New builds :
Grafx2-svn300-macosx.zip Current official release of Grafx2. MacOSX universal binary. grafx2-svn286-src.tgz Grafx2 beta svn286. Experimental build, use with caution grafx2-svn286-win32.zip Grafx2 beta svn286. Experimental build, use with caution
tjs aussi actif le project Grafx2 arrive en v4
grafx2-svn414-macosx.zip Current official release of Grafx2. Mac OS X universal binary. grafx2-svn411-src.tgz Grafx2 beta svn411. Requires FreeType libs. Experimental build, use with caution grafx2-svn411-win32.zip Grafx2 beta svn411. Experimental build, use with caution grafx2-svn335-BeOS.zip Grafx2 experimental build for BeOS, Zeta, Haiku. Running but quite untested. Please report bugs. grafx2-svn302-amigaos4.lha Grafx2 experimmental build for amiga os 4 Featured grafx2.00b97.0-amigaos4.lha Current official release of Grafx2. AmigaOS 4 binary. grafx2-svn244-source.tgz Current official release of Grafx2. Source snapshot. grafx2.00b97.0-win32.zip Current official release of Grafx2. Windows binary.
update sur différente plateforme + arrivé des versions SKYOS et GP2X
grafx2-svn477-win32.zip Grafx2 beta svn477. Experimental build, use with caution grafx2-svn473-macosx.zip Current official release of Grafx2. MacOS X universal binary. grafx2-svn472-src.tgz Grafx2 beta svn472. Requires FreeType libs. Experimental build, use with caution grafx2-svn468-amigaos4.lha Grafx2 beta svn468. Experimental build, use with caution. grafx2-svn454M-Amiga68k.zip Grafx2 beta svn454. AmigaOS 68k version. Experimental build, use with caution. grafx2-svn464-nottf-gp2x.zip Grafx2 beta svn464. gp2x version. Experimental build, use with caution. grafx2-r457-AROS-i386.tar.bz2 Grafx2 beta svn457. AROS version. Experimental build, use with caution. grafx2-svn454M-MorphOS.zip Grafx2 beta svn454. MorphOS version. Experimental build, use with caution. grafx2-svn447-amigaos4.lha Grafx2 beta svn447. Experimental build, use with caution. grafx2-svn433-skyos.zip Grafx2 beta svn433. SkyOS version. Experimental build, use with caution. grafx2-svn428-BeOS.zip Grafx2 beta svn428. BeOS/Haiku/Zeta version. Experimental build, use with caution.
Grafx2 now fully supports mode 0, 1 and 2 on cpc ! Launch with "grafx2 /rgb 3" and /wide or /tall
r477 (Added palette constraint modes: Run the program with command...) committed by yrizoud Added palette constraint modes: Run the program with command-line option "/rgb <N>" to force RGB components have N levels instead of 256. Ex: /rgb 16 enforces a classic Amiga 4096 color palette, 64is PC VGA, /rgb 3 is Amstrad CPC...)Added missing messages for /wide and /tall command-line arguments.
N'empêche il est super sympa ce petit logiciel, surtout pour faire du mode 0 sur PC avec son option /wide Très pratique, à mettre sur une clef USB pour pouvoir dessiner un peu au boulot
les derniere MAJ :
grafx2-2.0.858-win32.exe Current official release 2.0. Use this one if you want a stable version. Windows installer grafx2-svn859-macosx.zip Current official release 2.0 Mac OS X Universal Binary grafx2-2.0.858-gp2x.tgz Current official release 2.0. Use this one if you want a stable version. GP2X binary.
* Fixed: High CPU usage even when the program is idle ( issue 217 ).
GRAFX 2.1 (13/09/2009)
* New: C64 file formats (Issue 211). * Fixed: Crash with gradient-filled rectangle ( Issue 212 ). * New: Visible tile grid in zoomed view (alt-shift-G). * Fixed: Moving a very large brush in zoomed view would not refresh fast enough ( Issue 183 ) * Improved: Resizable "circle" paintbrush now proposes all diameters, no longer limited to odd ones. * Improved: Resizable "random" paintbrush has a more even flow. * New: Brush container, in Paintbrush screen. Store and retrieve up to 12 brushes. * Improved: Slow operations (ex: circle with big brush and Transparency active) now draws some intermediate steps ( Issue 183 ) * Changed: Color reduction when loading 24-bit BMP PCX or PNG no longer applies Floyd-Steinberg dithering. It picks nearest match instead. * Fixed: greyscale PNG loading. * Improved: PNG 24-bit can now be loaded, with color reduction ( Issue 201 ). * New: Keyboard shortcuts for assigning fixed zoom levels. * Improved: Palette screen remembers if you prefer HSV or RGB. * Fixed: Possible crash in Save/Load screen if directory content was modified ( Issue 198 ) * Improved: You can exit text fields by clicking elsewhere. * Improved: You can now choose a fixed GUI scaling factor ( Issue 101 ) * New: Hold SHIFT while drawing a line finds the closest multiple of 45° or isometric angle. * New: Hold SHIFT while using any other tool to lock X or Y axis ( Issue 193 ) * Fixed: Dragging sliders and clicking color color ranges no longer activate other parts of windows ( Issue 191 ) * Key-combo support to quickly set transparency, ie you can type 3 4 to get 34% transparency ( Issue 154 ) * New keyboard shortcut: All effects off (shift-E) * Gradient-filled rectangle and Gradient menu are now a single button. * New settings screen specifically for the look of the program (font, menu graphics, mouse cursor) : Right-click the Settings button. * New default skin and several alternate fonts, made by Ilkke. * Fixed: Releasing shift control or alt had the extra effect of releasing all mouse buttons ( issue 187 ) * Improved: MacOSX : Configuration is now preserved when upgrading grafx2 ( issue 192 ) * New: Support for loading and saving Neochrome image file format (.NEO files)
There was some bugs left in the first 2.0 release, so we fixed them while working on new features for 2.1. These versions only include the bugfixes, and not the new features. 2.0 will be supported like that until we get 2.1 out. GRAFX 2.00.970 bugfix release (08/06/2009)
* Fixed: Crash in Load/Save dialog when directory content has changed. ( issue 198 )
GRAFX 2.00.951 bugfix release (07/24/2009)
* Fixed: Crash when using pipette on a software-zoomed video mode from the palette screen ( issue 196 )
