| [EMU] CPCEPower v2103 https://cpcrulez.fr/forum/viewtopic.php?f=7&t=6486 |
Page 1 sur 1 |
| Auteur : | Megachur [ 19 Mars 2021, 15:59 ] |
| Sujet du message : | [EMU] CPCEPower v2103 |
Nouvelle version v2103 qui inclue ces changements :2021/02 SNA/DRIVE: Fixed a rare bug where track is fixed to a value superior of the max tracks available of the inserted disk SNA: Fixed z80 registers and GA colors index save thanks to Roudoudou ! ARGS: Corrected a bug which disable the loading of a LROM binary file passed with parameters. Z80: Thanks to MadRam experimentations -> Corrected the Flags of F for ini/d(r) and outi/d(r) instructions ! cf https://64nops.wordpress.com/2021/01/13 ... pc-timing/ Z80tests program with ORGAMS last distribution is now 100% accurate ! je poste rapidement la version Windows, MacOS et Pi4 pour dlfrsilver !Pièce jointe : 20210319_CPCEPower_SDL_Release.zip La versions Linux à venir... |
