Nous sommes actuellement le 27 Juin 2026, 05:04
HxC Floppy Emulator
Publier un nouveau sujet Répondre au sujet  Page 43 sur 50
 [ 742 message(s) ]  Aller vers la page Précédent  1 ... 40, 41, 42, 43, 44, 45, 46 ... 50  Suivant
Jeff_HxC2001
Message Publié : 14 Oct 2017, 11:41
Message(s) : 269
Manager V3.4 disponible :
http://hxc2001.com/download/floppy_driv ... anager.zip
Les DSKs ne sont plus "masqués".
Jeff_HxC2001
Message Publié : 15 Oct 2017, 14:54
Message(s) : 269
Nouveau firmware corrigeant encore des problèmes avec certains DSK:
http://hxc2001.com/download/floppy_driv ... _notes.txt
Et une nouvelle version du manager :
http://norecess.cpcscene.net/
Jeff_HxC2001
Message Publié : 18 Oct 2017, 08:17
Message(s) : 269
17 October 2017: Firmware STM32 USB HxCFloppyEmulator v3.0.33.1a
- Config-Less Mode :
Use the settings saved into the device internal flash memory and
switch to normal/direct selection mode when no HXCSDFE.CFG are present.
To change settings without config file, just use the embedded config menu
(Remove the USB Stick and press both buttons to enter it).
NOTE : Without HXCSDFE.CFG the last image selection is not saved.
- More CPC DSK format variant support.(again !)
Jeff_HxC2001
Message Publié : 03 Déc 2017, 23:08
Message(s) : 269
03 December 2017: Firmware STM32 USB HxCFloppyEmulator v3.1.0.4a
Major update !
- New direct file formats support (Read & Write !) :
- Acorn machines : *.ADL,*.ADM,*.SSD,*.DSD and *.ADF file support
- Camputer Lynx : *.LDF
- Commodore C64 : *.D81
- Thomson machines : *.FD
- Sam Coupé : *.SAD, *.MGT
- MSX Machines : *.IMG, *.DSK
- Spectrum : *.TRD, *.SDD
- New menu entry : Target system family selection.
This reduce a lot the risk of erroneous raw file identification.
- Lots of RAW file support improvements :
All sector sizes supported, advanced track skew and interleaving support.
FM & MFM support.
- Amstrad CPC DSK support : Fix for the One Disk/double sided Batman demo.
- Fix attempt of the "diymore.cc" OLED screens : OLED init screen delay
menu option added.
(Note : Please avoid these "diymore.cc" screens until i got an idea
what is the root cause of the issue.)
- Internal improvement : Track cache layer improved, RAW files support/identification improved.
Please report any issue to hxc2001 <at> hxc2001.com
Thanks ! :)
Jeff_HxC2001
Message Publié : 10 Jan 2018, 08:35
Message(s) : 269
Nouveau groupe HxC2001 sur Facebook ouvert :
https://www.facebook.com/groups/hxc2001
:D
Message Publié : 24 Jan 2018, 08:33
Message(s) : 3678
USB STM32 HxCFloppyEmulator firmware upgrade v3.0.8.2a + Alpha 3.1.1.1a (HFE + HFEv3 + ADF + ST + IMG + (E)DSK file format support)
21 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.1.2a
- "Load Last selected image" : Save & Restore previous folder position.
15 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.1.1a
- Fix broken Rotary support in normal mode.
(Connection points reminder : Clock -> J7 pin 2,Direction -> J7 pin 1)
17 December 2017: Firmware STM32 USB HxCFloppyEmulator v3.1.1.0a - More direct raw formats support :
- Akai formats (*.IMG)
- Casio FZ1 (*.FZ1)
- Emax machines formats (*.IMG)
- Ensoniq EPS & Mirage series formats (*.IMG)
- General Music formats (*.IMG)
- Korg formats (*.IMG)
- X68000 (*.HDM,*.XDF)
- Internal optimizations.
HxCFloppyEmulator software v2.1.8.0
21 January 2018: HxCFloppyEmulator 2.1.8.0 :
- New Loader : Atari ATR file image loader.
- New Write & Loader : HFE V3 : variable bitrate and other proctections support. (Experimental ! The file format definition is not yet finished !)
- Kryoflux raw files Writer : Fix dead lock with tracks without pulse.
- Amiga DOS image browser : 85 tracks AmigaDos image support.
- Disk Image browser (FAT & AmigaDOS) : Fix null-sized file import issue.
- Disk Image browser (FAT & AmigaDOS) : Can now delete folders.
- All image loaders : Fix possible track skew calculation error.
- Emax image loader : GAP fixed to 30.
- Thomson *.FD loader : Sector interleave set to 7
- Command line tool : -uselayout option can be now used to specify external xml disk layout file.
src/url: http://hxc2001.com/download/floppy_drive_emulator
Message Publié : 17 Fév 2018, 15:01
Message(s) : 3678
Cumulative modifications since the last stable firmware version :
14 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.10.1a
- New interface modes :
IBMPC_DD_HD (PC Mode with auto density selection)
S950_DD_HD (Akai / Shugart-Like Mode with auto density selection)
- New Family :
Ensoniq ASR10 (Ensoniq Auto DD & HD support)
- New 7 segments config menu 1 (Interface mode) entries :
0F = S900/S950 (Density Auto)
10 = PC DD/HD (Density Auto)
- New 7 segments config menu 0 (System family) entry :
11 = Ensoniq ASR10 (Ensoniq Auto DD & HD support)
- Some file system & disks access sanity checks added.
13 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.9.1a
- New menu setting interface menu for normal 7-segments Goteks:
-> To access it, remove the USB Stick and press both buttons.
-> Choose the sub menu number - wait some seconds for the selection validation.
-> Check and/or change the setting - wait some seconds for the selection validation.
The new setting is then saved into the device.
Reminder : To clear all settings to the default values, press the right button at power up.
Current Menu and sub selection definition :
Menu 0 - System family selection :
00 = AUTO (DEFAULT)
01 = Amiga
02 = Acorn
03 = Atari ST
04 = IBM PC AT/XT
05 = Camputer Lynx
06 = Commodore 1581
07 = Thomson
08 = x68000
09 = SAMCOUPE
0A = MSX
0B = Spectrum
0C = Akai
0D = Casio
0E = Emax
0F = Ensoniq
10 = General Music
11 = Korg
Menu 1 - Interface mode :
00 = AUTO (DEFAULT)
01 = IBM PC DD
02 = IBM PC HD
03 = ATARI ST DD
04 = ATARI ST HD
05 = AMIGA DD
06 = AMIGA HD
07 = CPC DD
08 = GENERIC SHUGART DD
09 = IBMPC ED
0A = MSX2 DD
0B = C64 DD
0C = EMU SHUGART
0D = S950 DD
0E = S950 HD
Menu 2 - Write protect mode :
00 = AUTO (DEFAULT)
01 = Write protected.
02 = Write enabled.
Menu 3 - Double Step :
00 = AUTO (DEFAULT)
01 = Single step
02 = Double step
Menus 4<->E : Not currently assigned.
Menu F - Display firmware version
06 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.8.1a
- Raw files : Write sector performance increased. Near Real time sectors write !
05 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.6.0a
- Low level Floppy IO optimizations.
04 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.5.1a
- Raw *.IMG PC Files : Use the DOS 6.22 disk layouts.
- And as always some code optimizations.
02 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.5.0a
- Cache flush fix : Do you not reorder the cache when not needed ( e.g when the track fit the cache size )
- CFG File V1 fix (Autoboot mode) : slots support now file images with 2 characters filename extension...
- More code Speed optimizations. (again ! :) )
01 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.4.0a
- More Code Speed optimizations.
- RAW MFM & FM Images (IMG/ST/...) :
- More Write speed improvement : Sector Data cache prefetch.
31 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.3.0a
- Write speed improvement :
- Track cache workflow improvement.
- Code optimization (CRC16, MFM 2 BIN...).
29 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.2.0a
- *.ST 720KB Files : Switch to the TOS 1.62 Disk Layout.
- RAW files loader : Internal enhancement.
27 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.1.4a
- Config file "Load last loaded floppy" flag is now supported in indexed and file selector mode.
27 January 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.1.3a
- Normal mode Fix : ST files are visible again !
src/url: http://hxc2001.free.fr/floppy_drive_emulator/index.html
Message Publié : 25 Fév 2018, 18:30
Message(s) : 3678
21 January 2018: HxCFloppyEmulator v2.1.8.0
  • New Loader : Atari ATR file image loader.
  • New Write & Loader : HFE V3 : variable bitrate and other proctections support. (Experimental ! The file format definition is not yet finished !)
  • Kryoflux raw files Writer : Fix dead lock with tracks without pulse.
  • Amiga DOS image browser : 85 tracks AmigaDos image support.
  • Disk Image browser (FAT & AmigaDOS) : Fix null-sized file import issue.
  • Disk Image browser (FAT & AmigaDOS) : Can now delete folders.
  • All image loaders : Fix possible track skew calculation error.
  • Emax image loader : GAP fixed to 30.
  • Thomson *.FD loader : Sector interleave set to 7
  • Command line tool : -uselayout option can be now used to specify external xml disk layout file.
25 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.16.1a
  • User interface part : Code Refactored
    - Better buttons behavior.
    - Better/faster rotary behavior.
  • Normal mode : Press both buttons shortly to jump to the first entry of the current folder. ("..")
  • Normal mode : When returning to parent folder ("..") the position in the folder is restored.
  • Autoboot mode : Press both buttons shortly to jump to Autoboot.hfe Press both buttons more than 2 seconds eject/insert the disk.
  • Indexed mode : Press both buttons shortly to jump to DSKA0000.HFE Press both buttons more than 2 seconds eject/insert the disk.
  • 7 segments screen : Now show when an image is inserted ("---") or ejected (" - ")
  • OLED : init algorithm revised for diymore.cc screens. (Press the right button at power up at the first diymore.cc screen installation).
  • Various user interface fixes.
18 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.10.6a
  • Normal mode : key auto-repeat delay increased.
18 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.10.3a
  • Revert filtering changes (Rotary support)
18 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.10.2a
  • Keys debouncing filter increased.
  • Normal mode : Wait the select key release after a directory change.
src/url: http://hxc2001.free.fr/floppy_drive_emu ... l#download
Jeff_HxC2001
Message Publié : 28 Avr 2018, 08:13
Message(s) : 269
Et hop la ! :)
11 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.18.1a
- End part of the read output pipeline reworked (pulses generator).
- Akai S20 IMG images : sectors gap and tracks skew aligned to the real machine.
- Casio FZ1 IMG images : sectors gap and tracks skew aligned to the real machine.
4 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.16.3a
- Fix last the v3.1.16.2a compilation option !
Please update if you have the v3.1.16.2a released yesterday !
3 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.16.2a
- Autoboot mode + 3 Digits Gotek screen : Fix slot number.
If you have any comments or suggestions, requests or issue to report please contact me :
Email : hxc2001 <at> hxc2001.com
Forum : http://torlus.com/floppy/forum
Facebook : https://www.facebook.com/groups/hxc2001
http://hxc2001.com/download/floppy_drive_emulator/HXCFEUSB_HFE_beta_firmware.zip
http://hxc2001.com/download/floppy_drive_emulator/USB_HFE_hxc_floppy_emulator_firmware_release_notes.txt
Jeff_HxC2001
Message(s) : 269
turlututu chapeau pointu ! :D
Jeff_HxC2001 a écrit :
15 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.18.1a
- Normal mode : Remove unwanted key delay when entering in direct mode.
17 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.20.1a
- USB Direct Access mode code refactored :
- Read/write performance increased (hxcmount).
- Command/Write indications printed on the LCD.
- USB access cache : Write timeout value set to 2 seconds.
18 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.21.1a
- Indexed mode : Ignore file extension. You can now use any file extension
as long as the file is supported by the floppy emulation engine.
(Can be DSKA0000.HFE/IMG/DSK/ADF/ADL...)
- Acorn machines (*.ADL, *.ADM, *.ADF):
Sectors gap, interleave and tracks skew aligned to the real machine.
19 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.21.2a
- USB Direct Access mode code : Index gap increased
(Amiga File selector & HxC copy utility under WB fix)
1 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.1a
- TI99/4A : Direct support of *.DSK/*.PC99/*.V9T9 sectors dump images
SD/DD/HD density support (Read & Write).
- New embedded menu entry : You can now force the user interface mode
(Normal/Indexed or selector mode selection).
Jeff_HxC2001
Message Publié : 28 Avr 2018, 08:14
Message(s) : 269
Some updates ! :
3 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.2a
- TI99/4A : V9T9/DSK Loader -> Better disk layout detection.
19 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.3a
- OLED screen setting sanity check : Do not allow more than 21 characters per line.
26 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.4a
- 2 Digits screen Gotek : Fix embedded config menu.
28 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.6a
- HFE files : Fix MPC60 MkII formatted images write support regression.
May also fix possible write issues on HFE files with some others machines/disk formats.
Update recommended.
Message Publié : 30 Mai 2018, 13:55
Message(s) : 3678
27 May 2018: HxCFloppyEmulator 2.1.11.1
- Hard-sectored H8D Heathkit raw file Loader & Writer added !
24 May 2018: HxCFloppyEmulator 2.1.10.1
- Kryoflux Stream Loader (*XX.X.raw) & Stream analyzer : Hard-sectored images support and various fixes !
- Kryoflux Stream Loader (*XX.X.raw) : bmpexport.txt config file to generate the full stream track graph.
- NSI Northstar raw file Loader & Writer added !
12 May 2018: HxCFloppyEmulator 2.1.9.3
- Kryoflux Stream Loader (*XX.X.raw) : Another fix for the index position !
- Kryoflux Stream Loader (*XX.X.raw) : filter.txt config file to adjust the internal bitrate filter.
- Flux Stream Analyzer : Internal filter can now be set.
- ADF Writer : Amiga ADF HD file (22 Sectors/track) support added.
11 April 2018: HxCFloppyEmulator 2.1.9.2
- Kryoflux Stream Loader (*XX.X.raw) : Loader & writer index position fixed.
2 May 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.23.1a
- 7 segments Gotek : New menu entry : 5 -> Auto select delay setting.
- Floppy Interface initialized before the screen. (Fix Emu Emulator second drive detection issue).
- Amiga ID support enabled by default (HD ADF support).
url/src: http://hxc2001.free.fr/floppy_drive_emu ... l#download
Jeff_HxC2001
Message Publié : 19 Juil 2018, 07:54
Message(s) : 269
Some updates ! :
17 June 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.25.1a ( -> In the "Next_WIP_Alpha_Firmware_And_Tools" Folder !)
- Internal improvements.
- "Double steps per increment" rotary support added.
- New menu entries :
- Head settling time. (7 digits gotek meny entry number 6).
- Rotary type. (7 digits gotek menu entry number 7 - 0=Single Step, 1=Double Step, 3=Disable.).
19 June 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.26.1a ( -> In the "Next_WIP_Alpha_Firmware_And_Tools" Folder !)
- Fix the "clear settings"/reset factory function.
15 July 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.26.5a ( -> In the "Next_WIP_Alpha_Firmware_And_Tools" Folder !)
- Thomson *.FD file support : Faster Loading (sectors interleave factor fixed).
Message Publié : 31 Juil 2018, 13:55
Message(s) : 3678
31 July 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.28.1a ( -> In the "Next_WIP_Alpha_Firmware_And_Tools" Folder !)
- Files Browser : All Files/Folders with the hidden attribut set are not shown anymore... (Hide Windows/MAC system folders)
30 July 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.27.1a ( -> In the "Next_WIP_Alpha_Firmware_And_Tools" Folder !)
- Push buttons Auto-repeat : Better/Smoother rate changes. Rate changes delays adjusted.
Message Publié : 31 Juil 2018, 17:12
5 jours auparavant : https://github.com/keirf/FlashFloppy/co ... fdfff6729d
Ya une sacrée taupe si même les versions alpha se font copier en interne.
