Nous sommes actuellement le 14 Jan 2026, 05:51
Basket Master
 Sujet du message : Basket Master
Message Publié : 10 Jan 2009, 20:18
Message(s) : 3614
New POKES, Basket Master
Mr BAD BEARD is quickly becomming the new Phil Howard of CPC poking.
have a look at these pokes he got for BASKET MASTER. **** Make sure you select WRITE memory in WINAPE.
Infinite Time
Poke 1C9F 00
*** I FOUND THIS POKE FOR INF TIME
11B0 C9
11C0 C9
11D0 C9
*** BUT I THINK BAD BEARDS POKE IS BETTER CAUSE IT STOPS THE CLOCK.
>>> THE TIME POKE IS OF NO REAL BENEFIT BUT IF YOU WANT TO CONTINUE PLAYING TO SEE HOW MANY POINTS YOU GET THEN ITS GOOD FUN.
STOP OPPONENT FROM SCORING
if opponent is about to score you could Poke 1124 FF quickly and the game will restart with your opponent in the far court.
INFINITE FOULS
16A9 00
16AA 00
16AB 00
INFINITE ENERGY
1C51 00
POKES for infinite FOULS & ENERGY will also give the opposition inf. energy as they both use the same
routine!!!
If you are not bothered about this then great but if you are then
we have to be clever! This will be the same for the fouls
also. If we have infinite fouls then so does the opponent!!!!
We have to do some programming ourselves and rewrite the code so that this
doesn't happen hehehehehe :0)
Type the follwing codes at the <addresses> below.
EXAMPLE of First line below
Poke 1C4E C3
Poke 1C4F 22
Poke 1C50 87
got that?!?
Infinite Energy Player 1
<1C4E> C3 22 87
<8722> DD 22 20 87 DD 7E 0A F5 3A 20 87 FE 2F 28 04 F1 C3 51 1C F1 C3 52 1C
Infinite Fouls Player 1
<16A9> C3 3B 87
<873B> DD 22 39 87 F5 3A 39 87 FE 2F 28 03 DD 34 0B F1 C3 AC 16
now try it hehehehe
Score
location 1125 holds your score
location 1126 holds opp.score
ie. Poke 1126 00 makes computer score reset when he next scores hehehehe
How many points do you want?
Poke 172E xx Player 1 one point scores - x = change to value you want
Poke 1733 xx Player 1 2/3 point scores - x = change to value you want ie. 5
(works off bits so use odd numbers to keep scores different for inside and
outside the box) - Hope you can understand it
TO GIVE OPPONENT / COMPUTER PLAYER ZERO ENERGY
Type in the INFINITE ENERGY pokes
<1C4E> C3 22 87
THEN add this extra poke...
Poke 1C51 AF if you want your opponent to always have zero energy
SCORE POKES
Change value of 2 point shots as the other pokes were for 1 and 3 point shots.
poke 175E 0E
Poke 175F XX X=points you want instead of 2 (2point shots)
TO STOP TRAVELS & OUT OF COURT
Poke 1694 AF
Poke 16A2 C9
Stops travelling, fouls, outs etc..
But it will be probably be for both players. Also when you score it will not reset the players to their starting points and you continue at the basket but you want that anyway?!
- CPC4EVA
 Sujet du message : Re: Basket Master
Message Publié : 19 Jan 2009, 19:26
Message(s) : 3614
POKE(S) pour le jeu AMSTRAD CPC "BASKET MASTER"
SURPISE! : POKE &0999,&25
