1. Go past the two rabbit holes until you come to the bucket. 2. Take the bucket 3. Return to the rabbit holes and go down the first one you come to 4. Go right and take the key 5. On the next screen, jump up on the boxes and out of the hole. 6. Go left past the shed to the pond 7. Move right to the edge and use the bucket 8. Return to the rabbit hole 9. Keep going right until you get the next lot of boxes. Drop the bucket and jump on the boxes. 10. Go left past the shed, take the lettuce and return to the rabbit hole 11. Go right and give the lettuce to the unfriendly rabbit; he will leave you alone 12. Continue right and jump the rabbit hole 13. Go left until you come to the post box, use the key, go back for the scissors, take the scissors, mix the objects and drop the scissors. 14. Go left to the tin opener and take it 15. Return to the rabbit hole and go down 16. Hop left to the first set of boxes, jump up and outside 17. Go left until you come to a tin box, drop the football, take the tin box and mix the objects 18. Drop the tin opener, take the football, take the pump and mix the objects 19. Right to the rabbit, drop the football and go back to the rabbit hole 20. Drop the pump and take the football 21. Go to the pond (where you filled the bucket) and use the football. When at the other side drop the football and go to the tree with the acorn 22. Use the balloon, take the acorn and jump down the tree 23. Drop the balloon and take the football 24. Go back across the pond and down the rabbit hole 25. Hop back for the bucket, then go left and jump up the last rabbit hole you come to 26. Go right until you come to the squirrel and use the acorn then take the bone 27. Return to the two rabbit holes and drop down the second one 28. Go left up the rabbit and keep going until you come to a flame on the rock 29. Use the bucket. Go past the rock and up to your family. Well done, game complete.
