Nous sommes actuellement le 10 Mars 2026, 00:02
BALLYHOO
 Sujet du message : BALLYHOO
Message Publié : 05 Mai 2009, 11:08
START.......S - LIFT THUMB - S - GET POLE - N - N - N - CLIMB UP - E - E - E -
E - E - E - GET BALLOON - W - W - W - W - W - W - DOWN - DOWN - GET POLE - S -
S - W - GET MASK - S - W - HIDE - WAIT - WAIT - E - N - E - N - NE - SEARCH
GARBAGE - GET TICKET - PRESS BLUE DOT - SW - S - PUT TICKET IN SLOT - E - S
- SE - LOOK INSIDE CAGE - GET KEY WITH POLE - UNLOCK CAGE - OPEN CAGE - ENTER
CAGE - GET THE HEADPHONES AND THE BUCKET - S - NW - N – W - W - S - UNTIE
BALLOON - BREATH HELIUM - SPEAK TO HARRY - S UNLOCK COMPARTMENT - OPEN IT -
GET WHIP - W - WEAR MASK - KNOCK ON THE DOOR - GO IN - CLOSE DOOR - LOOK IN
THE ASH - GET NEWSPRINT - WAIT - LIFT WALL - CRAWL UNDER IT - GET TRAP - WAIT -
(SOMETIMES 4X) - FEEL THE ROLE - UNSET THE TRAP - PUT THE CHEESE IN TRAP -
REMOVE THE MEAT - DROP TRAP.
E - W - E - W - GET MOUSE WITH BUCKET - E - N - E - PUT TICKET IN SLOT - E - S
- GET MOUSE FROM BUCKET - GIVE MOUSE TO HANNIBAL(2X) - LOOK - N - E - E - N - SE
- GET STOOL - NW - S - W - W - W - N - N - UNLOCK LION CAGE - OPEN CAGE -
ENTER CAGE - WHIP THE SMOOTH LION (3X) - OPEN GRATE - PUT THE MEAT INTO PASSAGE
- GO OUT - GO IN - CLOSE GRATE - LOOK UNDER THE STAND - OUT - S - S - W - S -
GIVE CASE TO HARRY - N - E - PUT TICKET IN SLOT - E - E - S - SHOW CASE TO
ANDREW - GIVE CASE TO JENNIFER - UP - GET ALL - LOOK INSIDE POCKET - GET VEIL -
UP - N - N - GIVE TICKET TO RIMSHAW - RIMSHAW,HYPNOTICE ME - STAND - E - UP - E
- PASS MONEY THROUGH CROWD - DOWN - E - UP - E - DOWN - S - GET INTO LONG
LINE - WAIT(UNTIL YOU SEE A SHORT LINE) - GO IN SHORT LINE - WAIT (3X) - GO OUT
SHORT LINE - GO IN LONG LINE - GO OUT LONG LINE - (DO THIS SO LONG UNTIL
YOU HEAR A VOICE,IN SHORT,OUT SHORT,IN LONG,OUT LONG,IN SHORT) - YES - NOW
GO AGAIN IN THE LINES AND OUT THE LINES UNTIL YOU CAN BUY BANANAS - REMOVE
CHOCOLATE - DROP BANANAS.
N - HELLO HAWKER - (NOW WALK AROUND UNTIL YOU ARE BACK TO RIMSHAW) - STAND - S
- W - CRAWL UNDER TENT - SEARCH GARBAGE - DROP WHIP - DROP POLE - GET GRANOLA -
CRAWL BACK - S - S - SW - N - PUT TICKET IN SLOT - E - E - E – N - SE - SHOW
GRANOLA - HELLO TINA - GET HAND - KISS TINA - NW - GET RADIO - OUT - W - W - S
- SE - DROP ALL - GET RADIO AND HEADPHONES - CLIMB ON CAGE - CLIMB LADDER -
TURN DIAL TO 1170 - REWIND TAPE - RECORD THE MUSIC – WAIT (UNTIL THE TAPE IS
FINISHED) - REWIND TAPE - DOWN - DOWN - LOOK - GET ALL - NW - UNLOCK CAGE -
OPEN CAGE - ENTER CAGE - PLAY TAPE - WAIT - LOOK UNDER STRAW - OPEN TRAP_DOOR
- GET RIBBON - OUT - SE - SLIDE TICKET UNDER FRONT - GO IN - GET TICKET -
BET $1 - (NOW PLAY UNTIL YOU WIN)NOW:OPEN PANEL - OUT - NW - SW - WAIT - NE -
SE - SLIDE TICKET UNDER FRONT - GO IN - LOOK UNDER TABLE - GET CASE - WAIT - OUT
- DROP ALL.
CLIMB UP - CLIMB LADDER - GO HOLE - WAIT(2X) - GRAB SHAFT - PULL SHAFT - DOWN
- DOWN - GET ALL - NW - SW - DROP ALL - CLIMB LADDER - OPEN PANEL - KNOCK ON
DOOR - GO IN - LOCK DOOR - GET SPREADSHEET - MOVE DESK - UP - DOWN - GET
ALL - N - FILL BUCKET WITH WATER - S - NE - N - POUR WATER OVER DETECTIVE - ASK
DETECTIVE ABOUT BILLY - DROP STOOL AND RADIO - GET NOTE AND CARD - READ
SPREADSHEET - S - SW - N - W - S - ASK HARRY ABOUT EDDIE - W - S - E -
HELLO EDDIE - GIVE CARD AND NOTE TO EDDIE - GIVE SPREADSHEET TO EDDIE - GIVE
NEWSPRINT AND THE RIBBON TO EDDIE - WEAR DRESS_SUIT - WEAR SHAWL_JACKET - WEAR
VEIL - WEAR RIBBON - KNOCK ON DOOR - GO IN - CLOSE DOOR - GET CROWBAR - GET
HEAD - OPEN DOOR - OUT - W - OPEN DOOR - GO IN - GET THUMB - OUT - E - GO IN -
PUT THUMB IN HOLE - WAIT - GET CHELSEA - OUT.
N - E - NE - SW - N - N - N - CLAP HANDS - ROUSTABOUT,GET NET - WAIT - S - S
- S - NE - N - DROP ALL - GET RADIO - S - SW - N - N - N - ENTER CAGE - GET
STAND - OUT - DROP STAND - STAND ON IT - CLIMB UP - UP - TURN RADIO ON -
REMOVE SHAWL-JACKET - REMOVE DRESS-SUIT - REMOVE RIBBON - REMOVE VEIL - DROP
SHAWL-JACKET AND DRESS-SUIT - DROP VEIL AND RIBBON - E - W - W - W - W - DOWN -
DOWN - (IF YOU DROPPED THE RADIO THEN PICK IT UP HERE) - S - S - S - PHONE
STATION - OUT - N - N - N - STAND ON STAND - UP - NOW GO EAST UNTIL THE GIRL IS
FALLING DOWN - WAIT UNTIL YOU FALL DOWN!!!
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 46 invité(s)
