CPC Rulez
https://cpcrulez.fr/forum/
SWITCHBLADE
https://cpcrulez.fr/forum/viewtopic.php?f=10&t=2755
Page 1 sur 1
Auteur :  Princesse Mariana [ 08 Jan 2009, 20:27 ]
Sujet du message :  SWITCHBLADE
Pour avoir des vies infinies, remplacez les octets 21 4F 0A 7E D6 01 par 21 4F 0A 7E D6 00.(Carine & Nicolas)
Pour avoir des vies infinies, faites POKE &30AC,0.(Carine & Nicolas)
Pour avoir des vies infinies, recherchez les octets D6 01 27 77 et remplacez le 01 par 00. (MAX)
Auteur :  Princesse Mariana [ 10 Jan 2009, 10:49 ]
Sujet du message :  Re: SWITCHBLADE
10 REM  Switch Blade
20 REM       by
30 REM Stephen Troup.
40 ùTAPE:MEMORY &13FF
50 LOAD"!loader  .bin"
60 a=&9F00
70 READ b$:IF b$="ST" THEN CALL &9F00
80 POKE a,VAL("&"+b$)
90 a=a+1:GOTO 70
100 DATA 21,09,9f,22,a6,9c
110 DATA c3,40,9c
120 REM Infinite Lives.
130 DATA af,32,ac,30
140 REM Infinite Weaponry.
150 DATA af,32,2b,25
160 REM Infinite Energy.
170 DATA 3e,c9,32,73,30
180 REM Monsters die when they appear.
190 DATA 21,18,0a,22,38,3d
200 REM Invulnerability.
210 DATA 3e,34,32,b3,23,32,02,1e
220 DATA 32,ce,2f,3e,48,32,0f,95
230 REM Leave last line.
240 DATA c3,80,c1,ST
Auteur :  hERMOL [ 04 Jan 2010, 09:51 ]
CHEAT: Remember some time ago we had a cheat for the cartridge version of Switchblade? Well Adam Noble has supplied a keypress for the tape (and presumably disk also) version of the game, and what do you know ifs almost the same! Get a high score and enter your name as SLEEPY then press the number of the level you want to go to, and keep it down, then press Fire to start - you will start half way your chosen level.
https://www.phpbb.com/
