Nous sommes actuellement le 14 Jan 2026, 09:12
Three Weeks in paradise
 [ 5 message(s) ]
 Sujet du message : Three Weeks in paradise
Message Publié : 11 Jan 2009, 10:50
Message(s) : 3614
new poke for 3 Weeks in paradise by hERMOL // CPCRULEZ
infinite lives: &39ce: &3d -> 00
cuL8er
 Sujet du message : Re: Three Weeks in paradise
Message Publié : 11 Jan 2009, 10:51
Message(s) : 3614
THREE WEEKS IN PARADISE COMPLETE SOLUTION
To Rescue Wilma
First of all get the Mint from the sign outside the Trading Post
then get Wilma's Handbag from the beach, to get to the beach go
through the picture in the room that contains the table. As long
as you have the Handbag in your possession the crocodile will not
harm you. Go to the screen with the Ice Cube in it and press the
Action key. Now pick up the Hole and go right until you are just
past the crocodile, now drop the Handbag. Take the Gold Fish Bowl
and the Hole to the Wishing well screen, stand at the far left
of the screen and press the Action key. Go left into the new
screen and take the Skeleton key, the spider will not move as
long as you have the Bowl. Go through the picture again and into
the sea, pass over the locker and the door will open. Take the
Spinach and drop it in a convenient place. Go back to the room
with the picture in it and get the stuffing from underneath the
table,go to the room with the big bird in it. Take the Egg but
don't drop the stuffing while you are in the same room as the big
bird. With the Egg and the Spinach proceed to the room that
contains the sign 'Old Faithful', now pull the rope and run to
the water. Jump up the geyser. Jump into the nest and swap the
Spinach for the Bow and Arrows. Now drop down and drop the Egg.
Go to the screen that contains Wilma and shoot the native with
the Bow and Arrows.Proceed to the screen with the well in it and
jump down. Go to the centre of the well and press the Action key.
Take the bottle and climb out of the screen by going to the right
of the screen and keeping the Action key depressed. With the
Bottle and the Corkscrew return to the crocodile screen.Get the
Bottle and the Corkscrew past the crocodile one at a time by
using the Handbag. Standing over the Coconut with both of the
objects press the Action key. Take the Bottle of Oil and the
Blunt axe to the screen with the hut and the car. Pass over the
front wheel of the car and press the Action key.With the Sharp
axe return to the screen with Wilma and cut her down by pressing
the Action key.
To rescue Herbert
First of all get the Deux Sticks from the crocodile room using
the Action key, light the fire in the anvil room. Take the
bellows from the top of the well, then pass over the fire and
press the Action key. Get the Hot Ashes and take them to the room
with the Totem pole in it. Now pass over the white man and press
the Action key.Should you have the bellows the cloud will move
away from you, so make sure you are standing to the right of it.
When the cloud reaches the hut collect the Shell. Now take the
Shell down the well and press the Action just as the drip
touches. Once that has been done take the Billy Can to the
Geyser, pull the rope, and run to the water to fill the can.Go
and find the Flipflops and take them along with the full Billy
Can to the beach. Just as you pass the crab press the Actionkey.
Now collect the Claw and take it to the right hand side of the
room that contains Herbert. Whilst keeping the Action key
depressed walk into the lion. Take the Thorn, with this and full
Sea Shell walk to the middle of the cauldron and press the
Actionkey.
To escape
Just go back to the beach via the picture, in the room with the
table, and you will have finished the game with 100%.
Message Publié : 02 Fév 2009, 17:19
Message(s) : 3614
Three weeks in paradise - Tips + Solution by mike_myers
TIP
- You can drop up to 4 items per screen.
- Bow and arrows have another use: In the game there's a native that is moving between the screen with the frog and the screen with the sorcerer. When an arrow hits him he starts to walk in opposite direction and you can avoid risks.
SOLUTION
There are several ways to complete the game, here's one...
1) DESTROYING HUT
Get Goldfish Bowl. Left[x3]. Drop Goldfish Bowl. Right. Get blunt axe. Enter between signs. Get deux sticks. Exit (go right). Right[x4]. Enter between signs. [you reach a screen with swords]. Drop all. Right[x3]. Get mint (it's behind "Tradin' Post" sign). Enter shop. Get flipflops. Exit shop (move left). Left[x2]. Enter between signs. [return to screen with swords]. Drop mint. Get deux sticks. Drop flipflops. Left[x3]. Get bellow. Right. Jump to enter door. Right. Use bellow with deux sticks to make a fire. Use it again and you'll get hot ashes. Right[x2]. Use hot ashes with the native and the cloud will start to shoot rays. Use bellow to move cloud (you must be at the right of the cloud).Left[x2] -you'll have to jump the native at least once-. Wait till rays destroy hut. Drop bellow. Pick the empty Billy can and the empty Sea Shell.
2) RESCUING HERBERT
Right. Enter between signs [you reach screen with swords], replace empty sea shell by flipflops, left, jump to picture (you appear at the beach). Left[x2]. Fill the empty Billy can using geyser. Right. Use full Billy can on crab. Get crab's pincer and drop it out of quicksand. Right. Get Wilma's handbag. Left. Replace flipflops by crab's pincer.
Left[x3]. Enter door -jump-. Right. Change Wilma's handbag by empty Sea Shell. Right. Left[x5]. Use crab's pincer on thorn (from now on, lions at this screen won't kill you). Get Goldfish Bowl. Left [you reach the screen with the well]. Drop goldfish bowl. Enter well [when you reach rope, press "use" key]. Get bottle, fill sea shell and exit (go to right wall and press USE key -4 screens-). Enter between signs. Go to fire and use sea shell. [You've rescued Herbert]
3) FILLING BOTTLE WITH OIL
Right. Enter between sighs [screen with crocodile]. Drop bottle. Right. Left[x2]. Enter (jump door).Right. Get corkscrew and Wilma's handbag. Left[x3] [screen with well]. Enter between signs [screen with lions]. Right. Enter between sighs [screen with crocodile]. This time croc is sad and can't kill you (that happens because you carry Wilma's handbag). Drop corkscrew at the left of croc, and do the same with the bottle -and don't drop handbag while you do this-. When you've dropped those items at the left of the croc and are in a place it can't kill you, you'll have to use bottle and corkscrew to fill the bottle with oil (corkscrew disappears). Get handbag and drop it when you're at the right of the croc (you'll need it again).
4) SHARPING AXE AND GETTING SKELETON KEY
Right. Left[x2] [return to screen with well]. Right. Drop bottle of oil. Enter door. Right. Get blunt axe and mint. Left[x2]. Drop mint. Get bottle of oil. Right. Press "use" key when you're in left door (that sharpens the axe -bottle disappears-) [sharp axe is one of the items you need to rescue Wilma]. Left. Enter door. Get bowl of stuffing. Right[x3]. Enter between signs. Drop sharp axe. Left. Get egg (but don't drop bowl of stuffing while you do this). Right. Drop bowl of stuffing. Enter between signs. Left. Enter between signs. Left[x2] [screen with big door], Right[x2] [screen with geyser], drop egg, Left[x2], get mint, left [screen with well], enter between signs [lions], right, enter between signs [croc' screen], get Wilma's handbag, use mint to melt down ice, get hole, right, drop Wilma's handbag when croc can't kill you, right, left[x2], get goldfish bowl, use hole in the wall, left, get skeleton key [but don't drop goldfish bowl or the spider will kill you], right, drop goldfish bowl
5) RESCUING WILMA AND COMPLETING GAME
Right[x4], get flipflops, right, dive, Use skeleton key on locker. Pick up tino of spinach. Up (you return to beach). Left[x2]. Drop flipflops. Pick egg, use geyser again [this time you reach an screen with a nest, when you don't carry the egg and eagle appears and kills you], jump to reach the nest, drop egg, get bow and arrows, Fall and drop tin of spinach. [you've the 2nd item needed to rescue Wilma]. Left[x2]. Enter. Right[x3]. Enter between signs. Kill native using bow and arrows. Get sharp axe -you dropped it here- and use it to rescue Wilma. Enter between signs. If you see the native, use an arrow to get rid of him temporally. Left. Enter between signs [screen with swords]. Left. Jump to the picture and... another game finished with a 100%. (*)
(*) There's another way, use flipflops and walk over quicksand to reach the beach.
 Sujet du message : Three Weeks In Paradise
Message Publié : 18 Déc 2009, 10:06
* Cheat Mode (Vies infinies) :
Lorsqu'on meurt, enfoncer simultanément les touches H+A+T (Clavier QWERTY) et relacher uniquement après avoir repris le controle du joueur.
Message Publié : 06 Juin 2011, 19:15
Message(s) : 3614
 [ 5 message(s) ]
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 12 invité(s)
