Nous sommes actuellement le 09 Mars 2026, 19:17
THE JETSONS
 Sujet du message : THE JETSONS
Message Publié : 03 Jan 2010, 17:22
THE JETSONS (AA97)
Level 1 - George
• From the start go DOWN and then take the LIFT.
• Go UP in the LIFT and then find and PRESS the 4 BUTTONS.
• GET the SPRAY and this should make MR SPACELY disappear from the televisions.
• If MR SPACELY is still present in the televisions, repeat the above process.
• Go DOWN in the LIFT, go UP, then UP in the LIFT.
• Go RIGHT and then proceed to go UP.
• Go RIGHT, then go RIGHT again; go DOWN, DOWN again and then go RIGHT.
• If MR SPACELY is here then go through the last step again
• If he isn't, go DOWN in the LIFT, go UP and then go UP again.
• Go LEFT and then go UP.
• Now go to your LEFT again, then find and PRESS the BUTTONS.
• COLLECT the SPANNER and then go DOWN and then go RIGHT.
• Go RIGHT once more and then go DOWN and DOWN again.
• Go to your LEFT three times and then go UP.
• Go UP and then go DOWN the LIFT.
• Go UP the LIFT and DOWN and DOWN again.
• Now go RIGHT three times and then go UP and UP again.
• Go DOWN the LIFT, and then go UP and PRESS the BUTTONS.
• Collect the PLUNGER, and then go to the LIFT where you used the SPANNER.
• Go DOWN, then DOWN again and then go to
your RIGHT.
• Go RIGHT again, RIGHT once more, and then keep going RIGHT until the end.
Level 2 -Race Section
Travel at full speed as much as possible, but, take care of speed restriction zones. Collect as much money and time as possible in the race sections.
In this level there is no need to take block holes as there are plenty of clocks to collect for time.
Level 3 - Jane
• From the start go LEFT and then go LEFT again.
• Keep going LEFT until you get ELECTRONIMO and then go RIGHT.
• Go RIGHT, DOWN, LEFT, then DOWN again.
• Go LEFT, go RIGHT and then go RIGHT round the CORNER.
• Go DOWN, COLLECT the AQUALUNG, go UP and then go LEFT.
• Go DOWN, go UP in the LIFT and then go LEFT {don't worry, you can walk on water).
• Go UP, go RIGHT, go RIGHT again and get the REMOTE CONTROL.
• Go LEFT, LEFT again, go DOWN, go RIGHT and COLLECT ELECTRONIMO again.
• Go to LIFT, go DOWN in the LIFT, go LEFT, go LEFT again.
• Go UP, RIGHT, DOWN in the LIFT, then LEFT.
• Go DOWN, go RIGHT, go RIGHT and then go RIGHT once more.
• Go RIGHT again, go UP and you have completed the level.
Level 4 - Race Section
• Follow the same tips given for level two.
