Nous sommes actuellement le 10 Mars 2026, 01:01
NECRIS DOME
 Sujet du message : NECRIS DOME
Message Publié : 10 Jan 2009, 21:58
NECRIS DOME (Code Masters)
[This game is a real dud - so don't say I didn't warn you :-)]
(You begin insde a casket), PUSH LID, ENTER CASKET, TAKE GLOVES, PUSH LID,
EXAMINE GLOVES, TAKE AXE, WEAR GLOVES, E, E, PUSH CASKETS, LOOK, EXAMINE
MANDROID, SEARCH MANDROID, LOOK, TAKE ORANGE TRANSROD, TAKE GREY TRANSROD, E, E,
D, W, KILL ROB, EXAMINE ROB, SEARCH JUNK, TAKE MULTI FUNCTI, E, E, E, E, TAKE
SUIT, SPRAY SUIT, DROP AEROSOL, E, TAKE ICE, W, SEARCH, U, N, W, W, W, S,
EXAMINE DIAGRAM (a plan of the power cables), USE MULTI FUNCTI (the panel swings
open), PRESS ONE, PRESS TWO, PRESS THREE, PRESS FOUR, DROP MULTI FUNCTI (RE-
EXERCISER PADS NOW DISABLED), E, EXAMINE UNIT, PUT MANDROID (in unit), LOOK TAKE
BLUE TRANSROD, DROP ICE, N, HIT PIPE (with the axe), EXAMINE MANDROID, SEARCH
MANDROID, LOOK (se green and brown transrods), TAKE GREEN TRANSROD, W, W, W, W
(China 2), E, TAKE METAL, W, W, W (Rec 1), DROP GREY TRANSROD, E, E, S (Amer 9),
TAKE COIL, N, N, N, TAKE POWER CELL, EXAMINE POWER CELL, EXAMINE METAL, EXAMINE
COIL, MAKE MAGNET, TAKE SHELL, EXAMINE SHELL, WEAR SHELL (disguise), TAKE HELM,
E, E, DROP BLUE TRANSROD, E, S, W, EXAMINE VAT, FILL HELM, E, THROW ACID,
EXAMINE MANDROID (see pink and red transrods), DROP HELM, N, W, TAKE BLUE
TRANSRODS, E (Rec 18), W, W, S, W, W, W, W (the magnet scrambles the circuits of
the battle droid - it collapses in a heap), LOOK, SEARCH JUNK, DROP MAGNET, TAKE
OXY ENCHANGER, S, E, TAKE ICE, N, E (Afri 1), DROP GREEN TRANSROD, E, DROP BLUE
TRANSROD, E, S, TAKE RED TRANSROD, TAKE PINK TRANSROD, S, W (India #?), CUT
CABLE, EXAMINE CABLE, N, E, S, OPEN WHITE LOCKER, LOOK, TAKE WHITE TRANSROD, N,
W (Control Level), W (stopped), THROW ICE, W, EXAMINE ARCH MANDROID, SHOOT PIPE,
SEARCH ARCH, DROP WHITE TRANSROD, TAKE KEY, EXAMINE KEY, W, SEARCH, INSERT KEY,
FIRE AT-LAN (now you only have a short time before the dome explodes), E, N
(Afri 2), TAKE BLUE TRANSROD, E (Rec 18), DROP ORANGE TRANSROD, 9*W, ENTER
CASKET
"You hear the explosion, but you are safely jettisoned into space. The oxy-
exchanger gives you adequate oxygen and the homing deivce is functioning. Your
mission has been a total success"
Transrods
Orange W from Rec 7 to Amer 9
E Rec 6 -"-
S Rec 3 -"-
Grey E Rec 2 China 2
S Rec 1 -"-
W Rec 3 -"-
Green W Rec 14 Afri 1
E Rec 10 -"-
Blue E Afri 2 Rec 18
N Afri 7 -"-
Red S Afri 6 India 9
W Afri 11 -"-
E Afri 9 -"-
Brown N Sov 3 Rec 4
Pink N India 4 Afri 2
W India 3 -"-
White W India 7 Control Level
E India 6 -"-
Solution by Jackie Holt
Retyped by Jacob Gunness
http://CPCrulez.2ya.com/
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 38 invité(s)
