20190326: modified vibrato and glissando parameters so they can reach even deeper extremes. Many songs need edits to fit the new values: old 1XF is equal to new 1XD. Added ASHTRAY.CHP, MYSTICAL.CHP, THINGSPR.CHP and ZYNAPS.CHP, merged RTS-25-51HZ.CHP into RTS-1998-9.CHP. 20190210: minor source cleanup. Removed optimisation from CPC player: it struck the tape relay. Added AMAUROTE-L.CHP, ARKA1C64.CHP, COBRAC64.CHP, E-MOTION.CHP, GAUNTLET.CHP, KILLRING.CHP, MICROMUS.CHP, PLATOON0-4.CHP, TOUR91.CHP and VIKINGS.CHP.
20190731 -- 30th public release. The tracker is GPL, the player is LGPL. Upgraded GCC to 5.1.0. New slow glissandos with 1X0 and 1X8: frequency rises (0) or falls (8) 1 unit on every X steps, unlike fast glissandos (10X) where frequency rises (X between 1 and 7) or falls (X between 9 and F) units on every single step. Added ALEHOP.CHP, ARCYESOD.CHP, BLOODBRS.CHP, BOUNDER.CHP, COLT36.CHP, FUTUREKN.CHP, MADDOG.CHP, MENACE-1-3.CHP, NAVYSLS1-7.CHP, PACLAND0-4.CHP, PYJAMA.CHP, RUNGAUNT.CHP, SANXION1-2.CHP, TEMPTATN.CHP, THMT1.CHP and TRIVIALP.CHP. 20190430 -- minor patch fixing a typo in CHIPNSFX.TXT ("LD B,$F6C0" had to be "LD BC,$F6C0") and adding basic sanity checks to song loading. Added ASPHALT.CHP, CAVEMANI-J.CHP, DIZZYDTR.CHP, DIZZYPYF.CHP, MOONTORC.CHP, STARWARS.CHP and SUPERKID-F.CHP.
20200331 -- 31th public release. New flag PREBUILT (+256) to allow compiling just the chip_play routine and rely on a predefined chipnsfx_bss table for softwares with just one song and no sound effects. Reduced mixer+noise clobbering in the player and added more sanity checks in the tracker, such as avoiding storing useless instrument data on portamentos. Added BURNRUB1-5.CHP, COMICBKR-U.CHP, DRDESTRU.CHP, DRUIDRMX.CHP, FINDKEEP-Q.CHP, FLUFF1-2.CHP, FROGALOT.CHP, KENDOWAR.CHP, KNIGHTYM-N.CHP, OPGUNSHP-Q.CHP, RICKDG1A-G.CHP, RICKDG2A-H.CHP, ROADBLST.CHP, ROBOCOP4.CHP, SILKWORM.CHP, SPELLBND-E.CHP, STEG1-2.CHP, STORMBRI-J.CHP, SUBWAYVG.CHP, SUPWBOY1-2.CHP and TINTINLN.CHP: 679 songs! 20191003 -- minor patch fixing a bug where Control-G could "shift" the portamento instrument down, and another one where songs that looped on empty patterns could forget to store the right instrument data after the loop. Added BOULDASH.CHP, DDRAGON0-2.CHP, MACH3.CHP, MASTUNIV.CHP, MONTYRUO-P.CHP, RACETIME.CHP and RLSTUNTX.CHP.
20200430 -- minor patch adding the option -L that generates a song header named after the -l label and allows generating fully self-contained song data files. Added FOLLIN2B.CHP, FOLLINOX.CHP, MADBALLS.CHP, STARDUSU.CHP and TYPHOON.CHP.
20200621 -- minor patch fixing a bug where a channel defined as X1+NN ... Xn+NN X1+NN ... Xn+NN X1+MM ... Xn+MM X1+MM ... Xn+MM became X1+NN X1+MM in the target. New experimental flag AMPL.CACHE (+512) that provides a minor speed boost in the player at the expense of requiring more memory. Added BIRDIE.CHP, KENDOWAS.CHP, MATAHARI.CHP, NITESHFT.CHP, RAMPARTS-V.CHP, RYGAS-U.CHP, SIMPSONS.CHP, STIFFLIP-Q.CHP, TRAPDOOR.CHP and TRIGGER.CHP: 700 songs!
20201115 -- minor patch fixing a bug in the file dialog sorting reported by Adrián: the sorting forgot to shuffle the filesizes together with the filenames. Added JSW64-RH.CHP and RASPUTIN.CHP. 20201109 -- minor patch allowing defining the filename "-" as the standard input (song source) or the standard output (INCLUDE target), adding small tweaks on the display (show 100..127 as A0..C7 on the leftmost column to keep everything aligned) and the player. Added DESPOTIK.CHP, FLINTSTN-O.CHP, FORMULA1.CHP, FORMULE.CHP, GILBERTE.CHP, GPSIM64A.CHP, GPSIMCPC-E.CHP, GPX750CC.CHP, HUNCHADV.CHP, KETTLE.CHP, MECHANIC-E.CHP, NEVEREND.CHP, PHNTMCLB.CHP, POWERPLZ.CHP, THRUSTST.CHP and TUBARUBA.CHP.
20210127 -- 32nd public release. Major rewrite: CHIPNSFX can be compiled with SDL2 ("gcc -O2 -DSDL2 -xc chipnsfx.c -lSDL2 -ochipnsfx") in other platforms than Windows. Added HEROBOTX.CHP, HISTEEL3.CHP, IKPLUS.CHP and TWINTUV8.CHP.
CNGSOFT est de retour avec une nouvelle version de CHIPNSFX :
20210418 -- minor patch fixing a bug in the WaveOut timer and a glitch when testing instruments: sound must play even if channels are disabled. Pressing Control-U on the instrument panel removes unused instruments. Added M_U_L_F-G_.CHP, OUTWORLD.CHP, PULSOIDS.CHP and PULSOIDZ.CHP. 20210129 -- minor patch restoring the filesize field in the file dialog, lost in version 20210127.
20220113 -- minor patch fixing a bug in the song loader (reported by ZJoyKiLer) and warnings in the YM3B and WAVE savers and the user interface. Added HUNCHMUZ.CHP. 20211119 -- minor patch adding the command line option `-!` to extend the buffer length on execution time (compare with the compile time parameter `-DSDL2_DOUBLE_QUEUE`), as well as mouse support (partial on Win32, full on SDL2). 20211113 -- minor patch adding minimal UTF-8 support to the SDL2 interface on non-Windows systems and tweaking the player's stable vibratos fix. Added DESPERA0.CHP and FOXBACK1-4.CHP. 20210626 -- minor patch making vibratos fully stable even in fringe cases reported by Adrián, and reworking the +512 experimental flag into a read-only mode where the player exclusively relies on the chipnsfx_bss buffer, instead of using self-modifying operations, also following an idea from Adrián. 20210526 -- minor patch adding a new noise effect (digits "7F" in the tracker) that toggles the noise wave into a crunch-like sound. The standard player code is now 838 bytes long. 20210522 -- minor patch fine-tuning Control-U so it just scans the patterns, tracks and scores for duplicates, and only performs cleanups (merging identical patterns, removing unused instruments, sorting the scores) if Shift is pressed. Added SHARRIR4.CHP. 20210421 -- minor patch enabling an experimental flanging effect (digits "108" in the tracker): the standard player code grows slightly heavier (832 bytes).
20220915 -- minor patch optimising the player's BUILTIN mode, where the internal functions 7, 9 and B are never used and can be thus safely removed, and removing the obsolete ABRIDGED mode; its place is now occupied by SONG-ONLY, that removes functions 7, 9 and B as well. The tracker's file dialog can warn the user against accidental overwrites. The SDL2 version shows the program icon on the window caption. 20220806 -- minor patch fine-tuning the SDL2 buffer size and the main loop delay (suggested by Kawe). Added BOMBUZAL.CHP and BURNINR5.CHP.
20221231 -- minor patch fixing a bug in the file dialog after loading a song from the commandline and trying to save it back, and removing the now useless option `-k STR`. Added DEVIANTS.CHIP and SPIKYHAR.CHP. Happy new year 2023! 20221212 -- minor patch improving and documenting a SDL2-only key, Control-J: it sets the text style to normal, bold, italic or thin. Similarly, the command line options '-$', '-$$' and '-$$$' set the text style. Added CHASEHQ1-2.CHP, I3TENIS1-2.CHP, LWTENNIS.CHP, RASPUTIH.CHP and TIMEMACH.CHP: 750 songs! 20221121 -- minor patch improving the player's dual mode noise mixer, fixing sound bugs in "Dire Dare". 20221030 -- minor patch redrawing the icon and ensuring that it looks the same on Win32 and SDL2. Added MOTOS1-3.CHP.
20230730 -- minor patch removing the confirmation prompt in the SDL2 version when closing the window on an unmodified song. Added FUNKYMUS-T.CHP, GHOSTCPC.CHP, GHOSTMSX.CHP, MASK4-5.CHP, PIPPOLS0-5.CHP and ROLLRON1-4.CHP. 20230216 -- minor patch adding drag-and-drop to the SDL2 version: the tracker will load songs dragged into the window. The command line options `-Q`, `-QQ`... apply to WAVE output only; the tracker always assumes `-Q`. Added AFTEROID.CHP, DIPDIP.CHP, HUMPHREY.CHP and LIVISTN0.CHP.
20240224 -- minor patch improving non-Win32 compatibility ('realpath' behaves differently in Alpine Linux because it's built upon MUSL instead of GLIBC) and adding a new size optimisation from Jean-Marie. Added COCOATM0-1.CHP. 20240119 -- minor patch fixing several warnings and a potential error in 64-bit systems in the tracker, and adding a 2-byte size optimisation devised by Jean-Marie to the player's read-only mode. Added BUBBLEMX.CHP, BUBBLEST.CHP, BOULDSHR.CHP, MONACOGP.CHP and TRAFFIC.CHP: 777 songs!
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 47 invité(s)
