Nous sommes actuellement le 21 Août 2026, 17:18
OUT(Dated) sources package
 Sujet du message : OUT(Dated) sources package
Message Publié : 03 Juil 2008, 20:42
OUT(Dated)
These sources are published as-is, for educational purpose. I've added some comments here and there along the source to let you know what is going on. Everything has been made with WinAPE (I'm using some of it's assembler directives to assemble in the extra 64Kb RAM of a 6128 amongs others things).
Files description
These are the files you will find in the archive:
gfx/ : In this folder you'll find the graphics used in the intro in PNG format.
C2.E8C0.BIN : This is the music (a compiled STarKos tune).
skoh.asm : the main source garbage code :)
skoh-init.sna : SNApshot of the CPC with preloaded data in RAM and the BASIC proggy to generate the sinus curves.
skoh.picture.8000.asm : part 1/2 of the 32kb picture as DEFB sourcecode.
skoh.picture.C000.asm : part 2/2
skoh.scrolltext.asm : This is the font-bitmap, char-map and encoded scrolltext.
winape-outdated.asm : just a wrapper for winape (Because I do not edit my sources codes with the WinAPE's editor).
How to Compile with WinAPE
Configure your WinAPE for a 6128Plus with CRTC 3 and Plus feature enabled.
Load the skoh-init.sna SNApshot (press F5)
Open the source editor (F3) then File/Open winape-outdated.asm
Compile and Run (F9)
And the whole thing should start. Enjoy :)
sources/outdated.txt - Last modified: 2008/07/03 14:12 by grim
url: http://semilanceata.cpcscene.com/prods.htm
http://www.grimware.org/doku.php/sources/outdated
