| It's Halloween and the new JavaCPC v6.7 is ready! https://cpcrulez.fr/forum/viewtopic.php?f=7&t=3913 |
Page 1 sur 1 |
| Auteur : | Devilmarkus [ 31 Oct 2009, 19:59 ] |
| Sujet du message : | It's Halloween and the new JavaCPC v6.7 is ready! |
Hi together, I finished JavaCPC 6.7 just in time. The new JavaCPC version offers the following changes: Citer : - Improved CRTC 0 and cRTC 1 emulation, fully emulates Registers 6 and 8 - New feature: JavaCPC Paint allows to paint normal sized screens, convert JPG, BMP, PNG and GIF on-the-fy into CPC format - Realtime clock (Just for fun, not a real emulated feature, demodisk is included) - Performance observer to avoid low performance / bad synchro - You can dump cpc-ram directly into HEX-Editor now (Read-only, but saveable to PC) - LZH uncompression possible for YM files - improvements for the YM player - Several minor bugfixes - Bugfix in Autotype to avoid shift-key ignores - Changed colour tables for Colour monitor (Linear / Non-linear) New: JavaCPC Paint - A internal application, which allows you to draw directly into CPC-Screen ram! You can also convert BMP, PNG, GIF and JPG images directly into CPC-Format... (Not perfect but works very well, if colours are set bad, adjust brightness a bit) ![]() Download your copy here ![]() Sources are not longer part of the downloads! If you need sources, you'll find the latest sources always on http://sourceforge.net/projects/javacpc into it's SVN repository. Have fun with it and a happy halloween! Markus |
| Auteur : | hERMOL [ 02 Nov 2009, 09:08 ] |
| Sujet du message : | Re: It's Halloween and the new JavaCPC v6.7 is ready! |
Citer : - Amélioration de l'émulation des CRTC 0 et CRTC 1. Emulation complète des registres 6 et 8.
- Nouvelle fonction : JavaCPC Paint reproduit les écrans de taille normale, il convertit à la volée les fichiers JPG, BMP, PNG et GIF dans un format compatible CPC. - Horloge en temps réel (c'est seulement pour le plaisir, disque de démo inclus). - Observateur de performance pour éviter de mauvaises synchronisations et des performances faibles. - Vous pouvez copier la RAM du CPC directement dans un éditeur hexadécimal (en lecture seule, mais peut être enregistré sur le PC). - Décompression LZH possible pour les fichiers YM. - Amélioration du lecteur YM. - Divers correctifs mineurs. |
