Nous sommes actuellement le 09 Mars 2026, 19:39
DUNGEON ADVENTURE (Jewels of Darkness Part 3)
 Sujet du message : DUNGEON ADVENTURE (Jewels of Darkness Part 3)
Message Publié : 05 Mai 2009, 21:28
(You start on a bridge outside the caverns) D, GET CASE AND WOOD, U, S, W, W,
GET POD, E, E, E, N, EXAMINE POD (a few fall to the ground and explode), N (you
can't hear the siren because of the explosion!), GET *MIRROR*, S, S, S, DROP POD
(the bird flies away), U, GET *JADE EGG*, D, N, E, N, U, DROP CASE (it hits one
of the giants; both leave), D, N, GET *BELT*, WEAR IT (this makes you much
stronger), GET CASE, S, S, E (you are hit by a sleep spell, but the mirror
reflects it), S, GET DICE; *WAND* AND *COINS*, N, W, W, N, N, THROW ALL BUT BELT
AND WOOD (the tree grabs everything, but has no branches left to grab _you_!), N, GET AXE, CHOP TREE (a woman asks you not to. OK?), YES (she gives you a *CARVING* in return. The tree drops your belongings again), GET ALL, DROP AXE, S, S, S, W, W, S, U, WAIT (a Rakashasa arrives; he wants to gamble. He'll even use your fake die! OK?), YES (you win and can now be resurrected even if you are far away from the case), D, N, E, N, N, N, N, DROP CASE, IN, IN, GET CHANDELIER, E, PRESS BUTTON (this is your extra life), DROP CARVING; COINS; EGG; MIRROR AND DICE, OUT, GET CASE, LIGHT WOOD, N, GET *HELMET* AND *CRUCIFIX*, WEAR HELMET, N, W, EXAMINE CORPSE (you find a bow and an orange collar), GET IT; ORANGE AND BOW,
W, GET *CUBE*, E, E, NW, GET *FIGURINE*, SE, DROP CASE, NE (the figurine
provides light), GET YELLOW AND *STAFF*, SW, DROP STAFF; YELLOW AND FIGURINE,
WEAR ORANGE, SE (you MUST wear a collar here), TURN STONE, AGAIN, AGAIN (the
stone rolls to the side), E, PUSH BOULDER, E, GET SWORD, W, NE, DROP BODY (the
animals attack the body), W, S, GET POT, N, W, W, W, S, GET *STICK*; BLUE AND
JAR, N, E, E, E, E, N, N, FILL POT (with slime), S, S, SW, NW, DROP CUBE AND
WAND, GET FIGURINE AND YELLOW, IN, IN, GET CHANDELIER, E, DROP BLUE; YELLOW;
FIGURINE AND JAR, OUT, GET ALL, E, E, EXAMINE HAY (using the magnetic cube, you
find a needle), DROP CASE, GET *JEWELLED NEEDLE*, IN, IN, GET CHANDELIER, E,
DROP NEEDLE AND CUBE, OUT, GET CASE, W, W, SW (you MUST carry the bow), SW, SW
(you a captured by skeletons), WAVE STAFF (they vanish. The dwarf you just saved
will give you some ore as a reward), DROP CASE, U, KILL DRAGON (with the sword:
+ 15 points), GET *BED* AND TEETH, D, WAVE WAND (the man towards the southeast
falls into a river), IN, IN, GET CHANDELIER, E, DROP BED; TEETH; BOW; STAFF AND
WAND, OUT, SE, GET *ANTIQUE CHAIR* AND GREEN, NW, GET CASE, N (the vampire
cowers before the crucifix), W, GET *CROSS*, E, THROW CROSS AT VAMPIRE (he dies:
+15 points), GET IT, E, E, W, W, U, DROP POT, GET *HORN* (the goat charges but
slips in the slime), U, U, U, U (the dwarf digs up the ore), IN, GET *ORE LUMP*,
S, U, U, U, U, SAY PASSWORD (to enter), IN, N (Lenslok-check for JoD-owners!),
BLOW STICK (the door opens), N, E, S, D, D, N, N, N, N, E, GET WISP (this gives
you everlasting light), DROP WOOD, WAIT (a mask appears from the ground), GET
*FACE MASK*, WAIT (till the Roc flies you to its nest - if it hasn't happened
already.)
Roc's Nest: GET CATERPILLAR, SQUEEZE IT (it creates a rope), DROP IT, GET
ROPE, TIE IT, GET *ROCK CRYSTAL*, D
S, S, S, W, S, U, U, U, U (on the throne - which also happens to be the Mithril Pedestal), PRESS BUTTON 4 (the throne goes to 'Odd Little Room'), D, DROP CASE, IN, IN, GET CHANDELIER, E, DROP STICK; HORN; FACE; CHAIR; ORE; ORANGE; CRYSTAL; CROSS AND CRUCIFIX, GET JAR, OUT, GET *LAPIS LAZULI*; *ONYX ORYX*, VIOLET; MITHRIL AND CASE, WEAR MITHRIL, U, SAY YELLOW (you are teleported to Yellow Pedestal), D, W, S, GET POTATO, N, E, E, E, E (the rat flees before the potato stench), DROP POTATO, N, GET *STAR PENDANT*, S, W, W, SE, GET HAMMER AND NAILS, NW, U, U, WEAR CREAM (it protects against heat), W, GET *SUN MEDALLION*, E, D, D, NW, EAT MUSHROOM (the rotten bridge turns to gold!), N, GIVE MEDALLION (to the troll), N, N, N, D, EAT MUSHROOM (you shrink), U, N, N, N, N (here you must be small to pass), W, SLIDE BOLT (on the steel door), E, S, S, S, S, D, N (the ants don't notice you), N, EAT MUSHROOM (you grow again), EAT MUSHROOM (and grow), S (and crush the ants), S, EAT MUSHROOM, N, N, EAT MUSHROOM (back to your normal size), S, S, GET MITHRIL; BELT AND HELMET, N, WEAR ALL, S, GET ALL BUT CASE, IN, IN, GET CHANDELIER, E, DROP GREEN; ONYX; LAZULI; VIOLET; NAILS AND PENDANT, OUT, GET CASE, U, N, N, EAT MUSHROOM (this turns you invisible), S, S, S, W (the troll can't see you), GET MEDALLION (your gift to the troll); RED AND *SPICES*, E, S, S, S, U, U, N, N, N, N, E (through the door you unbolted earlier), GET *TREASURE CHEST*, W, U, SAY MITHRIL (to the throne), PRESS BUTTON 9 (you wind up in a pit), SMASH GEM (with the hammer. It contained Agaliarept's spirit: + 15 points), GET SILVER, E, D, CLOSE EYES (so the images won't make you insane), N (a sphere follows you), GET SHIELD AND *DIAMOND*, S, D, D, D, E (here is another sphere. The two destroy each other), OPEN EYES, GET WEDGE, W, U, E (a spear hits the shield), EXAMINE CORPSE (you find a glove and a
blindfold), DROP CASE, IN, IN, GET CHANDELIER, E, DROP RED; SILVER; CHEST;
MEDALLION; SPICES AND HAMMER, OUT, GET GAUNTLET; BLINDFOLD AND CASE, W, DROP
SHIELD, U, E, WEAR GAUNTLET, GET RING (the glove protects you), W, D, D, D (a
boulder rolls towards you), D, W (you are safe), E, D, D, IN, DROP WEDGE (it
saves you from getting crushed), WAIT, WAIT, W, W, GET *AGATE*, E, E, E, D,
THROW RING (it kills the creature in the northern room), N, DROP GAUNTLET, GET
*RUBY*, S, D, WEAR BLINDFOLD, E (the cloth protects against the acid), GET
BROOCH, W, D, E, E, GET *EMERALD*, W, W, D, E, GET BOX, W, D, IN, THROW BROOCH
(it turns into an elephant(!) which kills the executioner), GET *AMETHYST*, W,
N, D, D, D (you've won a competition!), IN, PRESS BUTTON 9 (the best. You go to
'Reward Room'), PRESS BUTTON 4 (you win the mystery prize, a *SAPPHIRE*), U, S,
DROP BOX (the snake in the box drowns), OPEN BOX, GET *OPAL*, U, W, GET PIG, E,
D, DROP PIG (it dissolves. Inside is a pearl), GET *PEARL*, U, U, U, E, U, E,
GET *TOPAZ*, W, W, U, U, E, TURN STATUE (a passage appears east), E, GET
*RHINESTONE*, W, W, D, E (you have escaped Central Dungeon!), DROP CASE, IN, IN,
GET CHANDELIER, E, DROP ALL BUT HELMET; MITHRIL AND BELT (ie. all gems), GET
CRUCIFIX; CROSS; HAMMER; NAILS AND HORN, OUT, GET CASE, E (the crucifix and the
cross protect you against the wights), S, S, CLOSE COFFIN (with hammer and
nails), GET *TRIDENT*, N, N, U, SAY RED (you wind up in 'Cylindrical Room), D,
S, S, S, S, S, S, BLOW HORN (the orc army flees), E, E, E, E, YES (you have
escaped with all the treasures. That leaves YOU as Grand Master!!!)
Notes: You can PLANT TEETH (from the dragon) once the orc army turns up – this will chase it away).
TREASURES: Wand, Staff of Bone, Cube of Sticky Metal, Hollow Stick, Helmet,
Giant's Belt, Cross, Crucifix, Horn, Mirror, Octopus Figurine, Spices, Face
Mask, Dragon's Bed, Ethnic Carving, Antique Chair, Treasure Chest, Coins,
Jewelled Egg, Lapis Lazuli, Onyx Oryx, Ore Lump, Rock Crystal, Jewelled Needle,
Star Pendant, Sun Medallion, Costly Trident, Agate, Sapphire, Diamond, Opal,
Rhinestone, Ruby, Emerald, Amethyst, Topaz, Pearl.
ORDER OF COLLARS: Red, Orange, Yellow, Green, Blue, Violet, Silver, Mithril.
A collar can transport you to any pedestal up to and including its own position on the list. Hence, the Mithril collar can teleport you to ALL pedestals.
You can only teleport FROM the black pedestal, not TO it.
Jacob Gunness - 7/2-1990.
