CPC Rulez
https://cpcrulez.fr/forum/
Winape v2.0 alpha 17
https://cpcrulez.fr/forum/viewtopic.php?f=7&t=368
Page 1 sur 1
Auteur :  hERMOL [ 05 Sep 2008, 18:33 ]
Sujet du message :  Winape v2.0 alpha 17
Emulation
- Added PAL Emulation display modes.
- Improved anti-aliasing in Half-Size display mode and minor optimisation to palette setting.
- Fixed a bug reading 8K (or larger) sectors from a DSK file when they are stored in the DSK with their actual size.
- Fixed a bug in disc drive sound emulation, initialising with noise when turned off.
Configuration
- Added PAL Emulation option in Display Settings.
Graphics Editor
- Added Rotate Clockwise and Rotate Anti-Clockwise functions, available in the right-click menu.
Other
- Improved sound synchronization for writing of AVI files.
- Changed default behaviour of CPCDOS to only auto-detect file types from files with no AMSDOS header when the LOAD or RUN BASIC commands are used.
- Fixed reporting of bad tracks in DSK images to show the correct track for single-sided images.
- Added the ability to specify an Auto-Type file from the command line. This will execute after BASIC startup. e.g. WinAPE /T:test.atp
- Added a LOAD command to Auto-Type to load a binary file into memory. e.g. ~LOAD filename,#4000~ or ~LOAD filename~
The default directory is the last directory from which an Auto-Type file was read.
- Added the ability to specify a disc image for drive B: from the command line. e.g. WinAPE /B:test.dsk
- Updated the automatic update executable installer (Update.exe) to attempt to stop virus scanners from deleting ot detecting it incorrectly.
url:
http://www.winape.net/
http://www.winape.net/downloads.jsp
Auteur :  BDCIron [ 05 Sep 2008, 19:22 ]
Sujet du message :  Re: Winape v2.0 alpha 17
Ca c'est de l'emulation !!! De pire en pire !!!
Auteur :  BDCIron [ 05 Sep 2008, 22:12 ]
Bon cette fois j'ai envoyé un mail a l'auteur de winape pour qu'il corrige ca...
https://www.phpbb.com/
