START.......S - LIFT THUMB - S - GET POLE - N - N - N - CLIMB UP - E - E - E - E - E - E - GET BALLOON - W - W - W - W - W - W - DOWN - DOWN - GET POLE - S - S - W - GET MASK - S - W - HIDE - WAIT - WAIT - E - N - E - N - NE - SEARCH GARBAGE - GET TICKET - PRESS BLUE DOT - SW - S - PUT TICKET IN SLOT - E - S - SE - LOOK INSIDE CAGE - GET KEY WITH POLE - UNLOCK CAGE - OPEN CAGE - ENTER CAGE - GET THE HEADPHONES AND THE BUCKET - S - NW - N – W - W - S - UNTIE BALLOON - BREATH HELIUM - SPEAK TO HARRY - S UNLOCK COMPARTMENT - OPEN IT - GET WHIP - W - WEAR MASK - KNOCK ON THE DOOR - GO IN - CLOSE DOOR - LOOK IN THE ASH - GET NEWSPRINT - WAIT - LIFT WALL - CRAWL UNDER IT - GET TRAP - WAIT - (SOMETIMES 4X) - FEEL THE ROLE - UNSET THE TRAP - PUT THE CHEESE IN TRAP - REMOVE THE MEAT - DROP TRAP.
E - W - E - W - GET MOUSE WITH BUCKET - E - N - E - PUT TICKET IN SLOT - E - S - GET MOUSE FROM BUCKET - GIVE MOUSE TO HANNIBAL(2X) - LOOK - N - E - E - N - SE - GET STOOL - NW - S - W - W - W - N - N - UNLOCK LION CAGE - OPEN CAGE - ENTER CAGE - WHIP THE SMOOTH LION (3X) - OPEN GRATE - PUT THE MEAT INTO PASSAGE - GO OUT - GO IN - CLOSE GRATE - LOOK UNDER THE STAND - OUT - S - S - W - S - GIVE CASE TO HARRY - N - E - PUT TICKET IN SLOT - E - E - S - SHOW CASE TO ANDREW - GIVE CASE TO JENNIFER - UP - GET ALL - LOOK INSIDE POCKET - GET VEIL - UP - N - N - GIVE TICKET TO RIMSHAW - RIMSHAW,HYPNOTICE ME - STAND - E - UP - E - PASS MONEY THROUGH CROWD - DOWN - E - UP - E - DOWN - S - GET INTO LONG LINE - WAIT(UNTIL YOU SEE A SHORT LINE) - GO IN SHORT LINE - WAIT (3X) - GO OUT SHORT LINE - GO IN LONG LINE - GO OUT LONG LINE - (DO THIS SO LONG UNTIL YOU HEAR A VOICE,IN SHORT,OUT SHORT,IN LONG,OUT LONG,IN SHORT) - YES - NOW GO AGAIN IN THE LINES AND OUT THE LINES UNTIL YOU CAN BUY BANANAS - REMOVE CHOCOLATE - DROP BANANAS.
N - HELLO HAWKER - (NOW WALK AROUND UNTIL YOU ARE BACK TO RIMSHAW) - STAND - S - W - CRAWL UNDER TENT - SEARCH GARBAGE - DROP WHIP - DROP POLE - GET GRANOLA - CRAWL BACK - S - S - SW - N - PUT TICKET IN SLOT - E - E - E – N - SE - SHOW GRANOLA - HELLO TINA - GET HAND - KISS TINA - NW - GET RADIO - OUT - W - W - S - SE - DROP ALL - GET RADIO AND HEADPHONES - CLIMB ON CAGE - CLIMB LADDER - TURN DIAL TO 1170 - REWIND TAPE - RECORD THE MUSIC – WAIT (UNTIL THE TAPE IS FINISHED) - REWIND TAPE - DOWN - DOWN - LOOK - GET ALL - NW - UNLOCK CAGE - OPEN CAGE - ENTER CAGE - PLAY TAPE - WAIT - LOOK UNDER STRAW - OPEN TRAP_DOOR - GET RIBBON - OUT - SE - SLIDE TICKET UNDER FRONT - GO IN - GET TICKET - BET $1 - (NOW PLAY UNTIL YOU WIN)NOW:OPEN PANEL - OUT - NW - SW - WAIT - NE - SE - SLIDE TICKET UNDER FRONT - GO IN - LOOK UNDER TABLE - GET CASE - WAIT - OUT - DROP ALL.
CLIMB UP - CLIMB LADDER - GO HOLE - WAIT(2X) - GRAB SHAFT - PULL SHAFT - DOWN - DOWN - GET ALL - NW - SW - DROP ALL - CLIMB LADDER - OPEN PANEL - KNOCK ON DOOR - GO IN - LOCK DOOR - GET SPREADSHEET - MOVE DESK - UP - DOWN - GET ALL - N - FILL BUCKET WITH WATER - S - NE - N - POUR WATER OVER DETECTIVE - ASK DETECTIVE ABOUT BILLY - DROP STOOL AND RADIO - GET NOTE AND CARD - READ SPREADSHEET - S - SW - N - W - S - ASK HARRY ABOUT EDDIE - W - S - E - HELLO EDDIE - GIVE CARD AND NOTE TO EDDIE - GIVE SPREADSHEET TO EDDIE - GIVE NEWSPRINT AND THE RIBBON TO EDDIE - WEAR DRESS_SUIT - WEAR SHAWL_JACKET - WEAR VEIL - WEAR RIBBON - KNOCK ON DOOR - GO IN - CLOSE DOOR - GET CROWBAR - GET HEAD - OPEN DOOR - OUT - W - OPEN DOOR - GO IN - GET THUMB - OUT - E - GO IN - PUT THUMB IN HOLE - WAIT - GET CHELSEA - OUT.
N - E - NE - SW - N - N - N - CLAP HANDS - ROUSTABOUT,GET NET - WAIT - S - S - S - NE - N - DROP ALL - GET RADIO - S - SW - N - N - N - ENTER CAGE - GET STAND - OUT - DROP STAND - STAND ON IT - CLIMB UP - UP - TURN RADIO ON - REMOVE SHAWL-JACKET - REMOVE DRESS-SUIT - REMOVE RIBBON - REMOVE VEIL - DROP SHAWL-JACKET AND DRESS-SUIT - DROP VEIL AND RIBBON - E - W - W - W - W - DOWN - DOWN - (IF YOU DROPPED THE RADIO THEN PICK IT UP HERE) - S - S - S - PHONE STATION - OUT - N - N - N - STAND ON STAND - UP - NOW GO EAST UNTIL THE GIRL IS FALLING DOWN - WAIT UNTIL YOU FALL DOWN!!!
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 62 invité(s)
