L'avantage du Kryoflux (en RAW, pas en CT-RAW) reste sa meilleure résolution aux extrémités, là ou il est critique de connaitre précisément l’enchaînement des bits, ce que le SCP n'a pas (a mon grand regret !)
Version 3.8.4 (2014-08-26) -------------------------- - Added drive wobble for weak sector extraction from a single revolution - Added warnings for multiple-copy incompatibilities with EDSK format - Added warning is only copy of sector data is truncated at index mark - Added warning if blank tracks are missing from end of EDSK images - Removed lax 8K CRC condition that was masking real data errors - Fixed crash on short sector removal during flux data processing - Fixed multiple copies of fake 8K sectors being kept, bloating images - Fixed MBD images being read in the wrong track order
Version 3.8.7 (2015-03-08) -------------------------- - Added support for Deep Though .DTI images (Jupiter Ace) - Added --ace option to scan for Deep Though encoding in flux images - Added --new-drive option for fast stepping and use of disk-change line - Added License.txt to clarify free usage and lack of warranty - Changed to --old-drive behaviour by default, ignoring BIOS drive type - Changed to use cyl 0 instead of current head position for rpm measurement - Fixed incorrect CHS handling of large BDOS disks (8GB+) - Fixed false-positive on tracks using placeholder 8C 15 CRC - Fixed false-positive where tracks matched both XOR and SUM checksums - Fixed output of single-sided raw images
Version 3.8.8 (2015-07-08) -------------------------- - Added D88 support for 1D and 1DD disk types - Added .1dd output extension for 1D/1DD in D88 container - Added cylinder count detection to D88 image reading - Added support for .2d raw format - Fixed destructor crash bug in gcc builds (Linux and Mac) - Fixed TR-DOS false-positives by requiring .trd extension - Internal code fork from SAMdisk 4, which has now diverged too much
Version 3.8.9 (2016-12-18) -------------------------- - fixed clipping extent of non-error sectors - fixed raw .2d file reading (thanks Tatsuyuki Sato) - fixed HD track error during 2DD to 2HD promotion (thanks Tatsuyuki Sato) - fixed use of scanning data rates not supported by FDC - fixed --offsets crash if 2 stored copies were present - changed gap indicator from g to +, added - for short sectors - added support for double-density MB-02+ disks (thanks Jan Kucera) - added --step-rate speed option (0=slow, 15=fast, 10=default)
Version 3.8.10, last updated 14th May 2017 --------------------------- - added read and write support .qdos (QL) disk images - added --irregular option for blind output image if first track isn't regular - added --fill to set filler byte for regular formats - fixed setting perpendicular mode for 1Mbps data rate - fixed reading directly to single-sided formats from a:/b: - fixed short data indicator showing on no-data sectors - fixed raw output not using source format fill byte for missing sectors - changed raw output to allow blank head 1 to mirror head 0 format
