| [CROSSDEV] PASMO https://cpcrulez.fr/forum/viewtopic.php?f=4&t=6492 |
Page 1 sur 1 |
| Auteur : | Princesse Mariana [ 29 Mars 2021, 19:50 ] |
| Sujet du message : | [CROSSDEV] PASMO |
Citer : Pasmo is a Z80 cross assembler, written in standard C++ that compiles easily in multiple platforms. Actually can generate object code in the following formats: raw binary, Intel HEX, PRL for CP/M Plus RSX, Plus3Dos (Spectrum +3 disk), TAP, TZX and CDT (Spectrum and Amstrad CPC emulators tape images), AmsDos (Amstrad CPC disk) and MSX (for use with BLOAD from disk in Basic). Starting with version 0.5.0, can also generate 8086 code from Z80 sources, in binary format for Ms-dos COM files or in CP/M 86 CMD format. Last updated: 26-mar-2021 v0.5.4.beta2 : This version add third pass option (--pass3), phase error detection in cases where a EQUated symbol changes value between passes, and automatic switch to third pass in that case. v0.5.3 : In the previous version several error gives a 0 exit status. This versions fixes it. v0.5.2 : Added a warning when the 64 KiB limit is crossed in the middle of a instruction, all warnings now show line information, some changes to allow use of more compilers, gcc 4 in particular (thanks to the Debian people). src/url: http://pasmo.speccy.org/ |
| Auteur : | Princesse Mariana [ 09 Mars 2022, 13:48 ] |
| Sujet du message : | Re: [CROSSDEV] PASMO |
Citer : Version 0.5.5 : New directives IFDEF and IFNDEF. New emit options --sdrel for SDCC .rel files and --trs for TRS-80 cmd files. A lot of code cleaning and reformating. Some bug fixes. Test suite: use make check. url/src: https://pasmo.speccy.org/ |
