This project is a CPLD-based ROM expansion board. Although only 2 sockets are provided each can be filled with a 'double size' EEPROM to provide the equivalent of 4 classic 16KByte Amstrad ROMs.
The board will co-exist with other ROM cards and uses DIP switches to enable or disable ROMs individually and to select how the ROMs on the card will be numbered to avoid clashes with other cards.
This project is a CPLD-based ROM expansion board. Although only 3 sockets are provided each can be filled with a 'double size' EEPROM to provide the equivalent of 6 classic 16KByte Amstrad ROMs.
The two 4 slot cards are identical apart from the pass through connector being replaced by an reproduction of the Amstrad CPC edge connector. This is useful if you need to use any legacy edge connector peripherals as well as the newer MX4 slot types, and particularly for CPC464 users who may have a DDI-1 disk drive controller or DDI-3 USB interface.
The expansion slots on all cards are fully compatible with modern Amstrad CPC Peripherals such as Duke's M4 Card, the X-MEM RAM/ROM board and of course the RAM, ROM and Z80Tube expansions all described in the GitHub repositories here.
All of the above projects have been built and tested.
Eagle PCB files and zipped archives suitable for getting boards made are included in the Eagle Releases subdirectory.
Merci Revaldinho !
Grâce à tant de générosité, on peut acheter sur eBay des extensions RAM ou ROM à 40/50€, des MotherBoard à 40/50€, des PCB nues à 15/20€ ... Tout ce dont on était préservé sur notre machine depuis la MegaFlash... Trop généreux !
Vive les projets libres*. Vive le retour du business retro sur CPC !!!
* Ha oui, "on" est pas responsable de l'usage ni de penser aux conséquences...
TotO a écrit :
Merci Revaldinho !
Et tu fait quoi de tout ceux qui se la fabrique eux même et que tu ne vois pas ?
Il y aura toujours la loi de l'offre et de la demande , toujours des crevards pour profité du système ... A notre niveau ont ne peu qu'aiguiller les gens vers des vendeurs honnête.
marcel a écrit :
statistiquement c'est anecdotique, sinon vous n'auriez pas vendu des centaines de cartes, faciles à réaliser pour certaines
C'est toujours un compromis entre le temps que ça prend et le prix que ça coute. Le côté open-source aura toujours un avantage : si personne ne le propose à la vente, tu peux le faire toi même (sans parler du partage de connaissance).
marcel a écrit :
bon après si on les retrouve avec une marge sur ebay c'est que ça ne produit pas assez en amont
si y avait eu plus de dispo sur le dandanator, zaxxon n'aurait pas fait son coup de vendre le mini au prix du gold toutes options
C'est l'effet j'ai pas le temps de produite/gérer les commandes, je vous laisse vous démerder du HW open source Aprés, le marché fait le reste
Ma préoccupation ici est plutôt : Et l'on fait quoi de ceux qui achètent pour 120/150€ de matos parce qu'ils ne savent pas qu'ils peuvent avoir l'équivalent pour 40/50€ assemblé ou pour 30/40€ en kit. Surtout que ces personnes entrent à un moment où un autre dans la "communauté" et se rendent comptent qu'ils se sont fait "violer" au premier contact avec le monde retro CPC.
Je vais me répéter, mais si j'ai commencé en 2012 à réaliser mes propres extensions, c'est exactement pour m'éviter cela et finalement essayer de le limiter pour d'autres. Après je ne suis pas dupe, on ne peut pas sauver tout le monde... Mais cela n'empêche pas d'avoir une réflection autour des moyens permettant de limiter un problème plutôt que l'amplifier. Aussi, la fatalité c'est pas une solution en soi.
EDIT: Acheter des extensions de plus en plus cher c'est accepter d'acheter la machine pour les brancher de plus en plus cher aussi (on le voit sur Amiga, Mega Drive, etc). C'est une dérive qui nous concerne donc tous indirectement et l'Open Source "tout cuit" n'est pas vraiment une solution à cela.
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 142 invité(s)
