10 REM Switch Blade 20 REM by 30 REM Stephen Troup. 40 ùTAPE:MEMORY &13FF 50 LOAD"!loader .bin" 60 a=&9F00 70 READ b$:IF b$="ST" THEN CALL &9F00 80 POKE a,VAL("&"+b$) 90 a=a+1:GOTO 70 100 DATA 21,09,9f,22,a6,9c 110 DATA c3,40,9c 120 REM Infinite Lives. 130 DATA af,32,ac,30 140 REM Infinite Weaponry. 150 DATA af,32,2b,25 160 REM Infinite Energy. 170 DATA 3e,c9,32,73,30 180 REM Monsters die when they appear. 190 DATA 21,18,0a,22,38,3d 200 REM Invulnerability. 210 DATA 3e,34,32,b3,23,32,02,1e 220 DATA 32,ce,2f,3e,48,32,0f,95 230 REM Leave last line. 240 DATA c3,80,c1,ST
CHEAT: Remember some time ago we had a cheat for the cartridge version of Switchblade? Well Adam Noble has supplied a keypress for the tape (and presumably disk also) version of the game, and what do you know ifs almost the same! Get a high score and enter your name as SLEEPY then press the number of the level you want to go to, and keep it down, then press Fire to start - you will start half way your chosen level.
