnaire de fichier DSK (Windows uniquement). - Capture du son : enregistrement des sons du CPC dans un fichier WAV. - Lecteur de cassette qui supporte les formats CDT, CSW, WAV et MP3. - JavaCPC Paint : dessinez vos propres écrans dans le mode normal ou dans un mode avec sur-balayafe. Conversion des images dans le format CPC (support des formats PCX, TGA, BMP, PNG, GIF, JPG, SNA). - Mandelbrot : un application qui dessine des fractales de Mandelbrot. - Tiled Mapeditor : créer des cartes pour les jeux... - Poke Finder : outil pour trouver des codes triche PEEKS et POKES. - Une calculatrice. - Un navigateur Intenet. - Un Explorateur pour les jeux : ne perdez pas votre temps à télécharger des centaines de jeux CPC sans rien vérifier. Chargez les simplement directement dans l'émulateur et jouez. - Disquette virtuelle : permet de voir ce que fait votre lecteur de disque virtuel. - SubPopRadio : écoutez les meilleures musiques CPC disponibles sur le WWW. - JavaCPC Chat : discutez avec les autres utilisateurs de JavaCPC (expérimental). - Favoris : ajoutez et chargez vos fichiers DSK, CDT, SNA favoris en quelques clics de souris. - DSK2CDT : transfert de fichier pour copier les fichiers contenus dans un fichier DSK vers un nouveau fichier CDT (Windows uniquement). - ET encore plus.
JavaCPC 1.0b is an additional update. You can install it from JavaCPC's menu: "Help -> Check for updates". What's new? - Java Joystick library added. Should work with your gamepad now. When done, it asks you for the 2 fire-buttons. Press them on your joypad in order. To reset this settings, use menu: "Settings -> Reset Joystickbuttons"
It's important that you have the joystick translation enabled and that you don't use the "Alternative Joystick control".... (This is set properly by default!)
BUG alert! Please (If your JavaCPC still starts up) let it check for updates again! If it quits and you don't know why, run Update.jar (Or put a .bat file with content: "java -jar Update.jar" (without "") into your JavaCPC folder)
Major release to version 1.1! Many bugs (which had not been reported during the beta-phase) were the reason why I decided to release version 1.1 today.
What has changed? - Z80 emulation core improved. MEMPTR register fully emulated now, some small bugs fixed. LDI, LDD fixed. - JavaCPC Paint: Many bugfixes and improvements. - Debugger: MEMPTR register info and IM status added. - YM Player overhauled - JavaCPC Expansion ROM updated - Joystick libraries and joypad emulation added. - Replaced annoying dialog when drag & drop is used to load a DSK - Display improvement for SuperPAL filter (faster now) - Logic bugfixes in emulation core - several smaller bugfixes - PPI bugfix (Storing of SNA fixed and also PPI info in debugger is correct now) Thanks to TFM for finding this bug!
Depuis aujourd'hui le site émule la machine Amstrad CSD (Cartridge Software Demonstrator). Il s'agit d'un appareil de démonstration fourni aux vendeurs pour promouvoir les jeux GX-4000. Son architecture comprenait une carte mère d'un Amstrad CPC 464+ et disposait de 12 emplacements pour enficher autant de cartouches GX-4000.
JavaCPC Desktop 1.5 - La palette est restaurée maintenant lorsque vous charger une capture. - Le chat changement maintenant pour un chat php (le même que sur java.cpc-live.com). - L'affichage 3D accepte maintenant le glisser-déposer. - Gamebrowser update : il affiche les jeux sur java.cpc-live.com (les démos sont également disponibles).
JavaCPC Games : - L'émulateur a changé et devrait démarrer de manière un peu plus fluide. - Ajout de beaucoup de jeux, il y a maintenant 1 000 titres disponibles en ligne. - Amélioration de la fonction de recherche. Possibilité de chercher plusieurs jeux dans une seule recherche, n'oubliez pas de séparer les mots par une virgule. - Les 10 derniers jeux et 10 dernières démos sont affichés en bas de la page d'accueil du site. - Il y a maintenant 13 jeux dans la section highscore.
JavaCPC Desktop 1 Update 6a : - Amélioration de l'assembleur intégré Z80. - Légère modification de l'émulation AY. - Ajout de nouvelles commandes internes create_dsk "a:mydisk.dsk",data,40 -> création d'une image de disque vierge dans le lecteur DF0. Formats disponibles : data, system, 40 ou 80 piste. add_loader "myloader.bas" -> création d'un petit chargeur BASIC pour les fichiers que vous voulez assembler. write direct "a:myfile.bin" -> écrire un programme assemblé en DSK dans le lecteur donné.
JavaCPC Desktop 1.7b - Correction du clavier germanique. - Correction d'un bogue qui désactivait les ROMs lorsque vous activiez le panneau-de-statut. - Correction d'un bogue qui faisait que les ressources externes n'étaient pas copiées dans C:\Users\\JavaCPC de telle sorte que les Apps internes ne fonctionnaient pas.
Attention, la mise à jour actuelle est uniquement disponible via la fonction de mise à jour du programme : - ouvrir JavaCPC - aller dans le menu "Help" -> "Check for Update" et suivre les messages.
1.8 : - Ajout de commandes RSX qui permettent de copier un texte ou d'autre fichier dans l'écran : |TYPE," et |HEXTYPE,""
1.7f : - Ajout d'un système de fichier interne à JavaCPC (activer simplement la "JavaCPC expansion ROM"). - Changement de la gestion des ports pour "JavaCPC expansion ROM" (pour éviter des interférences avec Digiblaster).
1.7e : - Nettoyage du code. - Tous les messages en texte sont directement envoyés via le CPC émulé. - Il n'y a plus de stupide -chars.
1.7d : - Correction : gestion du bit SPARtan dans FutureOS. - Nouveauté : fonction Détacher / Attacher dans le panneau intégré sur le bureau.
JavaCPC v1.9 is ready: - Debugger -> Added a simple BASIC-debugger. - CPC-Screen-To-ASCII feature implemented. (You'll find it in menu -> Edit or by pressing shift+F11)
Because of lacking time and motivation, I decided to roll-out version 2.0a.
What is new? - Built-in "direct font editor" -> you now can edit the system rom's font. (It also opens a user defined font) You can also store modified fonts as headerless binary or into a new lower-OS-ROM file. Press ALT + F11 to open it. (Or check in menu -> Edit -> Open Font Editor) - A wallpaper is set by default now. 4 wallpapers are available now. (1920x1080 pixels) You of course can also set your own wallpaper. - The menubar now also shows up, when desktop is "Expanded"
What has changed? - Several minor bugfixes. - Bugfixes in the internal paint application - Rewritten code to posterize images (Turn your favourite photo/image into a CPC-pixelized image keeping the original proportions) - Internal java console is now turned off by default. (You can still enable/disable it in the preferences)
You can run an update or download 3 different files: - JavaCPC_Desktop_2.0a.zip -> Complete emulator in a ZIP archive - JavaCPC_2.0a_Setup.zip -> Complete emulator as a setup file - JavaCPC_Desktop_Online_Setup.zip -> Only the online installer, put it somewhere you want to install JavaCPC inside, and launch it.
For those of you, who run the update: - When the update runs first time, the updater self-closes. - Launch JavaCPC.exe again then, and a 2nd update starts, which updates the Update.jar itself and also the last required files.
This happens, because in this release, the updater changed, too.
update pour cette version v2.0a
Nouveautés : - Nouvel outil intégré "direct font editor" : possibilité de modifier la police de caractères des roms. - Un fond d'écran est maintenant réglé par défaut. Il y en a 4 de disponibles. Possibilité de mettre votre propre fond d'écran. - Affichage de la barre de menu, lorsque le bureau est "Expanded".
Modifications : - Divers correctifs mineurs. - Correctif dans l'application interne Paint. - Réécriture du code pour postériser les images. - La console interne Java est maintenant coupée par défaut.
