1 REM vies infinies pour solomon's key 2 REM version disquette 10 MODE 0:BORDER 0:FOR i=0 TO 15:READ a$:INK i,VAL("&"+a$):NEXT 20 DATA 0,3,6,c,f,18,1a,d,19,10,e,2,1,1,4,4,7 30 OUT&FA7E,1:FOR i=&8604 TO &8604+907:READ a$:a=VAL("&"+a$) 35 POKE i,a:b=b+a:NEXT:POKE &8603,&F3 40 FOR i=&A000 TO &A017:READ a$:POKE i,VAL("&"+a$):NEXT 50 IF b<>101161 THEN PRINT"ouille erreur dans les datas":END 60 CALL &8603 70 DATA dd,21,73,89,dd,66,00,dd,23,dd,6e,00,dd,23,22,45,89,5d,cd,89,88,21,42,89 80 DATA 35,ca,25,87,21,43,89,35,20,17,21,d3,84,af,46,23,ae,23,f5,e5,cd,32,bc,e1
1 :' Solomon's key - tape 2 :' by Phil Howard 710 IF y=4856 THEN 810 720 PRINT"ERROR IN KEY":END 730 :' 740 DATA 11,DA,81,1A 745 DATA 21,87,6A,51 750 DATA 68,3C,12,B4 755 DATA E3,A5,52,15 760 DATA 55,11,45,11 765 DATA 1B,42,41,4C 770 DATA 53,97,42,5B 775 DATA E9,48,6C,51 780 DATA 26,51,44,57 785 DATA 5B,41,E4,5A 790 DATA B6,B2,D6,25 795 DATA 46,61,17,D4 800 DATA 19,A1,00 810 :' 820 :'**** CHEAT **** 830 :' 840 y=0:RESTORE 910 850 FOR x=&BE80 TO &BE9D 860 READ a$:a=VAL("&"+a$) 870 POKE x,a:y=y+a:NEXT 880 IF y=3207 THEN 960 890 PRINT"ERROR IN CHEAT":END 900 :' 910 DATA 21,39,7d,CD 915 DATA 44,43,C3,D5 920 DATA 42,21,92,be 925 DATA 22,31,87,c3 930 DATA 5d,85,cd,a0 935 DATA 8c,3e,7f,32 940 DATA 47,01,32,60 945 DATA 07,c9 950 :' 960 MEMORY &1FFF 970 LOAD"SOLOMON'S KEY" 980 MODE 1:PRINT"Don't Panic..this takes FOREVER.. 990 CALL &BE80 1000 END
1 :'Solomons Key (tape) 2 :' 5 :'By Johnny & Kim Olsen 6 :'Hovedgaden 47A 7 :'3460 Birkerod 8 :'Denmark 9 :' 10 :'***** lock ***** 20 :' 30 y=0:RESTORE 100 40 FOR x=&4200 TO &4386 50 READ a$:a=VAL("&"+a$) 60 y=y+a:POKE x,a:NEXT 70 IF y=37465 THEN 590 80 PRINT"Error in lock":END 90 :' 100 DATA fe,00,20,03 105 DATA c3,3b,43,fe 110 DATA 01,20,07,dd 115 DATA 36,0f,f6,0e 120 DATA 10,c9,fe,02 125 DATA 20,07,dd,36 130 DATA 0c,f9,0e,0d 135 DATA c9,fe,03,20 140 DATA 0f,dd,36,1e 145 DATA e9,dd,7e,0c 150 DATA d6,10,dd,77 155 DATA 0c,0e,1f,c9 160 DATA fe,04,20,07 165 DATA dd,36,11,f6 170 DATA 0e,12,c9,fe 175 DATA 05,20,07,dd 180 DATA 36,10,f6,0e 185 DATA 11,c9,fe,06 190 DATA 20,07,dd,36 195 DATA 0d,f8,0e,0e 200 DATA c9,fe,07,20 205 DATA 07,dd,36,1b 210 DATA ee,0e,1c,c9 215 DATA fe,08,20,07 220 DATA dd,36,0e,f7 225 DATA 0e,0f,c9,fe 230 DATA 09,20,07,dd 235 DATA 36,23,c0,0e 240 DATA 24,c9,fe,0a 245 DATA 20,13,dd,e5 250 DATA e1,11,06,00 255 DATA 19,7c,d6,10 260 DATA dd,75,15,dd 265 DATA 77,16,0e,17 270 DATA c9,fe,0b,20 275 DATA 13,dd,e5,e1 280 DATA 11,06,00,19 285 DATA 7c,d6,10,dd 290 DATA 75,14,dd,77 295 DATA 15,0e,16,c9 300 DATA fe,0c,20,13 305 DATA dd,e5,e1,11 310 DATA 07,00,19,7c 315 DATA d6,10,dd,75 320 DATA 10,dd,77,11 325 DATA 0e,12,c9,fe 330 DATA 0d,20,0f,dd 335 DATA 7e,03,d6,10 340 DATA dd,77,03,dd 345 DATA 36,1a,e9,0e 350 DATA 1b,c9,dd,36 355 DATA 1d,20,dd,36 360 DATA 1e,eb,0e,1f 365 DATA c9,f3,21,39 370 DATA 7d,11,39,5d 375 DATA 00,01,00,0d 380 DATA ed,b0,21,36 385 DATA 6d,11,37,6d 390 DATA 01,00,10,36 395 DATA 00,ed,b0,36 400 DATA c3,23,36,34 405 DATA 23,36,43,21 410 DATA d5,42,11,39 415 DATA 6d,01,0d,00 420 DATA ed,b0,21,40 425 DATA 6d,36,eb,21 430 DATA 50,7d,11,50 435 DATA 6d,01,15,00 440 DATA ed,b0,21,ff 445 DATA 40,dd,21,58 450 DATA 7d,23,e5,7e 455 DATA cd,00,42,dd 460 DATA e5,e1,5d,7c 465 DATA d6,10,57,06 470 DATA 00,dd,09,ed 475 DATA b0,ed,73,00 480 DATA 40,c3,39,6d 485 DATA ed,7b,00,40 490 DATA e1,18,de,e1 495 DATA ed,4b,02,40 500 DATA d9,c3,89,be 505 DATA 22,d7,42,7c 510 DATA d6,10,67,22 515 DATA fb,42,22,32 520 DATA 43,e5,7c,d6 525 DATA 10,67,22,da 530 DATA 42,e1,2b,2b 535 DATA 2b,22,e3,42 540 DATA 23,22,e6,42 545 DATA 11,09,00,19 550 DATA 22,03,43,11 555 DATA 10,00,19,22 560 DATA 0b,43,11,00 565 DATA 10,19,22,08 570 DATA 43,11,08,00 575 DATA 19,22,17,43 580 DATA f3,d9,ed,43 585 DATA 02,40,c9 590 :' 600 :'***** KEY ***** 610 :' 620 y=0:x=&4100:RESTORE 740 630 WHILE a$<>"00" 640 READ a$:y=y+VAL("&"+a$) 650 POKE x,VAL("&"+LEFT$(a$,1)) 660 POKE x+1,VAL("&"+RIGHT$(a$,1)) 670 x=x+2:WEND 680 :' 690 :'---------------------------------- 700 :' 710 IF y=4856 THEN 830 720 PRINT"ERROR in key":END 730 :' 740 DATA 11,DA,81,1A,21,87 750 DATA 6A,51,68,3C,12,B4 760 DATA E3,A5,52,15,55,11 770 DATA 45,11,1B,42,41,4C 780 DATA 53,97,42,5B,E9,48 790 DATA 6C,51,26,51,44,57 800 DATA 5B,41,E4,5A,B6,B2 810 DATA D6,25,46,61,17,D4 820 DATA 19,A1,00 830 :' 840 :' *** Cheat *** 850 :' 860 tot=0:addr=&BE80:RESTORE 920 870 READ a$ 880 IF a$="end" THEN GOTO 905 890 b=VAL("&"+a$):POKE addr,b 900 tot=tot+b:addr=addr+1:GOTO 870 905 :' 910 IF tot<>9342 THEN PRINT"ERROR in Cheat":END 920 DATA 21,39,7D,CD,44,43 930 DATA C3,D5,42,21,BE,BE 940 DATA 22,31,87,C3,5D,85 950 DATA 21,81,03,3A,6B,23 960 DATA E6,08,20,04,CB,A6 970 DATA 18,15,3A,6C,23,E6 980 DATA 08,20,11,3A,05,02 990 DATA FE,02,20,05,3E,2C 1000 DATA 32,05,02,CB,E6,CD 1010 DATA 7E,03,CD,67,26,C3 1020 DATA 17,26,CD,A0,8C,3E 1030 DATA 2C,32,84,03,3E,C3 1040 DATA 32,14,26,21,50,00 1050 DATA 22,15,26,EB,21,92 1060 DATA BE,01,2C,00,ED,B0 1065 :'Infinite lives 1070 DATA 3E,00,32,53,31 1075 :'Infinite time 1080 DATA 3E,00,32,A6,08 1085 :'Infinite fireball's 1090 DATA 3E,00,32,59,36 1100 DATA 32,67,36,32,68,36 1105 :'Don't delete 1200 DATA c9,end 1210 MEMORY &2000 1220 LOAD"SOLOMON'S KEY" 1230 MODE 1:PRINT"Don't Panic...This takes forever" 1240 CALL &BE80
- ASTUCES - * CHEAT MODE (Vies infinies) : Faire un score au minimum de 5000 points pour rentrer dans le high-score, saisir comme nom 'CAZ'. (Aucun son ou message ne viendra confirmer l'activation)
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 34 invité(s)
