Nous sommes actuellement le 03 Sep 2026, 23:18
Floppy emulateurs USB par Gotek (pas chers)
 [ 13 message(s) ]
 Sujet du message : Floppy emulateurs USB par Gotek (pas chers)
Message Publié : 18 Mars 2014, 20:17
Message(s) : 2107
in spanish :
http://www.cpcwiki.eu/forum/amstrad-cpc ... a-cpc6128/
KaosOverride :
Hi!
I posted already here ;D "3.5 inch USB SSD Floppy Drive Emulator 1.44MB": Could this be a Poor Man's HxC?
Ok, the hack is this: I'm using IBM format, so it's compatible with PC Floppy phisical track format. For the Gotek is like feeding a PC with a Linux or Minix image.
At the video description are links to the tools (My own DSKIMA and CPCDiskXP with IBM hack to 250kb .DSK )
DSKIMA: https://mega.co.nz/#!bQVFzCAL!OH_5ERMYT ... xUSBZ2ZZ3M
CPCDISKXP: CPCMANIA - Amstrad CPC Mania - News
Also, the Gotek drive MUST BE the SFRM72-FU-DL because is the only one which works at DD (720ks) and has READY signal (with a jumper setting)
The DSKIMA (Alpha version, is a quick and dirty program) is the soft I used to convert DSKs to IMG and do first testings with USB floppy drives.
So yes.. I use the Gotek original firmware.
No other models work because they use HD formats (1.44Mb), has to be SFRM72-FU-DL...
And yes, I used the internal connector because is a CPC I have already modded for 3.5" and PARADOS, so the cable is adapted for PC Floppy drive, the power also, and the pity that PARADOS is not IBM format friendly on power on... that's the cause I have to reconfig it each power on...
I also want a CPC DSK firmware, but I don't have the knowing to do one. I have done the trick to survive until a firmware is done
 Sujet du message : Re: Floppy emulateurs USB par Gotek (pas chers)
Message Publié : 19 Mars 2014, 22:20
pas de chance , j'ai un sfrc922
Message Publié : 19 Mars 2014, 23:07
Message(s) : 2107
c'est quoi ?
ah, c'est un autre modèle...
le mien j'ai enlevé l'étiquète pour le démonté dans le passer... erf je vais devoir le redémonter pour voir si je trouve la référence quelque part dedans... si ça veut rire...
merde ou est mon tournevice quand j'en ai besoin...
SFRA619... merd... c'est quoi ça ?
après là Kaosoverride il a pas vraiment hacké la machine... si ça se trouve avec un firmware refait y'a moyen de faire quelque chose mais bon... pas spécialement simple de trouver uelqu'un qui pourrait faire ça...
y'a des docs là :
http://gotek.en.ecplaza.net/
sinon des infos en plus :
I got it from here:
Free Shipping SFRM72 FU DL USB Floppy Drive Emulator Gray-in Floppy Drives from
There is also another source with similar price :
I had no problem with customs at France, nor I had ever at Spain.
Also to mention... My 720k drive was grey, but I swapped the case with the black Gotek I bought for my Amigas
http://www.aliexpress.com/item/Free-Shi ... 23657.html
http://www.aliexpress.com/item/Free-Shi ... 14727.html
No, just plug to the CPC as normal 3.5" drive, with correct DSx jumper (Always DS1 external, or internal with my internal mod of 2 displaced wires. Maybe DS0 with other mods), jumper at READY option as quoted in the PDF at the "drivers" CD, and feed it with 5V, ready for action.
Then you take a FAT16/32 USB drive and make a IMG720 folder, put your *.IMG files and proceed as normal Gotek use with the "image" mode
Image mode:
-- With no USB plugged
-- Press both buttoms (Increase hundreds at display) until you pass 900, so you se b00 (image mode)
-- Use left (tens) or right (units) to select image number ( b00 - b99 )
-- Plug in USB key
-- Press right to MOUNT image ( b03 will mount 003.IMG, etc) (note 1***, see below)
-- Wait while d0 message from display
-- You can unplug the USB, the image is LOADED in the Gotek drive flash memory
(note 1*** --> if you press left button at this moment, the Gotek will SAVE the already flash mounted image to selected number showing d2 message at display)
So you can load for example Art Studio from image 003.IMG, load the program, then load an empty image from other image ( 006.IMG?) save your work and save the image to 007.IMG, 045.IMG or again to 006.img. (You can overwrite images, danger...)
Cholo, maybe the China Post Air Mail saves you from customs :)
Now i'm thinking... the folder is IMG720, so the firmware knows the type of image is working... I will try if my other Gotek is CPC friendly also, so I will have CPC friendly drives for 18€, not 33€ :o
Manufacturer says they're different but ... are chinese :laugh:
il n'a pas tort... en gros il faut au moins essayer...
sur le site de gotek ils mettent bien "1.44meg / 720k"
ils indiquent un modèle pour des clavier de musique avec lecteurs de D7... ils avaient pas forcément du HD 1.44megs... si ?
guyome
Message Publié : 10 Mars 2015, 12:49
Message(s) : 161
Salut les jeunes ! Quelqu'un a des news sur ce fameux Gotek pour CPC ? Surtout l'histoire du Firmware spécialement dédié a nos bécanes ? Ca a bien avancé coté Amiga apparemment ..
Bonne semaine ! :D
Message Publié : 10 Mars 2015, 13:33
Pas de nouvelle...
A ce que je sais, sur Amiga il ne fonctionne pas avec toutes les machines. (exit le CDTV par exemple)
Et comme certains crevards se sont empressés de faire du business avec, je doute que ça ait réellement bougé...
Message Publié : 10 Mars 2015, 15:26
Message(s) : 635
Aux dernieres nouvelles, l'engouement des "crevards" à eu raison de la motivation de l'auteur de la mise à jour du firmware.....dommage car la solution etait/est vraiment abordable pour tout le monde.
Ceci dit, tu peux toujours t'en servir au format 720Ko, ça marche parfaitement.
Message Publié : 10 Mars 2015, 15:50
Message(s) : 2107
c'est quoi l'histoire des crevards svp ?
je suis friand d'anecdotes sur le côté pathétique du genre humain.
en gros l'auteur faisait ça gratos et d'autres ont essayé de faire du bizness à partir de son taf ?
guyome
Message Publié : 10 Mars 2015, 17:37
Message(s) : 161
TotO a écrit :
Pas de nouvelle...
Pourquoi je suis pas etonné mdr !
Ebay en est rempli ! A des prix de folie.. Mais il n'as pas voulu vendre son produit aux revendeurs officiel.. tout de suite les vautours ont tourné autour de la bête.. normal..l’appât du gain pour le retrogaming.. Et encore c'est pas fini..
J’espère pour lui qu'il a déclaré son produit..
Mwouai en 720ko c'est comme une disquette quoi .. le but était quand même de stocker a mort sur une clé USB..
Le HxC reste the must ! Et puis la XMASS !
Jeff_HxC2001
Message Publié : 11 Mars 2015, 07:40
Message(s) : 269
Il n'y a rien d'étonnant à cette histoire, si vous laissez dans la nature vos jouets, voilà ce qui arrive. Et je parle d’expérience avec le début du projet HxC...
Et en plus ces personnes ne voient pas où est le problème... :?
Mais revenons au sujet, car nous préparons quelque-chose autour de ce hardware :
Jeff_HxC2001 a écrit :
Et maintenant nous préparons notre offre "very low end" :
:D
Je prépare en ce moment même les éléments qui permettrons une diffusion propre. (bootloader, maj par la clée USB, etc).
Le device sera disponible dans différentes crémeries à un prix situé autour de 30-40 Euros (prix variable selon le revendeur).
Un service de programmation en ligne sera aussi dispo pour ceux ayant déjà le device. Le prix sera de quelques Euros (non fixé pour le moment mais autour de 8-11e).
Bon j'y retourne :).
viewtopic.php?p=28664#p28664
Message Publié : 11 Mars 2015, 08:51
Bonne nouvelle ! :)
Merci de me contacter par MP pour savoir si je pourrai le mettre sur l'étalage de ma crèmerie.
Message Publié : 11 Mars 2015, 13:48
TotO a écrit :
Bonne nouvelle ! :)
Si c'est le cas, tiens nous au jus. Je passerai surement commande.
Message Publié : 11 Mars 2015, 18:51
Message(s) : 2107
wouai, bin si y'en a pas avant midi, je change de crêmerie...
:D
Message Publié : 12 Mars 2015, 07:39
Bravo Jeff_HxC2001 pour cela, je pense que tu vas faire des heureux !!! :JC_doubleup: :bravo:
J'espère que cela te ferra également un complément de revenu du Hxc original ! :biere:
 [ 13 message(s) ]
