v0.9.12a - LCD/OLED: Long filenames scroll during navigation - LCD/OLED: Make filename scrolling more configurable FF.CFG: {nav,display}-scroll-{rate,pause} - Direct navigation: ".." returns to subfolder position within parent - Fix head-seek settle time emulation - ADF: Generate longer tracks, like a real Amiga would
v0.9.13a - HFE: Emulate non-standard drive speeds (eg. Sony 600 RPM drive) - HFE: Fix single-sector writes (broken since v0.9.8a) - Direct Access: Support up to 64-sector track (Atari ST HxC Mount) - Direct support for Spectrum TR-DOS (TRD) image files
v0.9.14a - Fix write pipeline: record track number for delayed write processing - General Music (GEM): New host option "host=gem" for direct IMG support - Direct support for Spectrum Opus Discovery (OPD) image files - HFE, ADF: Batch writeback to the USB drive where possible - FF.CFG: Replace "index-during-seek" with "index-suppression" - Direct Access: Restart read at correct track position after a write
v0.9.15a - UI: Fix subfolder navigation when returning to parent folder (#66) - OLED: Auto-detect OLED displays at I2C address 0x3d - ST: Mimic TOS by applying track skew to ST image files (#44) - 7-Seg LED: Allow write protection to be toggled as on LCD/OLED - Support Ensoniq DD/HD custom IMG formats (host=ensoniq) - Support IBM PC interface with density select (interface=ibmpc-hdout) - Direct Access: Support track with fewer than 8 data sectors (#62)
v0.9.16a - Support ADFS D/E/F images (suffix *.ADF, FF.CFG: host=acorn) - Direct Access: Fix sector data CRCs - Reliability improvements for Acorn systems (index-suppression=no) - Rearrange floppy read/write buffering to avoid corruptions
v0.9.18a - Fix HxC compatibility mode ("LBA change test failed") - SDU: Improve geometry detection - More bug fixes to read-data ring-buffer handling - LED 888 Display: Show firmware version when right/up button pressed - LCD/OLED: When browsing through images, reset scroll to start of each file
v0.9.19a - USB-DFU firmware file now included! - Amiga: Support high-density disk images ADF: 1760kB images Generate HD-ID pattern on pin 34 (interface=amiga) - DSK: Fixes for Sam Coupe, and others with long tracks
v0.9.20a - New image types supported: IMG: UKNC/DVK (Soviet PDP-11 clones) (host=uknc) IMG/FDI: NEC PC-98 (host=pc98) IMG: Common retro IBM/PC formats work out of the box IMG: Detect disk layout from PC DOS BPB (host=pc-dos) - Auto-extend truncated images (SSD, DSD, TRD images only) "extend-image=no" disables this feature
** v0.9.21a - 11 June 2018 - New default 6x13 font (Codec, by Chris Cannam) - IMG: Support MSX (host=msx) - HxC-Compat File Selectors: - New font on Amiga and Atari ST - Faster folder navigation on Amiga
Inscription : 29 Août 2007, 12:04 Message(s) : 1989 Localisation : seine et marne 77
Nouvelle version v0.9.25a : https://github.com/keirf/FlashFloppy/wiki/Downloads - DSK (Spectrum, CPC, Sam Coupe): Fix pour les pistes avec pas ou peu de données - FF.CFG: Nouvelles options pin02= et pin34= permet une configuration précise de l'interface
Oh bah tiens c'est marrant ça, exactement les même configs que dans le HxC et chaque sous-configurations dans exactement dans le même ordre ! étonnant hasard... Un de plus on va dire...
Il est clair que ce projet là apporte beaucoup en terme d'innovation !
Jeff... Avec tout le respect que je porte à ton travail, tu n'as jamais été en mesure de proposer le support du DSK et il aura fallu attendre ce projet pour que tu l'ajoute en temps record. OK, tu trouves beaucoup de similitudes avec ce que tu fais, mais quand on regarde l'historique sur son GitHub, on note que "les beaucoups de similitudes" datent souvant d'un ou deux jours avant que tu releases... Donc, je me permet de te retourner la question : Utilises-tu aussi son travail pour avancer ? (perso, ça me va)
Sincèrement, je suis contant que ce projet existe car j'utilise tes firmwares et j'ai enfin de quoi me mettre sous la dent.
Sérieux ? ça c'est la meilleure . Quand une fonction est clonée jusqu’à la virgule près, bah c'est un clone. Vous pouvez même comparer le menu en question avec celui du SD HxC. Pourtant il me semble que le firmware du SD HxC date d'il y a fort fort longtemps non ?
Le support dsk sur HxC était disponible largement avant celui de ce firmware il me semble. Il était annoncé quasiment depuis le début, a été développé et testé puis releasé. Bon a priori, comme je m'en doutais, ce n'était vraiment pas urgent au vu du nombre incroyable de retour sur la feature que j'ai eu par la suite ! A moins que j'ai réalisé le support parfait, mais j'en doute )
Il faudrait un peu regarder ce qu'il se passe avant la release : Les firmwares que je fais sont généralement en test sur le forum hxc ou d'autres forums ou encore en privé avant la release. Il y a donc un temps entre les deux. Et pour certaines releases discutés en public, "bizarrement" ça sort chez l'autre avant...
Et tout ce qu'il peut "forker" du projet hxc, il le fait... Il y a avait même carrément des liens vers les binaires HxC sur le domaine hxc2001.com il y a encore peu de temps sur son wiki. Regardez dans l'historique des modifications du github. Et regardez aussi dans l'historique la page principale de ce projet... Et après on vient me dire que je pompe...
Truc "marrant": Les stats d'accès des serveurs HxC montre que j'ai un gros fan depuis 2017 se situant du coté de Londre. Je ne sais pas de qui il s'agit.
Sinon techniquement, même si je voulais, je ne pourrais simplement pas "utiliser son travail" car l'implémentation et les pipelines entre les deux projets sont évidemment complètement différents... Entre autre, le pipeline du firmware HxC à un vrai cache disque et est beaucoup plus optimisé (Une bonne partie est en assembleur). Et je rappelle que le firmware HxC est fonctionnel depuis 2015, sur la base du firmware SD HxC commencé en 2008... ce n'est pas comme si je l'avais commencé après hein ?
Et puis définitivement je n'ai, mais alors, aucun intérêt, ni la nécessité et surtout aucune envie d'utiliser quoique ce soit venant de cette personne !
En bref, jusqu'à présent, de nous deux je ne suis pas celui qui utilise le travail de l'autre... Il y a clairement inversion.
Je t'invite à regarder les discussions du dev du firmware HxC pour une enquête plus approfondie :
Évidement maintenant je suis plus prudent et je limite les discussions "non-privés" sur les futures releases pour éviter de donner des idées à certains...
Merci pour cette réponse détaillée qui permet de mieux comprendre certaines choses. Comme je le disais, j'utilise tes firmwares et suis contant qu'il y ait eu un élan de sorties de nouvelles fonctionnalités.
v0.10 - FF.CFG: Allow up/down inputs to be reversed - Reverse original two buttons (twobutton-action=reverse) - Reverse rotary encoder direction (rotary=reverse) - Modified version numbering scheme and remove alpha status
v0.11 - Detect and report upside-down data ribbon cable - FF.CFG: Configurable OLED brightness/contrast (oled-contrast=) - FF.CFG: Configurable head settle time (head-settle-ms=) - FF.CFG: Fix comma-separated-list parsing (eg. rotary=)
Fin septembre chez "hxc" : http://eab.abime.net/showpost.php?p=127 ... count=1125 <<23 September 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.30.2a - Inversed Floppy Ribbon detection at power-up : "rib" (7 segments display) or "Floppy ribbon reversed !" (LCD/OLed display) message printed at power-up if the floppy ribbon is not connected properly.>>
Et la comparaison du code est troublante... Il y a du reverse dans l'air... Les même signaux et même timeout sont utilisés... Improbable que cela arrive par hasard (en plus du choix du code d'erreur "rib" identique ...).
Game/demo AutoSwap-disks feature No manual disk swapping, at all! Requires patching of host software titles Amiga titles so far (github:keirf/FF_AutoSwap): Beneath a Steel Sky Indiana Jones and the Fate of Atlantis The Secret of Monkey Island Monkey Island 2: LeChuck's Revenge FF.CFG: New OLED display-type sib-option "-narrower" 16-character-wide display (c.w. "-narrow" 18-char-wide) PC98: Direct support for HDM image files HxC Compat: Small fixes to Amiga file selector
