| Yarkon Blues 1 https://cpcrulez.fr/forum/viewtopic.php?f=10&t=5719 |
Page 1 sur 1 |
| Auteur : | Princesse Mariana [ 24 Mai 2016, 19:15 ] |
| Sujet du message : | Yarkon Blues 1 |
Yarkon Blues 1 When you’re playing an adventure, you can often get stuck trying to find the right verbs or adverbs to type in - should you 'enter' or 'go in? Don't panic - the following list should help you with any synonym problems you might be having in Yarkon Blues, attach , author , bend , break, catch, change, climb, close, cross, cut, dig ,drink , drop, eat , empty, enter, examine, exchange, feed , fill , fire , get , give, hit , hold, hook, in , insert , into , inventory , jump, kick, light, look, make , melt , move, no, offer, open , panic, pay , pick up, play, press, pull, push , put , read , say , sell , shoot , shout, shut, smash, swim, swing, talk , teleport, throw, tie , to , toss, unlight , unlock , wait , yes. You'd also find it mighty usefull to use 'in' directly in front of other verbs. Give it a try. |
