Nous sommes actuellement le 09 Mars 2026, 19:32
TOTAL ECLIPSE 2: THE SPHINX JINX
 Sujet du message : TOTAL ECLIPSE 2: THE SPHINX JINX
Message Publié : 04 Jan 2010, 09:26
En ligne
Complete solution - part 2
Start: You start your quest outside three pyramids on Sahara - C. Make your way around to the back of the closest pyramid, there you will find a small building with a door. Go through the door and you will arrive at Entrance - A.
In front of you, you will see an arrow pointing downwards. Walk forward and climb down some steps to reveal 3 doorways. Go through the right hand door, and enter Selquet-A.
Take a step forward and turn 45 degrees to the right, look down and you will see some steps, climb down. In the room are several blocks, a bar of gold and a trough of water. Fill your flask, turn towards the blocks and shoot, they will disappear revealing a door. U-turn (U) and you will see another door, go through this and you will arrive at Sphinx - X, this is the room where the Sphinx will re-assemble. On the wall to the north is an Ankh, collect it, and go through the door in the eastern wall, you will arrive in Thebes - H.
On the wall to the east is a block, shoot it and it will rise up to reveal a door. Go through the door and arrive at Thebes - G. You are faced by 2 statues, (by shooting at the noses you will prevent them shooting you, but this will have to repeated each time you enter the room). Turn to face the south and you will see some steps. Climb these and go through the door nearest the north wall, you re-enter Thebes - G.
Go down the steps, shoot the statues, go through the door in between and arrive at Thebes - F. Turn to the south and walk to the south wall, turn to the east and walk forward, then collect the bar of gold that lies in front of the locked door. Walk into the door to unlock it, and enter the Jinx section.
Room 1 - Jinx E: Shoot the first barrier (it will disappear), shoot the second barrier (it will raise) change height (H) and crawl under. Go through the door.
Room 2 - Jinx D: Walk into the first barrier (it will fall over), walk over it. You will see another barrier with two symbols on the walls beside it, shoot the symbols and then shoot the barrier (the barrier should disappear - if not repeat the process). Quickly walk through the door.
Room 3 - Jinx C: Shoot the cube in front of the barrier (the barrier will move forward), walk up to the barrier, U-turn and shoot the cube again (The barrier will return to its original position). Walk into the barrier (you will hear a noise) U-turn and you will see a door has appeared, go through.
Room 4 - Jinx B: Walk up to the barrier, U-turn (a cube will have appeared), stand on the cube (the wall will disappear). Quickly go up to the second barrier and shoot it (it will grow to reach the ceiling). Walk right up to the barrier, change height and crawl backwards until the bottom half of the barrier disappears. Rotate yourself through ninety degrees, crawl to the left wall, rotate yourself back so that you are facing the wall. Change angle (A) to the smallest available and rotate yourself once to the left. You should be facing the wall, but also be able to see the barrier. Crawl forwards moving into the wall but also under the barrier. When completely under change height and go through the door.
Room 5 - Jinx A: Walk forwards a few steps and U-turn. Next to the door you will see the Sphinx's lips. Change height and collect them. Change height once again and U-turn, you should see the Ankh on the far wall, go and collect it Rotate yourself so that you are facing the two blocks. Stand in between them, face the wall you collected the ankh from and change height. Shoot the lower part of the block, and part of it will disappear revealing a tunnel. Crawl through it and you will appear back at the re-building room, Sphinx - X. Now is a good time to save your position.
Go from Sphinx - X through the door facing south to Entrance - A then to Selquet - H as before. If you are short of water fill your flask from the trough, then go through the door to the west, you re now in Selquet - G.
You are facing some steps; to the left of them is a part of the Sphinx, collect it. Go behind the steps and through the door, you will arrive in Selquet - F.
There are some steps on the north wall; climb them and go through the door at the top into Selquet - E.
You are standing on an "L" shaped ledge; walk along and fall off at the north wall. U-turn and you will see a barrier in the middle of the room. Walk to the west wall and then turn to face south, you will see that the barrier doesn't stretch right the way across the room. Walk through the gap and collect the Ankh and the Sphinx part on the far side. Go back through the gap climb the steps, walk into the door to unlock it then enter Selquet - D. This is one of the two rooms with teleporters, but don't tele-port yet! First go through the door ahead that leads to Selquet-C.
An Ankh is on the floor in the middle of the room, there is also a Sphinx part and water trough, get the Ankh and the Sphinx part, then fill up with water, but do it quickly as there is a laser in the ceiling that will shoot you. Go to Selquet - E and use the teleporter.
You arrive in Thebes - D. Climb down from the teleporter and walk north, you will trip over a small step on the ground which will cause you to spill about half your water. There is nothing you can do about it but if you topped up your supply in Selquet - C you should have enough to last.
You will see a door at the top of the north wall; a small inverted pyramid is on the floor to its right. Position yourself below the door, away from the waH. then shoot the pyramid and some steps will appear. Quickly go up the steps and through the door mto Thebes - C.
Walk forwards and through the door on the far wall into Thebes - B. This is the invisible wall room - save your position here (you'll need it!).
Yep, you've guessed it the invisible wall room is a real stinker. It's really an invisible wall maze with invisible steps! You have to climb the invisible steps and walk along the top of the invisible walls which eventually lead you to the door at the other end. Its best to map out the position of the walls on some graph paper. In there somewhere you will stumble on a gunshot type noise; crawl when you hear this.
Moving swiftly along, you should now arrive at Thebes - A (or destroyed the tape forever!). Fill your flask with water and get first aid for your aching head, and get the Sphinx part.
Return to Thebes - B and save your position. Getting out is considerably easier than getting - C.
Go to the east wall, face south and walk forwards, you will climb invisible steps and fall the other side. Climb the visible steps and exit to Thebes - C. Go to the west wall, just behind the Sphinx part and face south, you should be able to see a door, if not, walk backwards until you can. Turn yourself slightly to the right and walk into the wall (same method as used in Jinx - B) you should get to the door without it The being covered, to arrive in Behbet - D.
You are standing on a ledge; on the wall beside you is an Ankh; collect it. DO NOT unlock the door to the west, srnipiy drop off the ledge and go through the unlocked door to Behbet - C. To avoid getting hit by lasers walk around the perimeter of the room rather than straight across. GO through the door into Osiris - D. Look up to the ceiling you will see a block, shoot it and it will disappear. Now go through the door to the west and enter Behbet - B.
Keep going west through the next door to Behbet - A. keep on through the next door to Selquet - C, but hurry, the ceiling is coming down on you!
You are now back in Selquet - C , fill up with water if you need to and go back to Selquet - D. Use the teleport to Thebes - B. this time stand on the block facing south and go through the small hole leading to Thebes - E. Collect the Sphinx part and go to the far door, walk into it, unlock and enter Thebes - F.
From Thebes - F make you way back out to Sahara - C by going through Thebes - G up the steps to Thebes - H. Duck and crawl under the block to Entrance - A then up the steps to Sahara - C.
Make your way around the pyramids until you find a hole in the sand. Save your position, drop through the hole and you will have arrived in Osiris - D. Go up the steps and through the door, you are now in OSIRIS-E.
Collect the three Ankhs and return to Osiris -D. Go down the steps and up to the locked door, but don't open it, duck down and you will be able to crawl under the bar. You arrive at Osiris - C. Don't walk on the coloured carpet where the gold is, ignore it, and go through the door at floor level to Osiris -B. Collect the Sphinx part lying on the floor, go back through the door, up the steps and through the other door to get onto the ledge. You should have 5 Ankhs (3 from Osiris - E, one from Behbet - D and one from Selquet - C), If you haven't then you're stuck! (restart from saved position). If you do have 5 walk forwards into the floating blocks, keep walking and they will fall down to create a bridge, collect the Sphinx part and go back to Osiris - C and save your position.
You should now have 10 pieces of the Sphinx, if your heart rate is high go around the ledge and drop down onto the first aid oox to slow it down.
Go up the steps to Osiris - E, drop over the ledge. U-turn and you will see an Ankh, collect it. Then go up the steps to the south and duck down. When the door opens fully go through it, you will be in Osiris - F. Collect the Sphinx part and drop over the catwalk, go through the door and you are in Sphinx - X.
Make your way to Selquet - C, go up the steps, walk into the door to unlock it and enter Selquet - B the floating block room.
The floating blocks:- follow these instructions to make your way across. Its a good idea to save your position after every stage in case you have a fatal fall.
1) Shoot the 2nd block, shoot the 3rd block (when it appears) leave the room and come back.
2) Go to the 6th block, you have to be very quick Over the 3rd block as it disappears and re-appears every 10 seconds.
3) Go across to the 11th block, once again you have to be quick across the 7th and 8th blocks as they keep vanishing.
4} Look down slightly; when the 12th block appears step onto it, U-turn and your sights should be on the 11th. shoot it. LHum and step onto 13. 5) Shoot the 2nd block again, step onto the 14th (if the (edge isn't there shoot the 13th block and it shouW appear. Step onto the ledge and go through the door into the last room Selquet - A.
Selquet - A: Duck and crawl across under the lasers, up the other steps, get the gold and stand up. Get the final piece of the Sphinx and you've lifted the Curse and completed the game.
