NECRIS DOME (Code Masters) --------------------------
[This game is a real dud - so don't say I didn't warn you ]
(You begin insde a casket), PUSH LID, ENTER CASKET, TAKE GLOVES, PUSH LID, EXAMINE GLOVES, TAKE AXE, WEAR GLOVES, E, E, PUSH CASKETS, LOOK, EXAMINE MANDROID, SEARCH MANDROID, LOOK, TAKE ORANGE TRANSROD, TAKE GREY TRANSROD, E, E, D, W, KILL ROB, EXAMINE ROB, SEARCH JUNK, TAKE MULTI FUNCTI, E, E, E, E, TAKE SUIT, SPRAY SUIT, DROP AEROSOL, E, TAKE ICE, W, SEARCH, U, N, W, W, W, S, EXAMINE DIAGRAM (a plan of the power cables), USE MULTI FUNCTI (the panel swings open), PRESS ONE, PRESS TWO, PRESS THREE, PRESS FOUR, DROP MULTI FUNCTI (RE- EXERCISER PADS NOW DISABLED), E, EXAMINE UNIT, PUT MANDROID (in unit), LOOK TAKE BLUE TRANSROD, DROP ICE, N, HIT PIPE (with the axe), EXAMINE MANDROID, SEARCH MANDROID, LOOK (se green and brown transrods), TAKE GREEN TRANSROD, W, W, W, W (China 2), E, TAKE METAL, W, W, W (Rec 1), DROP GREY TRANSROD, E, E, S (Amer 9), TAKE COIL, N, N, N, TAKE POWER CELL, EXAMINE POWER CELL, EXAMINE METAL, EXAMINE COIL, MAKE MAGNET, TAKE SHELL, EXAMINE SHELL, WEAR SHELL (disguise), TAKE HELM, E, E, DROP BLUE TRANSROD, E, S, W, EXAMINE VAT, FILL HELM, E, THROW ACID, EXAMINE MANDROID (see pink and red transrods), DROP HELM, N, W, TAKE BLUE TRANSRODS, E (Rec 18), W, W, S, W, W, W, W (the magnet scrambles the circuits of the battle droid - it collapses in a heap), LOOK, SEARCH JUNK, DROP MAGNET, TAKE OXY ENCHANGER, S, E, TAKE ICE, N, E (Afri 1), DROP GREEN TRANSROD, E, DROP BLUE TRANSROD, E, S, TAKE RED TRANSROD, TAKE PINK TRANSROD, S, W (India #?), CUT CABLE, EXAMINE CABLE, N, E, S, OPEN WHITE LOCKER, LOOK, TAKE WHITE TRANSROD, N, W (Control Level), W (stopped), THROW ICE, W, EXAMINE ARCH MANDROID, SHOOT PIPE, SEARCH ARCH, DROP WHITE TRANSROD, TAKE KEY, EXAMINE KEY, W, SEARCH, INSERT KEY, FIRE AT-LAN (now you only have a short time before the dome explodes), E, N (Afri 2), TAKE BLUE TRANSROD, E (Rec 18), DROP ORANGE TRANSROD, 9*W, ENTER CASKET
"You hear the explosion, but you are safely jettisoned into space. The oxy- exchanger gives you adequate oxygen and the homing deivce is functioning. Your mission has been a total success"
Transrods Orange W from Rec 7 to Amer 9 E Rec 6 -"- S Rec 3 -"- Grey E Rec 2 China 2 S Rec 1 -"- W Rec 3 -"- Green W Rec 14 Afri 1 E Rec 10 -"- Blue E Afri 2 Rec 18 N Afri 7 -"- Red S Afri 6 India 9 W Afri 11 -"- E Afri 9 -"- Brown N Sov 3 Rec 4 Pink N India 4 Afri 2 W India 3 -"- White W India 7 Control Level E India 6 -"-
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 52 invité(s)
