Nous sommes actuellement le 09 Sep 2026, 06:31
[WIN32] CPC-EMU
 Sujet du message : [WIN32] CPC-EMU
Message Publié : 05 Déc 2009, 10:05
Keyboard support improved 04.12.2009
At last. I have managed to implement configurable keyboard layouts in CPCemu. I think this improvement has deserved a new version number: v1.7 is out now! The Windows setup program is available in the Downloads section. Take it as an early christmas gift if you like. The Linux version is ready, too, but still needs to get compressed. Should be there after the weekend!
But don't expect too much. Indeed, one has more freedom to configure the keyboard than in the DOS version. However, the different usage of SHIFT in different national layouts causes subtle problems sometimes. If you improve cpcemu.dat significantly, please share your changes with me!
One question to French users: How in the world did/do you reach "@" and "\" on a French CPC?
url : http://www.cpc-emu.org/news.html ;linked:
 Sujet du message : Re: [WIN32] CPC-EMU
Message Publié : 03 Jan 2021, 08:38
Message(s) : 3693
Something is going on here 01.01.2021
After 11 years, CPCemu 2.0 is coming soon. Happy New Year!
src/url: https://cpc-emu.org/news.html
 Sujet du message : Re: [WIN32] CPC-EMU v2.0
Message Publié : 08 Jan 2021, 21:39
Message(s) : 3693
07.01.2021 : CPCemu 2.0 released
I'm proud to present the latest release of CPCemu. It deserves a new major version number.
These are the features of version 2.0:
  • Runs on MacOS, Android, iOS, Linux (x86_64 and ARM, in particular on Raspberry Pi) and Windows
  • Graphics engine overhauled, introducing border, overscan, dynamic horizontal synchronisation (not perfect yet), scan doubling and some optional CRT blurring
  • Completely new CRTC (CPC's graphics chip) emulation, quite accurate, and selectable between CRTC types 0, 1 and 2 (most demos work as on a real CPC)
  • Realistic timing of CPU instructions and interrupts
  • Sound emulation significantly improved, now able to play digitized sounds (such as speech and special effects)
  • Different accelerated modes of operation ("Turbo", with and without CRTC synchronisation)
  • Debugger with optional CRTC single-stepping alongside the CPC screen, including crosshairs indicating the current electron beam position
  • Graphical menu (in addition to function keys)
  • Virtual on-screen joystick on Android and iOS
  • Keyboard configuration improved, enabling easier customization
  • Many small improvements (e. g., correct handling of CPU register R, support for ZIP file archives without external "unzip", V3 Snapshot files) and bug fixes (e. g., floppy disk controller now correctly reads strange sectors such as Speedlock)
src/url: https://cpc-emu.org/download.html
Pasoft
Message Publié : 09 Jan 2021, 02:39
Message(s) : 1
Dear friend,
Good work on making a CPC emulator for Android :D .
The app needs lots of work, as due to touch screens, it is very difficult to browse on menus.
There should be auto-landscape or a setting for that, because starting in portrait mode makes everything too small (useless).
Proposal: disable portrait mode, emulator launch should always be in landscape.
And, where is the folder to add .dsk files? :?
Pete
Message Publié : 09 Jan 2021, 09:37
Function Keys
 F1  Help [Introduction]
 F2  Toggle between CPC screen and message screen (red border) {DOS}
 F2  Toggle between real-time and unlimited-frames-per-second emulation {Non-DOS}
 Shift+F2  Toggle between CPU speed 1x, 3x and 24x at current number of frames per second {Non-DOS}
 F3  [Insert Disk]
 F4  Toggle Sound on/off [Sound enabled]
 F5  [Load Snapshot] (memory dump)
 F6  [Save Snapshot]
 F7  [Setup Menu]
 F8  Reset CPC
 F10 Debug Menu
 F11 Toggle fullscreen mode {Non-DOS only}
 F12 Exit CPCEMU
More detailed instructions may be found in the cpcemu.hlp file
Message Publié : 15 Mars 2021, 20:35
Message(s) : 3693
CPCemu 2.2 released - 14.03.2021
Again, there is a new version of CPCemu with some new features:
  • Setup option to use arrow keys as joystick
  • Main menu improved for small screens (Android, iOS)
  • Improved output in CRT-monitor mode ("Video mode=1", including better window behaviour for desktop versions)
  • Improved emulation of the HSYNC signal ("blacker than black", relevant for some demos as Dreamend)
  • Fixed errors: Folder sharing on Android, sound output, poke database (Android, iOS)
CPCemu 2.1 released - 23.02.2021
Once again, I'm happy to present a new version of CPCemu. New features are:
  • Available also for Linux-x86 (32 Bit) and (soon) Linux-ARM64 (64 Bit)
  • Further features of CRTC (types 0 and 1) and Gate Array implemented (e. g. behaviour of register 6, and the colours)
  • User interface improved: text size on Android and iOS, Drag & Drop of DSK files on Windows, MacOS and Linux
  • The versions for Android and iOS accept DSK and ZIP files from other applications (e. g. downloads from the browser)
  • Further features of the disk controller (FDC) implemented (Orion Prime in the 4 disk version loads correctly now)
  • Multiple improvements (e. g. autostart, green monitor, cassette relay)
Message Publié : 20 Mars 2021, 10:00
Message(s) : 3693
19-03-2021 : WIN32 Portable version; software and manuals all-in-one
20-03-2021 : cpcemu-android-multicpu-2.2.1.apk
Message Publié : 22 Mars 2021, 17:19
Message(s) : 3693
22-03-2021 : cpcemu-linux-arm64-2.2.tar.gz 1.7 MB Software and manuals all-in-one
22-03-2021 : cpcemu-linux-arm-2.2.tar.gz 1.7 MB Software and manuals all-in-one
PhilA
Message Publié : 28 Mars 2021, 15:19
Message(s) : 41
Ça j'avoue qu'un émulateur Amstrad sur mon télephone c'est assez bluffant! :D
Message Publié : 14 Juil 2021, 17:05
Message(s) : 3693
13.07.2021 : CPCemu bug fix release 2.3.2.1 for ARM (Raspberry Pi) released
There was a general problem with director paths on 64-bit Raspberry Pi OS, because the C function "strcpy" (yes, I know it is dangerous) behaves different than in 32 bit and than in any other OS for which CPCemu is provided. This is fixed now.
Besides, the SDL message-box system does not work on 64-bit Raspberry Pi OS, so any messages (error and non-error) are, again (as earlier), output in a terminal window. For all other OS (and probably for other window managers than LXDE) these messages can be displayed by pressing SHIFT while exiting CPCemu.
11.07.2021 : CPCemu 2.3.1/2.3.2 released
These are bugfix releases. They correct the following problems:
  • File handling on systems with a case-sensitive file system.
  • Missing folder "m4" in some Linux packages.
  • Outdated online help on Android.
  • Sound volume very high.
07.07.2021 : CPCemu 2.3 released
After nearly four months of hard work, I'm back with a new version of CPCemu. I'm very proud to present an exclusive feature:
  • Complete emulation of an M4 Board (http://www.spinpoint.org) using a host directory as drive C: (i. e. SD card; even for SymbOS), including network/internet connections, dynamic ROM simulation and (replaceable) Hack ROM (lower ROM). Many thanks to Duke for providing information and staying patient!
  • CRTC emulation of type 0 (register 8) and type 1 (register 6) even better than before.
  • HYSNC and VSYNC emulation still a bit improved.
  • Online help updated.
  • Mouse pointer visible on movements.
  • Correction of many small and big errors (in particular, 576 KB RAM work correctly now for the first time after decades) and improved error reporting.
url/src: https://cpc-emu.org/
Message Publié : 22 Juil 2021, 18:21
Message(s) : 3693
20.07.2021 : CPCemu published in Google Play Store
I hereby announce that CPCemu (v2.3.2.1) has been published in the Google Play Store for Android as my first Android app.
20.07.2021 : CPCemu bug fix release 2.3.2.1 for Linux released 13.07.2021
There was a general problem with directory paths on some Linux systems, because the C function "strcpy" (yes, I know it is dangerous) behaves different than expected. This is fixed now.
Message Publié : 31 Juil 2021, 22:06
Message(s) : 3693
30.07.2021 : CPCemu 2.3.3 released
This release (also available in the Android Play Store) provides:
  • Snapshot sizes of up to 576 K (uncompressed only).
  • Default snapshot size can be changed in configuration file.
  • New option to use on-screen joystick as cursor keys.
  • Several bug fixes, in particular in the context of ROM handling.
url/src: https://cpc-emu.org/news.html
Message Publié : 30 Déc 2021, 11:28
Message(s) : 3693
29.12.2021: CPCemu 2.4 released
Unfortunately, this release took 5 months, but it was a bit difficult. It provides:
  • Original, but virtual CPC keyboard in 4 different languages. Click/touch at the bottom border to get it.
  • Loading firmware ROMs (0 and 255) from the running emulator (setup menu).
  • Upgrade to the latest SDL version (2.0.18). If you don't get the virtual keyboard, the on-screen joystick and the graphical main menu you should consider upgrading your installed SDL version.
  • Correction of many errors (M4 file names, M4 sockets, sound output, restart of emulation, error tolerance, screen layout, Z80 R register).
This release is also available in the Android Play Store.
Message Publié : 14 Août 2022, 18:23
Message(s) : 3693
13.08.2022 : CPCemu 2.5 released
Almost 8 months after the previous release, I'm proud to present a new version. I thought of making it v3.0, but decided to save the new major version number for a new user interface I'm working on. Many thanks go to Vincent Weber for thoroughly and patiently testing the Android version (thus improving the others, too).
Even without a new UI, the current version provides many new features:
  • Floppy LED (visible only with virtual keyboard)
  • Virtual keyboard:
    - adjustable: position, size, transparency
    - persistent: saves position, size, transparency automatically (separately for portrait and landscape on Android and iOS)
    - visual und acoustic (switchable) feedback
  • Virtual joystick in two different sizes
  • Virtual mouse (selectable instead of joystick): AMX, Reisware/Gerdes or Symbiface II (PS/2)
  • Original sounds of disk drive, cassette relay and keyboard (can be switched on and off)
  • Zoom function (display without border), alternating with and without full screen; persistent (separately for portrait and landscape on Android and iOS)
  • Audio emulation deeply revised; output quality significantly improved (you can select from 4 output frequencies)
  • Vortex memory extension SP64...SP512
  • Jarek memory extension 576KB...4096KB
  • Bank-switching speed dramatically improved; correct emulation of C3 mode
  • IPv6-enabled web server similar to M4 board (upload and download into/from the emulator via web interface)
  • Autostart behaviour improved (automatic file selection and deactivation)
  • Minimal audio latency on Android (Oboe)
  • User interface improved on Android/iOS
  • Setup settings are saved immediately
  • First preparations for new user interface
  • Adjusted to SDL version 2.0.22 (which needs to be installed manually on Linux)
  • Fixed bugs: background-foreground-changing behaviour on Android, real-time speed, video output speed (in particular on Android, iOS and MacOS, I think also on the Raspberry Pi), memory leaks, M4 sockets, file access on Android and iOS
url/src: https://cpc-emu.org/download.html
url: https://play.google.com/store/apps/deta ... ons.cpcemu
Message Publié : 14 Avr 2025, 19:16
Message(s) : 3693
13.04.2025 : CPCemu 3.0 released
It took me a long time, but now v3.0 is at last released. Unfortunately, I had to finish a Master's degree first.
The Windows, Android and MacOS versions are available first, the others will follow soon. Besides, I have submitted CPCemu to the Apple App Store for the first time. I hope it fulfils their requirements and is going to be published soon. Of course, I have submitted the update to Google Play, too.
The current version provides these new features:
  • New GUI
  • New debugger/monitor including (re)assembler
  • ROM configuration by GUI
  • Basic V9990 graphics card emulation (primarily for SymbOS)
  • Emulation of Dobbertin HD20 harddisk drive
  • Emulation of keyboard clash
  • Virtual joystick/mouse left/right handles can be swapped
  • New video mode "simple" (should be faster, but that still needs to be proved)
  • IPv6 compatibility (only for the web server, not inside CPC via M4)
  • Usability of joysticks/game controllers improved
  • Mouse emulation (conversion of host mouse) improved, in particular the Symbiface mouse for SymbOS
  • Many bugs fixed (in particular compatibility with Windows 11)
  • Adjusted to SDL version 2.32.4 (which probably needs to be installed manually on Linux)
I am particularly proud of the V9990 emulation, because it worked out of the box with SymbOS 4.0 released in January (the V9990 emulation had already reached its current state two years ago).
url/src: https://www.cpc-emu.org/ ;linked:
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 49 invité(s)
