Nous sommes actuellement le 10 Sep 2026, 21:53
[EMU] Caprice32 (Colin Pitrat)
 [ 4 message(s) ]
 Sujet du message : [EMU] Caprice32 (Colin Pitrat)
Message Publié : 31 Mars 2017, 07:06
Message(s) : 3695
Caprice32 is a software emulator of the Amstrad CPC 8bit home computer series running on Linux and Windows. The emulator faithfully imitates the CPC464, CPC664, and CPC6128 models. By recreating the operations of all hardware components at a low level, the emulator achieves a high degree of compatibility with original CPC software. These programs or games can be run unmodified at real-time or higher speeds, depending on the emulator host environment.
Caprice32 provides:
  • Complete emulation of CPC464, CPC664 and CPC6128
  • Mostly working support of Plus Range: CPC464+/CPC6128+/GX4000 (missing vectored & DMA interrupts, analog joysticks and 8 bit printer)
  • Joystick support - it can be fully used with joystick only, thanks to an integrated virtual keyboard.
  • Joystick emulation - joystick-only games can be played using the keyboard
  • English, French or Spanish keyboards
  • DSK and IPF files for disks - VOC and CDT files for tapes - CPR files for cartridge
  • Snapshots (SNA files)
  • Direct load of ZIP files (all formats except IPF)
  • Custom disk formats
  • Printer support
  • Memory tool to inspect and modify memory (peek and poke)
  • Experimental support of Multiface 2 (you should prefer using memory tool)
  • Text mode graphics (using aalib or libcaca)
src: https://github.com/ColinPitrat/caprice32
url: https://cpcrulez.fr/emulateurs_download- ... pitrat.htm
 Sujet du message : Re: [EMU] Caprice32 (Colin Pitrat)
Message Publié : 22 Déc 2017, 20:04
Message(s) : 3695
v4.4.0 Build 10-Dec-2017 (x64/x32)
- Support passing commands to the emulator through autocmd command line…
- Support loading IPF files from ZIP
- Fixed virtual keyboard
- Use English keyboard map by default
- Fixed French MS windows map
- Minor fix to audio loop
- More minor timing fixes
- Slight IPF fix
- Support passing CPC_F1 or CPC_F2 to autocmd
- Deactivate MF2 by default
src/url: https://github.com/ColinPitrat/caprice3 ... tag/latest
Shmil
Message Publié : 30 Jan 2018, 09:29
Message(s) : 1
Bonjour :)
J'aime beaucoup cet émulateur, aussi voudrais je savoir s'il existe une documentation détaillée afin d'en maîtriser mieux le fonctionnement.
Merci à vous tous. ;)
Message Publié : 30 Jan 2018, 09:49
dans le sous dossier doc... :cow:
 [ 4 message(s) ]
