Nous sommes actuellement le 03 Sep 2026, 18:44
THE AMSTAIR TOOL
 [ 4 message(s) ]
 Sujet du message : THE AMSTAIR TOOL
Message Publié : 20 Avr 2025, 19:05
Totalement révolutionnaire , cette machine été dévoilé lors de la revision 2025 par Raft/TRSi:
A bit of context
As far as I remember I always wanted to have a led display of the Amstrad CPC signals, like on the old skool Altair / Imsai / educational kits... you know, Xmas tree vibes!
But obviously these LEDs would blink too fast to see anything. The CPC had to be slowed down. Since the Wait signal is used by the Gatearray, I had to find another way. The DMA mode was my second choice, although I often read that it was difficult to use on CPC...
As things advanced I really had fun with DMA and it appeared that this little project finally had some usefulness !
So I decided to design a tool based on my experiments, with these guidelines in mind:
  • The gear should look Ooold SKooooool
  • No CPU, only LOGIC components of the CPC era (also because I had quite a lot of these TTL LS chips in my drawers)
  • Have fun!
Tool Features
Beyond its Educational interest, AMSTair offers you a way to Hack your games in real time, Debug code / ports, Diagnostic faulty CPC and much more...
  • Display CPC control lines via LEDs
  • Slow down your Amstrad at chosen speed
  • Freeze mode with step by step functionality : Step on each Clock, DMA access, CPU instruction, port read, port write, Memory access
  • Select the IO port you want to scan
  • Show address lines in binary and data lines in hexadecimal
  • Output the selected data to SOUND (Really?!)
  • Digiblaster compatible mode
  • DMA read or write in each cpu modes : fast, slow, paused
  • DMA can r/w Memory and IO ports
  • Selection of DMA address and data via switchs
  • Selection of Port or Memory address to intercept via switchs
  • Force DMA for dead z80
  • CPC or external power supply
  • Reset Amstrad
This tool is compatible with the Amstrad CPC 464, 646, 6128, 464 Plus and 6128 Plus
https://ftp.untergrund.net/users/raft/c ... r/ams2.jpg
src: https://www.pouet.net/prod.php?which=103951
url: https://ftp.untergrund.net/users/raft/c ... mstair.htm
 Sujet du message : Re: THE AMSTAIR TOOL
Message Publié : 21 Avr 2025, 07:23
Message(s) : 651
Ah oui... c'est à la fois incroyable, utile, une idée originale, pratique pour le déveloveppement, etc. :biere:
norecess464
Message Publié : 21 Avr 2025, 15:47
Message(s) : 262
Hehe, tout comme toi, je suis vraiment impressionné.
Mais j’ai un avis un peu partagé :
- D’un côté, c’est génial ! Cela me fait penser à une version améliorée de la Multiface 2. Le fait de pouvoir lire les registres du CRTC, par exemple, c’est une première (à ma connaissance). Je ne pensais même pas que c’était faisable de cette manière, c’est bluffant. Clairement un vrai bond en avant dans le hardware CPC. J'imagine que l'on pourrait voir quelle ROM ou BANK RAM est sélectionnée, ça aussi ce serait super utile !
- D’un autre côté, j’ai des réserves sur l’ergonomie. Je comprends bien le clin d’œil à l’Altair de 1974, et j’imagine que ça doit rappeler plein de bons souvenirs à l’auteur :) Mais pour une utilisation vraiment pratique, j’aurais préféré une interface permettant de tout visualiser d’un coup d’œil en mode pas à pas, sans avoir à appuyer sur plein de boutons. Un petit écran basique comme ceux des Gotek ou HxC (16 caractères sur 2 lignes) aurait pu faire l’affaire. L’idéal, ce serait une expérience comme sous émulateur avec debugger intégré : tu avances pas à pas dans une instruction, et tu vois immédiatement tout ce qui change.
Bref, voilà mon ressenti : une vraie avancée, qui je l’espère ouvrira la voie à des versions futures abordables et mieux pensées sur le plan ergonomique.
Un grand bravo à l'auteur !
Message Publié : 23 Avr 2025, 16:04
C'est un projet sympa et une curiosité de part son originalité. :)
Après, j'imagine que c'est en gros un NE555 connecté à /BUSREQ. ^^
 [ 4 message(s) ]
