1 :' DIZZY -tape- 2 :' By Graham Smith 3 :' Infinite lives 4 :' Shortens built in cheat 5 :' To use:- pause game. Press T 6 :' Press Z,X,K,M to change screens 7 :' Press space to restart 8 :' Method 1 9 :' 315 10 FOR j=0 TO 44:READ a$ 20 x=VAL("&"+a$):y=y+x 30 POKE j+48640,x:NEXT j 40 IF y<>4086 GOTO 150 50 MEMORY 14900:LOAD" 60 CALL 48640 70 DATA 2a,38,bd,22,2d,be 80 DATA 21,37,bd,36,c3,23 90 DATA 36,1b,23,36,be,21 100 DATA 40,00,e3,11,00,bb 110 DATA c3,4a,3a,21,3d,c9 120 DATA 22,34,95,21,a8,75 130 DATA 36,ff,21,00,00,22 140 DATA d0,73,cf 150 PRINT"DATA ERROR
1 ' Dizzy-tape 2 ' by Matt Cawley 3 ' 10 MEMORY &3000:addr=&BF00 20 READ byte$ 30 IF byte$="CM" THEN 70 40 byte=VAL("&"+byte$) 50 POKE addr,byte 60 addr=addr+1:GOTO 20 70 LOAD"":CALL &3AB0 80 LOAD"!",&3040 90 CALL &BF00 100 :' The Key 110 DATA 01,c8,01,11,37,bd 120 DATA 21,2d,bf,ed,b0,01 130 DATA ee,01,21,40,30,11 140 DATA 40,00,ed,b0,21,40 150 DATA 00,e5,21,00,bb,e5 160 DATA 21,ee,01,e5,21,07 170 DATA b8,e5,21,bb,02,e5 180 DATA f1,f3,c9,af 190 :' the pokes 195 REM Infinite Lives 200 DATA 32,c2,9b 205 REM Fast Game 210 DATA 32,b3,8f 215 REM Fast Music 220 DATA 32,8d,9c,32,9f,9c 225 REM Slow Music 230 DATA 32,ad,9c 235 REM No Nasties 240 DATA 3e,c9,32,72,80 245 REM Game Completed 250 DATA 3e,c9,32,97,80 260 REM Leave 270 DATA 3e,cf,32,37,bd,3e 280 DATA 88,32,38,bd,32,39 290 DATA bd,c3,37,bd,CM
R, GET GREASE GUN, R, R, USE GUN ON CART, D, GET KEY, U, Lx10, USE KEY ON DOOR, R, R, U, GET SPADE, D, R, USE SPADE BELOW SPIDER, D, GET TROWEL, USE TROWEL ON UPPER MUSHROOM, R, R, GET CUTTERS, L, L, U, Lx7, D, L, L, DROP CUTTERS ON CHAINS, L, L, GET WIG, Rx4, U, Rx3, DROP WIG IN POT, Lx3, D, D, GET RAINCOAT, U, U, Lx3, U, TAKE DRY ICE, D, Rx3, D, Lx4, USE DRY ICE, L, TAKE AMULET, Rx5, U, DROP AMULET, D, R, GET GUN, L, D, KILL GHOST, R, D, GET GOLD, U, L, U, U, Rx9, DROP GOLD IN BUCKET, GET LINING, Lx6, DROP LINING IN POT, Lx3, D, D, Rx3, GET OIL, Lx3, U, U, Rx13, DROP OIL ON DRAWBRIDGE, TAKE FEATHER, Lx10, DROP FEATHER IN POT, Rx12, TAKE TROLL BREW, Lx12, DROP BREW IN POT, R, TAKE TORCH, L, LIGHT FIRE UNDER POT, R, R, TAKE FLASK, L, L, DROP FLASK ON POT, L, L, L, TAKE AMULET, Rx14, U, R, DESTROY FIREBALLS, L, D, Lx11, TAKE FLASK, Rx11, U, R, DROP FLASK BY ZAKS......Done It!!
Note: Several objects are useful in this game, but are not vital to complete the adventure. Just for the record, these are:
CLOVE OF GARLIC - Kills bats INSECTICIDE - Kills Spiders BIRD SEED - Kills...er...Birds PICKAXE - Unblocks tunnel, to get dagger HARD HAT - Destroys falling stalactites EMERALD - Drop on yellow statue to enter tomb
• Go left into the village. • Collect the grease gun and go left to the mine. • Drop the grease gun next to the cart. • Enter the mine and go right and get the ghost hunter's laser. • Go left then down. • Kill the ghost by falling on top of it. • Go right and down and collect the purse of gold. • Get out of the mine and go back to where you started. • Go right to the old tree house. • Stand on cup and get gold. • Get to the top of the tree house and jump up. • Collect the cloud silver lining and go to the start screen. • Drop the silver lining in the cauldro: • i Jo right and collect the burning torch. • Stand next to the cauldron and drop the torch. • Go above the mine and collect the Acme bird seed. • Make your way to Dizzy's End killing the birds on the way. • Drop the seed, go back to the mine and get the key. • Go to Dizzy's End. • Dodge the raindrops and open the door. • Get the birdseed and go right twice killing the birds. • Get the Vampire Dux feather and go to the start. • Drop the feather into the cauldron. • Go to the place where the ghost was in the mine then right three times. • To get past the little river jump straight up in the air. • Get the 3 in 1 oil. • Go to Dizzy's End then through the graveyard to the drawbridge. • Drop the oil and go across the drawbridge. • Use the insecticide to kill spiders. • Go up the stairs and right to collect the troll brew then back to the start. • Drop the brew into the cauldron. • Go right five times and climb the tree. • Collect the spade and climb back down. • Go left stand in the middle of the screen and drop the spade. • Fall down the hole. • Work your way to the trowel. • Drop it on the springy mushroom under the hole. • Stay in the caves and go right twice to get the cutters. • Exit the caves and go to the mine where the key was. • Go right twice. Drop the cutters on the chain. • Make your way to the leprechaun's wig. • Go back to the start and drop it in the cauldron. • Go to Zak's castle and collect the broken he. • Go to the screen left of the drawbridge and give the woman the heart. • Go down the hole again and get the diamond. • Go to the start the left five times. • Drop the diamond on the thin ice above the lift. • Go left and up and get the bottle of dry Ice. • Go to where you smashed the ice and fall down. • Go left to the red box. • Drop the dry ice and walk across the water when it has hardened. • Go left and down the hole to get the amulet. • Go back to Zak. • Let two bolts hit you then drop the amulet. • Go back to the collapsible bridge. • Collect the potion. • Drop it on the cauldron and pick up again. • Go to Zak and drop the bottle near him. • The game is complete. • That was easy • Yes, it was.
CHEAT: On the title screen press SPACE to start the game. Keeping your finger on SPACE press Q , to quit, continue keeping your finger on SPACE and the the game will restart, then pause the game with P and type T,R,O,W,B,R,l,D,G,E, after the last letter Dizzy should disappear (if not, something went wrong!). Use the keys Z,X,K and M to move location, use ENTER for extra lives, and, use the SPACE to restart in your chosen location.
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 56 invité(s)
