HINTS and TIPS: These are not a complete solution to the Adventure, but they should help anyone totally baffled by the Adventure.
The first problem is getting into the temple.
ROOM OBJECT USED IN Jungle clearing Branch Temple steps
KEY WORDS Remove leaves Get stick South Break latch Use stick Climb steps Use rock Go through door
SACRIFICIAL CHAMBER MAGIC BLANKET FIRE ROOM Store room Key Panelled room Rock room Match Fire room Painted corridor Chisel Remove magic ring from flint Small room Ladder
At POOL SIDE: Climb on board Boat, row in direction: S - Robe Room W - Priest Rest Room E - Fire Room
In FIRE ROOM: Smother flames with magic blanket, light lamp, get magic ring. FIRE ROOM: Magic ring - Get through porthole in sand dungeon. FORGOTTEN ROOM: Blue stone - Get through porthole in sand dungeon. SACRED STORE ROOM: Red stone - Get main treasure. ARMOURY: Rope - Climb out of sand dungeon. In The Maze: NSEW - EMPEROR'S THRONE ROOM SNWE - MIRROR ROOM NSWE - TRAITORS' HALL
