1. VOREX <- this one it's very close to screen where you begin game 2. RALIQ 3. TALIS 4. ASCIO <- a place where you can find key 5. DULON 6. QUORE <- the core of the planet 7. ELIXA 8. ANGLE 9. KRYZL 10. OPTIK <- the octopus is here 11. AMBOR <- one of the deepest teleporter in the map 12. INDOL 13. SNODY 14. ZODIA <- the most dangerous zone. No platforms and a lot of traps. 15. UPAZZ
Places whes you can find the key and the card: The key: - The screen where is 'Ascio' teleport. - The screen at the left of the core (near 'Quore' teleport). - The screen at the right of the core (you need card to pass through security door)
The card: - [From 'Ascio' teleport] Down, right, Down (ride on platform), right, up. - [From 'Quore' teleport] (ride on platform) right[x3], down, left[x2], down - The screen where you begin. - The screen where is 'Vorex' teleport. - Two screens under 'Ascio' teleport.
How to use the Cheops Pyramids a) When you only have the card Do it only when you need the last item to complete the game. [you'll notice that options 1-4 show the same item ]
b) When you have 2 items b.1) Card and key - Card,key: The pyramid changes the key. [it's useful when you've found 7 or 8 items] - Key,card: The pyramid changes the card.
b.2) Card and anything else - Card,number: The pyramid changes the rightmost item. (a warning: that includes the card and the key -when you've it-) - Card,core piece: The pyramid changes the core. It doesn't mind the order - Card,normal item(*): The pyramid changes the normal item. It doesn't mind the order. (*) = disk, bell, umbrella,... and other objects you can find in this game
c) When you have 3-4 items - Drop the item(s) you don't want to change and then look the part 'when you have 2 items'
Other things - You can drop up to 4 items at the same screen. Pyramids and items that give extra lives (joystick)/ammo,... count as one. (you'll have to get those items first). You'll have to pick up them before you decide to drop all your items in the same screen -to place them in a different order, for example-).
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 28 invité(s)
