Nous sommes actuellement le 09 Mars 2026, 20:55
SNOWBALL
 Sujet du message : SNOWBALL
Message Publié : 03 Mai 2009, 21:05
(Later released as Part 1 of the 'Silicon Dreams' Trilogy)
Start inside a Coffin.
EXAMINE (you will notice a lever beside you, even though it's pitch
black!)
PULL LEVER (the lid rises)
OUT
N
PUSH RED BUTTON
PUSH RED BUTTON
PUSH RED BUTTON (a coffin will now slide from an arpeture)
S
UP (you now stand on the coffin)
UP (you scramble through a trapdoor)
WAIT (several times until the 'clanking noise' of the deadly Mechanical
Nightingale "fades away")
N
OPEN DOOR
N
E
PUSH BUTTON (the elevator arrives)
S
DOWN (you now cling to a rope below the elevator!)
DOWN
TAKE TOOLBOX
UP
UP
PRESS BLACK BUTTON
N
W
W
W
UP (to a Significant Cylindrical Ledge)
S
S
S
S
S
S
S
S (you are now in a Featureless Airlock)
PRESS YELLOW BUTTON (the door slides open)
S
S
DOWN
DOWN (you are now lying on a comfortable couch)
SCORE (the table will now massage you, and you've got 150/1000 so
far!!).
UP (a Dumpy Droid is now shuffling about)
UP
S
WAIT (several times until a Scruffy Robot shuffles on to the Cyladder
and is carried down)
DOWN (you fall into a Large Low Room)
S
DOWN (you are now seated at a Console)
WEAR VISOR (the screen will light up)
LOOK AT 2 (it becomes brighter)
BLINK (the screen displays information numbers)
UP
S
SEARCH BODY
WEAR LEOTARD
WEAR NECKLACE
WEAR BRACELET
N
N
N
EXAMINE TABLE
TAKE VIEWER
N
TAKE MEMPAK
INSERT MEMPAK
EXAMINE VIEWER.
(You will now be given TWO important colour codes. One is for your OWN
coffin location and the other for the FROZEN CREW MEMBER'S coffin
location.......These are DIFFERENT for EACH GAME!.......Make a note of
the TWO SETS OF COLOUR CODES, including the MORTUARY COLOURS. You
should have SEVEN COLOURS in EACH CODE!).
OPEN TOOLBOX
TAKE SPANNER
DROP SPANNER
TAKE SCREWDRIVER
TAKE BATPAK (you lever it out with the screwdriver)
DROP SCREWDRIVER
DROP VIEWER
S
S
E
N
E
N
TAKE LAMP
INSERT BATPAK
TAKE CUP
S
INSERT CUP (the machine fills it with thin lentil custard!!)
W
LOOK UNDER BED
TAKE LED
S
W
UP (you are carried up the Cyladder)
S
N
N
DOWN (a Robot welcomes you)
DOWN
DOWN
S
S
U
W
N (the Damaged Droid requests a spare part.....'EXAMINE' or 'WAIT'
until it does)
ATTACH PROBE (this is the 'LED' you collected earlier. Make a note of
the spare part it requires.......this will DIFFER FOR EACH
GAME........then follow the given route around the junk and collect
what you were asked for, returning to the Damaged Droid)
E
N
N
W
S
S
GIVE.......(the item you were asked for) (the Droid then gives you a
battered Bubble Helmet).
DROP PROBE
E
DOWN
DOWN
E
E
TAKE RED TICKET
N
N
N
TAKE GREEN TICKET
W
W
GIVE RED TICKET
TAKE RED FORM
S
S
S
GIVE GREEN TICKET
GIVE RED FORM
TAKE ORANGE FORM
E
E
TAKE RED TICKET
N
N
N
TAKE GREEN TICKET
W
W
GIVE RED TICKET
GIVE ORANGE FORM
TAKE YELLOW FORM
S
S
S
GIVE GREEN TICKET
GIVE YELLOW FORM
TAKE GREEN FORM
E
E
TAKE RED TICKET
N
N
N
W
W
GIVE RED TICKET
GIVE GREEN FORM
TAKE LANCE
S
UP
OPEN DOOR
U
U
N
PRESS BUTTON (the door slides open)
N (We're now coming to the complicated bit, which cannot be mapped
correctly as it DIFFERENT for EACH GAME! Follow the directions
carefully)
SCORE (should now be 450/1000).
LOCATING AND REVIVING THE FROZEN CREW MEMBER!!
PRESS YELLOW BUTTON
N (continue North and every time there is an exit DOWN, 'EXAMINE
BRACELET' until the FOURTH colour on the bracelet is the SAME as the
SECOND colour of the Frozen Crew Members code that you noted earlier.
When the colour matches.........)
DOWN (now proceed EAST until you reach an elevator, indicated by a
button protruding from the floor)
PRESS BUTTON (the elevator arrives)
PRESS...(the FOURTH colour of the code)...BUTTON
N (from now on, whenever you hear a noise, go in the OPPOSITE direction
of the source of the noise, usually from the West, and find a door,
open it, and 'WAIT' until the noise fades away, then go OUT and proceed
EAST until you are at a GREEN door)
EXAMINE LIGHTS (there are THREE colours and they must match the SECOND,
THIRD and FOURTH colours of the Frozen Crew Members code. If they
don't, proceed EAST again until you reach the next GREEN door and
repeat the procedure, bearing in mind what to do if you hear the noise!
When the lights match the SECOND, THIRD and FOURTH colours, in the SAME
SEQUENCE.......)
OPEN DOOR
N (there is a panel here and you must press the buttons corresponding
with the LAST THREE colours of the code, that is FIFTH, SIXTH and
SEVENTH)
PRESS...(5th colour)...BUTTON
PRESS...(6th colour)...BUTTON
PRESS...(7th colour)...BUTTON (a coffin slides out from an arpeture)
N
TAKE COFFIN
S
WAIT (several times, until the clanking sound approaches and eventually
fades away)
OPEN DOOR
S
E (continue EAST until you arrive at a button in the floor......bearing
in mind the procedure if you hear the clanking noise again!)
N (a machine grabs and opens the coffin to reveal the Frozen Crew
Member!!)
GIVE LIQUID (she drinks it and gives you the HABIDOME CODE......make a
note of these THREE COLOURS).
(Well, that's the hard bit over!!....now on with the adventure!!)
S
PUSH BUTTON
S
PUSH BLACK BUTTON
N
W
W
UP
S (continue SOUTH until you arrive at an Airlock)
PUSH YELLOW BUTTON
S (You are now back at the North End of the Marblon Cylinder
See Map 2)
S
S
S
WEAR HELMET
PUSH YELLOW BUTTON
S
PUSH YELLOW BUTTON
S
TAKE GUN
LIGHT LAMP
S
S
S
JUMP (you are told that there is no web that way, are you sure?)
YES
SHOOT GUN (the recoil spins you and you float down)
SHOOT GUN (you now have to quickly match your velocity with the
fast-moving ice below you!!)
SHOOT GUN (That did the trick! You are now on a Flat Snowfield)
DROP GUN
UP
UP
PUSH BUTTON (the Shuttle arrives)
IN
PRESS BUTTON (on to the next Station)
OUT
DOWN
DOWN
IN
PRESS BUTTON
S
PRESS YELLOW BUTTON
S- DOWN (you are now confronted by a Security Door. The combination is
the THREE COLOUR HABIDOME CODE given to you earlier when you revived
the Frozen Crew Member)
PRESS...(1st colour)...BUTTON
PRESS...(2nd colour)...BUTTON
PRESS...(3rd colour)...BUTTON (the door will now slide open!)
IN.
DOWN (the Forest Glade is really a hologram!!)
E
E
IN
TAKE WAND
OUT
W
W
WAVE WAND (it whistles, and you are now in a Large Round Room)
DROP WAND
DOWN
PUSH BUTTON
DOWN
PUSH YELLOW BUTTON
DOWN
DOWN
WEAR GLASSES
UP
PUSH BUTTON
UP
PUSH YELLOW BUTTON
UP
UP
SE
SE
TAKE CAT
NW
NW
OPEN DOOR
NE
TAKE TRAY
OPEN DOOR
SW
UP
OPEN DOOR
OUT
UP
S
TAKE CAN
PUT CAN IN TOOLBOX
CLOSE TOOLBOX
TAKE FLASK
N
PUSH BUTTON
N
PUSH YELLOW BUTTON
N
OUT
UP
UP
PUSH BUTTON (to call the Monorail Shuttle)
IN
PUSH BUTTON
PUSH BUTTON
OUT
DOWN
DOWN
TAKE SHOVEL
UP
UP
PUSH BUTTON
IN
PUSH BUTTON
PUSH BUTTON
OUT
DOWN
DOWN
IN
DOWN
DOWN
S
TAKE CYLINDERS
N
UP
UP
OUT
UP
UP
PUSH BUTTON
IN
PUSH BUTTON
PUSH BUTTON
OUT
DOWN
DOWN
OPEN DOOR
IN
WEAR ARMOUR
OPEN DOOR
OUT
UP
UP
PUSH BUTTON
IN
PUSH BUTTON
PUSH BUTTON
PUSH BUTTON
OUT
DOWN
DOWN
DIG (you find a bunch of keys and you are now in a Tiny Hole).
DROP SHOVEL
TAKE KEYS
MEND SNOWDOZER (you fix the tracks)
DROP LANCE
DROP CYLINDERS
IN
DOWN
TAKE EXTINGUISHER
UP
TURN KEYS (you are now advised to leave the Snowdozer!)
OUT (the Snowdozer moves off, pushing ice blocks into the hole)
DROP KEYS
EXAMINE TRAY (it holds an Electro-Flute)
TAKE FLUTE
UP
UP
PUSH BUTTON
IN
PUSH BUTTON
OUT
DOWN
DOWN
N
N (you are now at the base of Jacob's Ladder, guarded by a massive
Waldroid!)
OPEN TOOLBOX (the aerosol paint can explodes in the vacuum and blinds
the Waldroid!)
UP
UP
UP
UP
N (the ramp here is coated in 'unislime')
DROP CAT (likes slime, does this cat!!)
UP
UP
UP
UP
OPEN DOOR
IN
ATTACH FLASK (the helmet is now recharged with air)
W
WAVE TRAY (the tray reflects a laser beam back on itself and you hear
an explosion)
W
S
OPEN DOOR
IN (a figure, holding a petrol bomb, warns you to keep back!!)
PLAY FLUTE (it shatters the bomb and engulfs the female figure in
flames)
PRESS EXTINGUISHER (the Nitrogen kills the fire)
W
PULL LEVER.
FINAL MESSAGE
"It turns!...Engines roar!...The Snowball turns away from the
sun....you have won!".
"You scored 1000 out of 1000".
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 30 invité(s)
