Hi All,
Because faster is better, here is another version of GP2X-CAP32 the CPC emulator for GP2X.
For those who haven't seen previous versions, Caprice32 is one of the best emulator of the Amstrad CPC home computer series running on Windows and Unix, written by Ulrich Doewich. This emulator faithfully imitates the CPC464, CPC664, and CPC6128 models (see caprice32 project)
What's new in version 1.4.0 :
- Speed improvements - Add gzipped disk file support, reduce disk file size from 190k to 20k ! (you may gzip original dsk file using http://www.7-zip.org) Of course, gzipped disk files are also browsable using disk explorer inside the emulator, and when possible, they can be run automatically. - A thumbnail image is now displayed in the file requester while selecting any file with the same name of a previously saved game (snapshot, disk, keyboard, settings). It might be very helpful to recognize that game later if you have thousand different games in your disk and snapshot folders ! - The virtual keyboard is now usable in the file requester menu to choose the first letter of the game you search ! - In the emulator menu you can go directly to keyboard and settings menu using the L-Trigger key. - The sound can be set a bit louder
How to use it ? Everything is in the README file.
This package is under GPL Copyright, read COPYING file for more information about it.
Here is a full working binary and source : cap32-v1.4.0-bin.zip
cap32-v1.4.0-src.zip
Special thanks to KaosOverride, Noldor & Notaz,
Thanks to Gryzor you can find here a set of snapshots in snz format.
If you look for disk images you can find most of them here
Want to know which games are good ? here is a good site !
