1. Open the Chest in front of you and take the key in it (Crypt). Open the casket across the room. U turn (U)r look down and shoot the mouse which is draining your energy. Unlock door (A), and go through the "Crypt Corridor".
2. Move directly forwards through the far door into Tantalus".
3. Open casket, and shoot the mouse. GO over to the block and push it (A). Then go back to "Crypt Corridor", cross diagonally to far door and go through to "The Mouse trap".
4. Stand behind the table facing the chair. Get the food (A), then shoot the table and then shoot the chair 5crush that furniture - ed). Go out across the corridor to "Last treasure".
5. Climb up the blocks, move to edge of higher block, and get the Key (Belanus) on the wall above the large block. Push both small blocks into the wall and then go back to "Tantalus"
6. Climb up the blocks and get the food.
7. Go to the locked door at the end of the "Crypt Corridor", unlock it and enter "Belanus".
8. Get the treasure, and go forwards through the door to "Pothole".
9. Push block away (A). (You can only do this if you have a strength rating of Strong or above.)
10. Go through the revealed door to the steps Level 6. Get the food, (from now on , don't get any food if you have any more than 5 large weights on each side of the strength indicator.
11. Go up the steps to level 5, go through the door into the corridor, kill the mouse and go through the door.
12. You are on a walkway above "Ravine", make vour way carefully along it (if you fall off you can't get anywhere, and have to quit!).
13. Go through the door to "The Tube", quickly move to the far wall, and go along the side of the wall. There is a small gap in the tube and you will climb through it. Change height to crawl and shoot the food that is draining your energy. Change back to walk and go through the far door to "Lift entrance 5".
14. Shoot the chair. Walk around the corner of the room and drop down through the hole to "Lift entrance 6".
15. Shoot the chair. Shoot the padlock on the door and open the door. Stay in the room, go around the corner and into the lift. Go to the cupboard in the lift, shoot it and take the Key (Level 4) that is inside (You can't see it, Just "action" the cupboard. Select the top block on the lift panel, then the bottom block. Leave lift and go through the door around the corner to the "Lift Shaff.
16. Go around the lift and get the key (Level 2) which is lying amongst some small blocks, go back to the lift and select the third block up.
17. Leave the lift, you will be at "Lift entrance 4". Shoot the food under the rim of the table. Get the treasure and then go through the far door to -Ravine"
18. Walk along ledge until you get to big block. Push it over (A) so that it forms a bridge across the chasm. Cross the bridge and go through the door on the right. Shoot the mouse and go through the far door to the steps (Level 4).
19. Get the food if you need it.
20. Go up the steps to level 3, go to the far wall, turn around, change to crawl and you will see another key (Trapeze) against one of the steps. Get it and make your way back to the lift. Select the top block.
21. Leave the lift and you will be in a "Tunnel". Go through the near door, shoot the mouse, move through the far door into "Ravine", keep going until you arrive in the "Switch".
22. Turn 90 degrees to the right and shoot the block. Get the food if you need it.
23. Go over to the switch and hit it (A), then move swiftly to the door that appears opposite. Go through the door on to one of the ledges in "Pothole"
24. Drop off the left side of the ledge and you land on the ledge below. Get the key (Level 3) and go through the door on the ledge to "Epona"
25. Get the treasure and the food, shoot the padlock, open the door and go through.
26. Shoot the mouse and go through the far door to "Ravine"
27. Stay on the side you are on, go through the door at the other end, and back to the steps (Level 4).
28. Go up steps to level 3, unlock the door and go through the far door to "Nantosuelta*. Shoot the block, get the food and the jewel then go through the far door to "No room".
29. Shoot the padlock on the door in front of you and open it. Go through onto the "Ravine", then again into a corridor, shoot the mouse and move on back to the Tunnel". Go right down the tunnel to the lift. Go down one floor and make your way to the steps.
30. Go up to level 2. Unlock the door and go through to "Pillar". Shoot the block and get the food if you need it. Push the block in the centre of the room (A).
31. Go back to the steps, down one level and back to "No room".
32. Go down "No room" and open the door on the left (you don't need a key!). Enter "Stalactites" and push the block hanging from the ceiling. Go back to "No room" and through the door at the end on the left. Go to the Tunnel" (across the "Ravine" and through a corridor). GO down the Tunnel" and through the door so that you are standing on the roof of the lift.
33. Go across the lift and onto the ledge next to it. Get the key (Ground floor) then go back to the Tunnel".
34. Go to "No room" and open the door to Trapeze". Shoot the block in Trapeze" and then go back to the steps (making sure you leave the doors open to make a bridge across "No room").
35. When you reach the steps go up to level 2 and then go to "Pillar". Stand on the pillars and get the Key (Yang). Go through the far door to "No room", cross the make-shift bridge to the "Ravine". Go across "Ravine" to "Rat trap".
36. Shoot the block and then stand just within reaching distance of the key (If you get too close you get caught in the trap!). Get the key (Treasure chest) and the trap should land in front of you.
37. Go back through "Ravine", "No room" and "Pillar" to the steps, then up to "Lookout post".
38. Go through the door on the right to "Kerborus"
39. Shoot the heads of the dogs, first the left, then the right, then the middle.
40. Fire on each head until it falls off. When all heads are felled your energy will stop draining.
41. Go back all the way down to "Last treasure" (right at the beginning of the game). Open the chest, take the key and the food, go back to "Kerborus" get any food on The steps" that you left on the way.
42. Once in "Kerborus" go through to the "Gatehouse" and unlock the door to "Spirits abode". Go through and kill all 5 nasties.
43. Go through the window out into the "Wilderness". Turn to face the front of the castle, and shoot the block next to the drawbridge and the drawbridge will fall.
44. Go back to the "Gatehouse" and then out into the "Wilderness".
