| [EMU] JOYCE https://cpcrulez.fr/forum/viewtopic.php?f=7&t=5339 |
Page 1 sur 1 |
| Auteur : | hERMOL [ 09 Oct 2014, 20:12 ] |
| Sujet du message : | [EMU] JOYCE |
Pas grand chose en actu émulation en ce moment... a part une update de JOYCE (emulateur PCW sous unix/win32/macosx) Citer : Update History 2014-10-08 : JOYCE v2.2.7 (stable) released. This contains code to guard against the possibility of a malicious CP/M program overwriting or deleting important files on the host computer or crashing JOYCE. If you use JOYCE / ANNE to run CP/M programs downloaded from the Internet, I recommend that you upgrade to this version. 2012-10-24 : JOYCE v2.2.5 (stable) released, with compilation fixes for the latest version of libpng, and a fix for a crash in the native VGA driver. 2010-11-03 : JOYCE v2.2.4 (stable) released. Improvements to keyboard emulation; some compiler warnings removed, and an updated SDL.DLL included with the Windows version. 2010-06-09 : JOYCE v2.2.3 (stable) released. This has a further correction to the configuration script. 2009-11-08 : JOYCE v2.2.2 (stable) released. This corrects some compilation issues on recent Linux systems. url/src: http://www.seasip.info/Unix/Joyce/index.html
| Auteur : | Princesse Mariana [ 05 Déc 2016, 22:02 ] |
| Sujet du message : | Re: [EMU] JOYCE |
Citer : 2016-04-16 : JOYCE v2.2.10 (stable) released: compilation fixes for recent GCC versions. Since these only apply to Linux source builds I haven't done a new Windows pack. 2016-04-16 : JOYCE v2.2.9 (stable) released. This adds emulation of the Electric Studio light pen. src/url: http://www.seasip.info/Unix/Joyce/index.html |
| Auteur : | Princesse Mariana [ 07 Jan 2021, 22:18 ] |
Citer : 2021-01-07 : JOYCE v2.2.14 (stable) released: Fixes autodetection of extended DSK files, display artefacts when colours are changed while video is disabled, and Rosanne checksum detection when the ROM is patched. 2019-06-29 : JOYCE v2.2.13 (stable) released: fixes compilation on recent Unix distributions. Since this only applies to Linux source builds I haven't done a new Windows pack. 2017-07-07 : JOYCE v2.2.12 (stable) released: the default keyboard mapping for the # and \ keys under Windows has been corrected. 2017-02-12 : JOYCE v2.2.11 (stable) released: added a feature allowing up to 13 emulated hard drives in CP/M (rather than 5-6 as in previous versions). Also corrected the build process so LyX is not required. scr/url: http://www.seasip.info/Unix/Joyce/index.html |
| Auteur : | Princesse Mariana [ 06 Août 2021, 10:17 ] |
Citer : 2021-08-05 : JOYCE v2.2.15 (stable) released: Fixes handling of DSK files with unformatted tracks. http://www.seasip.info/Unix/Joyce/index.html |
| Auteur : | Princesse Mariana [ 04 Mars 2023, 18:41 ] |
Citer : 2023-02-19 : JOYCE v2.5.1 (development) and 2.4.1 (stable) released. Fixes for parallel port emulation within ANNE. 2022-08-03 : JOYCE v2.5.0 (development) released. Adds support for running CP/M-86 or CP/M 2 as guest sessions inside PCW CP/M. 2021-12-14 : JOYCE v2.4.0 (stable) released: Fixes an issue where PIP would hang copying 16k-32k files on folders mapped as drives. src/url: http://www.seasip.info/Unix/Joyce/index.html |
| Auteur : | Princesse Mariana [ 12 Mars 2024, 18:51 ] |
Citer : 2024-03-10 : JOYCE v2.5.2 (development) released. Improved LocoLink emulation. 2023-05-21 : JOYCE v2.4.2 (stable) released. Compilation fixes for C++17 compilers. src/url: http://www.seasip.info/Unix/Joyce/index.html |
| Auteur : | Princesse Mariana [ 28 Mars 2026, 08:45 ] |
Citer : 2026-03-26 : JOYCE v2.5.5 (development) released. Dot-matrix and daisywheel printer can now output to PDF files. GSX drivers added for direct output to PNG and PDF files, and accelerated output to the PCW mono display. Fixed an issue with bidirectional matrix printer output going out of alignment. 2025-08-09 : JOYCE v2.5.4 (development) released. Corrected default palette on built-in GSX driver to match GSX documentation. 2024-03-26 : JOYCE v2.5.3 (development) released. PCW-Linkit emulation, ability to use the serial port as a UNIX terminal. url/src: http://www.seasip.info/Unix/Joyce/index.html |
