Nous sommes actuellement le 10 Mars 2026, 00:26
KLAX - GX4000
 Sujet du message : KLAX - GX4000
Message Publié : 10 Jan 2009, 21:27
KLAX CARTRIDGE by cpc4eva
INF DROPS
1502 00
INF CREDITS
0AFD 00
SKIP CURRENT LEVEL
2ED1 00
ALWAYS SAME SPEED
10B1 00
CHANGING SPEED
MAKE SPPED CHANGE YOURSELF BY POKING A VALUE INTO 2E7F
IE POKE 27EF FF (VERY SLOW SPEED) OR POKE 27EF 10 (VERY FAST SPEED)
*** YOU WILL ONLY SEE A CHANGE AFTER THE NEXT BLOCK COMES WHEN ENTERING A POKE SO DONT THINK IT HASNT WORKED. DONT FORGET TO RE-ENTER THE SPEED POKE AFTER EACH LEVEL OR WHEN YOU RESTART YOUR CURRENT LEVEL AFTER SAY 3 DROPS.
COMPLETE PAUSE & REST
109E 00 = PAUSE
109E 12 = TO RESTART
WARPING
2EC4 XX WHERE X-1 = LEVEL TO JUMP TO
IE. POKE 2EC4 05 NEXT LEVEL WILL BE LEVEL 6
POKE 2EC4 0A NEXT LEVEL = LEVEL 11
THEN USE SKIP CURRENT LEVEL POKE AND U WILL START ON NEW (X) LEVEL.
NB. HIGHEST LEVEL ALLOWED = 63 = 100
ALSO MAKE SURE YOU GO IN 5S TO KEEP GRAPHICS CORRECT WHEN WARPING
IE. 05 (LEVEL 6) 0A, 0F,14,19 (LEVEL 26) 1E,23,28,2D,32 (LEVEL 51) 37,3C,41,46,4B (LEVEL 76) 50,55,5A,5F (LEVEL 96)
DONT WARP STRAIGHT TO 100 START AT 96 IE POKE 2EC4 5F AND THEN ENTER THE SKIP LEVEL POKE
PHEW!!!!
 Sujet du message : Re: KLAX - GX4000
Message Publié : 10 Jan 2009, 21:28
KLAX CARTRIDGE, New Pokes by cpc4eva
Mr BAD BEARD says its XMAS 2004 and there is time for KLAX Cartridge pokes
ps. remember it's READ memory
Klax Cartridge CPC
Poke 1502 00 = Infinite Drops
Poke 0AFD 00 = Infinite Credits
Poke 2ED1 00 = Skip Current Level
Poke 10B1 00 = Always same speed (speed of klax coming down)
You can make the speed change yourself by poking a value into 2E7F
ie. Poke 2E7F,FF Very Slow Poke 2E7F,10 Very Fast etc...
You will only see the result AFTER the next block comes when entering the poke so don't think it hasn't worked. You should be able to get big scores just by using the speed poke and ie. Poke 2E7F,FF
Don't forget to re-enter the speed poke after each level or when you restart the current level after say 3 drops.
CPC4EVA says "I only enter the speed poke once and it worked fine all the way through but if you are having trouble do what BAD BEARD says above"
For a complete pause and rest
Poke 109E 00
When ready to go again
Poke 109E 12
WARPING
Poke 2EC4,X where X-1 = Level To Jump To
ie. Poke 2EC4,05 Next level will be 6
Poke 2EC4,0A Next level will be 11
Then Use *Skip Current Level poke*. You will then start on the new (X) level.
Nb. Highest level allowed = 63 = level 100
Also make sure you go in 5's to keep the graphics correct when warping.
ie. 05 (level 6),0A,0F,14,19 (level 26),1E,23,28,2D,32 (level 51),37,3C,41,
46,4B (Level 76),50,55,5A,5F (level 96)
don't warp straight to 100. Start at 96. ie. Poke 2EC4,5F and then enter the skip level poke
Hope you like 'em
CPC4EVA says "loved that warp poke - i went straight to level 96 .... look at the next post of end of game screenshots...."
RUN "SIGNATURE"
PRESS PLAY THEN ANY KEY
Yesterday Is TODAYS memory and Tomorrow is TODAYS dream
READY
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 59 invité(s)
