The Amstrad CPC/Plus is an old 8-bit microcomputer. It's still used nowadays by some people to create demos. However, there are almost no tools to do that under Linux. This project aims to collect the various bit of existing sourcecode in one common place, add the missing features, and make life easier for all developpers.
The goal is to provide easy-to-use cross development tools for the Amstrad under Linux, to speed up development of your demos and games. Most of these tools are designed to be used from a makefile and are only useable from the command line. Amongst other things, you will find an image converter, an image viewer, the first tool for reading and writting floppies from an usb drive (limited to romdos d1 disks), a new version of Caprice with some improvements, and a port of ramlaid's Cpctools to Linux.
-BuildCaprice Instructions to build caprice -BuildCPCTools How to build the cpctools chain -CapriceCompatibilityChart List of CPC programs that work and that don't in CapriceReloaded -OtherTools Some other tools you may find useful -CapriceReloaded Amstrad CPC Emulator -cpcfs Dsk image and real floppy management -gfx2crtc Converts pictures from png to scr suitable for displaying on the CPC.
ca bouge sur le projet cpcsdk ..
* r216 (More improvements to CRTC1 emulation. Vanity logo in from sc...) committed by pulkomandy - More improvements to CRTC1 emulation. Vanity logo in from scratch shows up, but there is a weird VBL getting on screen. Probably related to R9 handling... * r215 ([Reloaded] * Emulator class modified to singleton object. ) committed by teppicymon - [Reloaded] * Emulator class modified to singleton object. * issue 19 (Handle interlaced mode) reported by pulkomandy - CRTC 0 and 1 have broken support for Reg8 interlaced mode. Still they have an effect... This is completely ignored in caprice ! Add it (with the subtle differences between the two types of crtc). * r214 ([Reloaded] * fileutils.cpp : add absent header (problem with...) committed by teppicymon - [Reloaded] * fileutils.cpp : add absent header (problem with some toolchain) * WXEmulator::Pause() is not an inline function for the moment, cause problem with some toolchain. * r213 (Some more fixes. "From Scratch" and "DTC" now detects us as ...) committed by pulkomandy - Some more fixes. "From Scratch" and "DTC" now detects us as CRTC1. Now to display correct things... * r212 (Work in progress for CRTC1 emulation. Still some things are ...) committed by pulkomandy - Work in progress for CRTC1 emulation. Still some things are missing... * issue 18 (Different CRTC types and amstrad Plus Support) Labels changed by pulkomandy - Labels: Component-caprice * issue 18 (Different CRTC types and amstrad Plus Support) reported by pulkomandy - Only CRTC0 is emulated for now. This is not acceptable for demomakers. * issue 16 (Caprice won't build with new ide and cli disabled) Status changed by pulkomandy - Fixed, finally ! Status: Fixed * r211 (Cleaner way to draw the "paused" image in wxgui for caprice....) committed by pulkomandy - Cleaner way to draw the "paused" image in wxgui for caprice. * r210 (Cleanup. Make Caprice build again with cli disabled. ) committed by pulkomandy - Cleanup. Make Caprice build again with cli disabled.
le changelog, apparemment ca avance sur le mode debug ...
* r234 (FDC "Led" in wx gui is no longer updated via active polling ...) committed by pulkomandy - FDC "Led" in wx gui is no longer updated via active polling FDC "Led" in wx gui is no longer updated via active polling * r233 ([Reloaded] * Now assembler is include only if cli or ide was...) committed by teppicymon - [Reloaded] * Now assembler is include only if cli or ide was present. * Correct bug from bad revert. * Remove useless depandancy when ide is desactivated. [Reloaded] * Now assembler is include only if cli or ide was present. * Correct bug from bad revert. * Remove useless depandancy when ide is desactivated. *BuildCaprice (Instructions to build caprice) Wiki page edited by teppicymon - Revision * r232 Edited wiki page through web user interface. Revision r232 Edited wiki page through web user interface. * r231 ([Reloaded] * Modify default autotools configuration * Remove...) committed by teppicymon - [Reloaded] * Modify default autotools configuration * Remove segfault bug when IDE was close (faulty destructor) * IDE now optional [Reloaded] * Modify default autotools configuration * Remove segfault bug when IDE was close (faulty destructor) * IDE now optional * r230 (Revert all this mess... ) committed by pulkomandy - Revert all this mess... Revert all this mess... * r229 (Moved wx into gui/wx folder. Commit needed to get rid of som...) committed by pulkomandy - Moved wx into gui/wx folder. Commit needed to get rid of some remaining .svn before I make the compilation work again. Moved wx into gui/wx folder. Commit needed to get rid of some remaining .svn before I make the compilation work again. * r228 (Removed useless debug ) committed by pulkomandy - Removed useless debug *r227 (Fixed disassembly of LD B,xx and possibly some other problem...) committed by pulkomandy - Fixed disassembly of LD B,xx and possibly some other problems. Fixed disassembly of LD B,xx and possibly some other problems. * r226 (Fixed bank memory display in memory debug window. ) committed by pulkomandy - Fixed bank memory display in memory debug window. Fixed bank memory display in memory debug window. * r225 (Fix memory PAL addressing. ) committed by pulkomandy - Fix memory PAL addressing. Fix memory PAL addressing. * r224 (Colorize memory view depending on the type of memory (lorom,...) committed by pulkomandy - Colorize memory view depending on the type of memory (lorom, hirom, expansion, normal). Colorize memory view depending on the type of memory (lorom, hirom, expansion, normal). * r223 (WIP window for CRTC missing regs and GA regs. ) committed by pulkomandy - WIP window for CRTC missing regs and GA regs. WIP window for CRTC missing regs and GA regs. * r222 ([Reloaded] * Ouups... forget to remove debug message... ) committed by teppicymon - [Reloaded] * Ouups... forget to remove debug message... [Reloaded] * Ouups... forget to remove debug message... * r221 ([Reloaded] * Correct an horible bug in timer... ) committed by teppicymon - [Reloaded] * Correct an horible bug in timer... [Reloaded] * Correct an horible bug in timer... * r220 (-Cleaned up the "register debug" window -Added Interrupt inf...) committed by pulkomandy - -Cleaned up the "register debug" window -Added Interrupt info to z80 screen -Some misc. crtc fixes. -Cleaned up the "register debug" window -Added Interrupt info to z80 screen -Some misc. crtc fixes. * r219 (Fixed noise generator again. Thanks Grim! ) committed by pulkomandy - Fixed noise generator again. Thanks Grim! Fixed noise generator again. Thanks Grim! * r218 (-Switch stsound to float mode as this gives better results -...) committed by pulkomandy - -Switch stsound to float mode as this gives better results -Fix noise generator -Switch stsound to float mode as this gives better results -Fix noise generator * r217 ([Reloaded] * Some code source cleaning. * Add a timer class,...) committed by teppicymon - [Reloaded] * Some code source cleaning. * Add a timer class, make modification for portability easier. [Reloaded] * Some code source cleaning. * Add a timer class, make modification for portability easier. * r216 (More improvements to CRTC1 emulation. Vanity logo in from sc...) committed by pulkomandy - More improvements to CRTC1 emulation. Vanity logo in from scratch shows up, but there is a weird VBL getting on screen. Probably related to R9 handling... More improvements to CRTC1 emulation. Vanity logo in from scratch shows up, but there is a weird VBL getting on screen. Probably related to R9 handling... * r215 ([Reloaded] * Emulator class modified to singleton object. ) committed by teppicymon - [Reloaded] * Emulator class modified to singleton object. [Reloaded] * Emulator class modified to singleton object. * issue 19 (Handle interlaced mode) reported by pulkomandy - CRTC 0 and 1 have broken support for Reg8 interlaced mode. Still they have an effect... This is completely ignored in caprice ! Add it (with the subtle differences between the two types of crtc). CRTC 0 and 1 have broken support for Reg8 interlaced mode. Still they have an effect... This is completely ignored in caprice ! Add it (with the subtle differences between the two types of crtc). * r214 ([Reloaded] * fileutils.cpp : add absent header (problem with...) committed by teppicymon - [Reloaded] * fileutils.cpp : add absent header (problem with some toolchain) * WXEmulator::Pause() is not an inline function for the moment, cause problem with some toolchain. [Reloaded] * fileutils.cpp : add absent header (problem with some toolchain) * WXEmulator::Pause() is not an inline function for the moment, cause problem with some toolchain. * r213 (Some more fixes. "From Scratch" and "DTC" now detects us as ...) committed by pulkomandy - Some more fixes. "From Scratch" and "DTC" now detects us as CRTC1. Now to display correct things... Some more fixes. "From Scratch" and "DTC" now detects us as CRTC1. Now to display correct things... * r212 (Work in progress for CRTC1 emulation. Still some things are ...) committed by pulkomandy - Work in progress for CRTC1 emulation. Still some things are missing... Work in progress for CRTC1 emulation. Still some things are missing... * issue 18 (Different CRTC types and amstrad Plus Support) Labels changed by pulkomandy - * issue 18 (Different CRTC types and amstrad Plus Support) reported by pulkomandy - Only CRTC0 is emulated for now. This is not acceptable for demomakers. Only CRTC0 is emulated for now. This is not acceptable for demomakers. * issue 16 (Caprice won't build with new ide and cli disabled) Status changed by pulkomandy - Fixed, finally ! * r211 (Cleaner way to draw the "paused" image in wxgui for caprice....) committed by pulkomandy - Cleaner way to draw the "paused" image in wxgui for caprice. Cleaner way to draw the "paused" image in wxgui for caprice.
