03 December 2017: Firmware STM32 USB HxCFloppyEmulator v3.1.0.4a
Major update !
- New direct file formats support (Read & Write !) : - Acorn machines : *.ADL,*.ADM,*.SSD,*.DSD and *.ADF file support - Camputer Lynx : *.LDF - Commodore C64 : *.D81 - Thomson machines : *.FD - Sam Coupé : *.SAD, *.MGT - MSX Machines : *.IMG, *.DSK - Spectrum : *.TRD, *.SDD
- New menu entry : Target system family selection. This reduce a lot the risk of erroneous raw file identification.
- Lots of RAW file support improvements : All sector sizes supported, advanced track skew and interleaving support. FM & MFM support.
- Amstrad CPC DSK support : Fix for the One Disk/double sided Batman demo.
- Fix attempt of the "diymore.cc" OLED screens : OLED init screen delay menu option added. (Note : Please avoid these "diymore.cc" screens until i got an idea what is the root cause of the issue.)
USB STM32 HxCFloppyEmulator firmware upgrade v3.0.8.2a + Alpha 3.1.1.1a (HFE + HFEv3 + ADF + ST + IMG + (E)DSK file format support)
21 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.1.2a - "Load Last selected image" : Save & Restore previous folder position.
15 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.1.1a - Fix broken Rotary support in normal mode. (Connection points reminder : Clock -> J7 pin 2,Direction -> J7 pin 1)
17 December 2017: Firmware STM32 USB HxCFloppyEmulator v3.1.1.0a - More direct raw formats support : - Akai formats (*.IMG) - Casio FZ1 (*.FZ1) - Emax machines formats (*.IMG) - Ensoniq EPS & Mirage series formats (*.IMG) - General Music formats (*.IMG) - Korg formats (*.IMG) - X68000 (*.HDM,*.XDF) - Internal optimizations.
HxCFloppyEmulator software v2.1.8.0
21 January 2018: HxCFloppyEmulator 2.1.8.0 : - New Loader : Atari ATR file image loader. - New Write & Loader : HFE V3 : variable bitrate and other proctections support. (Experimental ! The file format definition is not yet finished !) - Kryoflux raw files Writer : Fix dead lock with tracks without pulse. - Amiga DOS image browser : 85 tracks AmigaDos image support. - Disk Image browser (FAT & AmigaDOS) : Fix null-sized file import issue. - Disk Image browser (FAT & AmigaDOS) : Can now delete folders. - All image loaders : Fix possible track skew calculation error. - Emax image loader : GAP fixed to 30. - Thomson *.FD loader : Sector interleave set to 7 - Command line tool : -uselayout option can be now used to specify external xml disk layout file.
- New 7 segments config menu 0 (System family) entry :
11 = Ensoniq ASR10 (Ensoniq Auto DD & HD support)
- Some file system & disks access sanity checks added.
13 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.9.1a
- New menu setting interface menu for normal 7-segments Goteks:
-> To access it, remove the USB Stick and press both buttons. -> Choose the sub menu number - wait some seconds for the selection validation. -> Check and/or change the setting - wait some seconds for the selection validation.
The new setting is then saved into the device. Reminder : To clear all settings to the default values, press the right button at power up.
Current Menu and sub selection definition :
Menu 0 - System family selection : 00 = AUTO (DEFAULT) 01 = Amiga 02 = Acorn 03 = Atari ST 04 = IBM PC AT/XT 05 = Camputer Lynx 06 = Commodore 1581 07 = Thomson 08 = x68000 09 = SAMCOUPE 0A = MSX 0B = Spectrum 0C = Akai 0D = Casio 0E = Emax 0F = Ensoniq 10 = General Music 11 = Korg
Menu 1 - Interface mode : 00 = AUTO (DEFAULT) 01 = IBM PC DD 02 = IBM PC HD 03 = ATARI ST DD 04 = ATARI ST HD 05 = AMIGA DD 06 = AMIGA HD 07 = CPC DD 08 = GENERIC SHUGART DD 09 = IBMPC ED 0A = MSX2 DD 0B = C64 DD 0C = EMU SHUGART 0D = S950 DD 0E = S950 HD
Menu 2 - Write protect mode : 00 = AUTO (DEFAULT) 01 = Write protected. 02 = Write enabled.
Menu 3 - Double Step : 00 = AUTO (DEFAULT) 01 = Single step 02 = Double step
Menus 4<->E : Not currently assigned. Menu F - Display firmware version
06 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.8.1a - Raw files : Write sector performance increased. Near Real time sectors write !
05 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.6.0a - Low level Floppy IO optimizations.
04 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.5.1a - Raw *.IMG PC Files : Use the DOS 6.22 disk layouts. - And as always some code optimizations.
02 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.5.0a - Cache flush fix : Do you not reorder the cache when not needed ( e.g when the track fit the cache size ) - CFG File V1 fix (Autoboot mode) : slots support now file images with 2 characters filename extension... - More code Speed optimizations. (again ! )
01 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.4.0a - More Code Speed optimizations. - RAW MFM & FM Images (IMG/ST/...) : - More Write speed improvement : Sector Data cache prefetch.
31 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.3.0a - RAW MFM & FM Images (IMG/ST/...) : - Write speed improvement : - Track cache workflow improvement. - Code optimization (CRC16, MFM 2 BIN...).
29 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.2.0a - *.ST 720KB Files : Switch to the TOS 1.62 Disk Layout. - RAW files loader : Internal enhancement.
27 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.1.4a - Config file "Load last loaded floppy" flag is now supported in indexed and file selector mode.
27 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.1.3a - Normal mode Fix : ST files are visible again !
15 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.18.1a
- Normal mode : Remove unwanted key delay when entering in direct mode.
17 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.20.1a
- USB Direct Access mode code refactored : - Read/write performance increased (hxcmount). - Command/Write indications printed on the LCD.
- USB access cache : Write timeout value set to 2 seconds.
18 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.21.1a
- Indexed mode : Ignore file extension. You can now use any file extension as long as the file is supported by the floppy emulation engine. (Can be DSKA0000.HFE/IMG/DSK/ADF/ADL...)
- Acorn machines (*.ADL, *.ADM, *.ADF): Sectors gap, interleave and tracks skew aligned to the real machine.
19 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.21.2a
- USB Direct Access mode code : Index gap increased (Amiga File selector & HxC copy utility under WB fix)
1 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.1a
- TI99/4A : Direct support of *.DSK/*.PC99/*.V9T9 sectors dump images SD/DD/HD density support (Read & Write).
- New embedded menu entry : You can now force the user interface mode (Normal/Indexed or selector mode selection).
28 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.6a
- HFE files : Fix MPC60 MkII formatted images write support regression. May also fix possible write issues on HFE files with some others machines/disk formats. Update recommended.
27 May 2018: HxCFloppyEmulator 2.1.11.1 - Hard-sectored H8D Heathkit raw file Loader & Writer added !
24 May 2018: HxCFloppyEmulator 2.1.10.1 - Kryoflux Stream Loader (*XX.X.raw) & Stream analyzer : Hard-sectored images support and various fixes ! - Kryoflux Stream Loader (*XX.X.raw) : bmpexport.txt config file to generate the full stream track graph. - NSI Northstar raw file Loader & Writer added !
12 May 2018: HxCFloppyEmulator 2.1.9.3 - Kryoflux Stream Loader (*XX.X.raw) : Another fix for the index position ! - Kryoflux Stream Loader (*XX.X.raw) : filter.txt config file to adjust the internal bitrate filter. - Flux Stream Analyzer : Internal filter can now be set. - ADF Writer : Amiga ADF HD file (22 Sectors/track) support added.
11 April 2018: HxCFloppyEmulator 2.1.9.2 - Kryoflux Stream Loader (*XX.X.raw) : Loader & writer index position fixed.
2 May 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.23.1a - 7 segments Gotek : New menu entry : 5 -> Auto select delay setting. - Floppy Interface initialized before the screen. (Fix Emu Emulator second drive detection issue). - Amiga ID support enabled by default (HD ADF support).
31 July 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.28.1a ( -> In the "Next_WIP_Alpha_Firmware_And_Tools" Folder !) - Files Browser : All Files/Folders with the hidden attribut set are not shown anymore... (Hide Windows/MAC system folders)
30 July 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.27.1a ( -> In the "Next_WIP_Alpha_Firmware_And_Tools" Folder !) - Push buttons Auto-repeat : Better/Smoother rate changes. Rate changes delays adjusted.
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 31 invité(s)
