Nous sommes actuellement le 04 Mars 2026, 04:59
M4 Board Amstrad CPC WiFi
 Sujet du message : M4 Board Amstrad CPC WiFi
Message Publié : 30 Juin 2016, 13:26
The M4 board, features as previously described a ST32F407 Cortex M4 MCU, connected via SPI to a ESP8266 WIFI module, and 18 GPIO’s routed via a GTL2000 voltage translator chip.
It was meant to be connected to the old the Amstrad CPC (z80 based) computer via it’s expansion port.
As with most old age computers, it runs with 5V I/O, here is where the GTL2000 chip came in handy.
The signals driven through the GTL2000 are output signals and the bi-directional data bus (D0-D7).
Input signals are connected directly to the ST32F407 Cortex M4 as it is 5V tolerant.
The idea was to provide WiFi to the Amstrad CPC, for easy and fast data exchange between it and a PC, but also direct internet access.
Features:
- ROM BOARD emulation
- SD card storage
- WiFi & Internet
- WEB interface
- RTC
What it does
Emulate Romboard, currently up to 16 roms, can be uploaded/removed via Web Interface.
Download files from internet via WiFi.
Mass storage to SD card, via native file I/O. R/W support. Emulated as drive A.
Can use DSK files on the SD card too, but only for file read access and sector reading via firmware call.
Upload files via web interface.
src: http://www.spinpoint.org/2016/05/06/m4- ... -cpc-wifi/
 Sujet du message : Re: M4 Board Amstrad CPC WiFi
Message Publié : 14 Juil 2016, 10:19
Un grand pas en avant dans le domaine du stockage avec cette nouvelle carte m4:
src/url: https://mobile.twitter.com/FranGallegoB ... 9650887684 ;linked:
Message Publié : 27 Juil 2016, 16:13
Le CPC se modernise :).
number-one
Message Publié : 27 Oct 2016, 16:25
Message(s) : 9
Quelqu'un a acheté la carte ?
Message Publié : 27 Oct 2016, 19:21
J'en ai une depuis plusieurs mois maintenant, c'est vraiment top, je n'utilise plus que ça pour transferer des images disk
remax
Message Publié : 30 Oct 2016, 18:49
Message(s) : 228
Pareil, sauf quand ca utilise un loader trop complexe
cyrillem
Message Publié : 01 Nov 2016, 12:51
Message(s) : 10
Que veux tu dire par un "loader trop complexe" ?
remax
Message Publié : 01 Nov 2016, 18:49
Message(s) : 228
En gros, si, pour charger les données sur la disquette, les jeux utilisent une technique trop "maison" ça ne marche pas.
Il faut que ça utilise la voie standard (je suis pas expert pour expliquer donc j'espère que ca te suffit comme explication).
Message Publié : 01 Nov 2016, 19:09
Message(s) : 5125
visiblement la carte n'est pas trop chère , comment ca ce passe pour l'achat ? mp sur cpcwiki ?
remax
Message Publié : 01 Nov 2016, 20:06
Message(s) : 228
Oui. Il me semble que maintenant il construit à la demande.
Duke est très sympa, serviable, assure parfaitement le SAV, (on est plus du côté de TotO que de Piotr quoi :D), ca vaut vraiment le coup !
En plus le développement est très actif actuellement... (encore une beta sortie avant hier)
C'est très marrant de chatter sur IRC avec un CPC :mdr:
cyrillem
Message Publié : 05 Déc 2016, 12:13
Message(s) : 10
salut
la carte se branche toute seule ou faut il une M4 ?
remax
Message Publié : 05 Déc 2016, 18:58
Message(s) : 228
cyrillem a écrit :
salut
Mother X4 ou au moins un cable
cyrillem
Message Publié : 09 Déc 2016, 10:14
Message(s) : 10
ok
Merci Remax
Vous savez ou trouver des cables pas chers ?
Message Publié : 11 Déc 2016, 09:53
M4 firmware v1.1.0 beta 9
Changes:
- Stability fixes for netapi.
- Added RSX commands |GETPATH, |UDIR, |LONGNAME by SOS
- Added C_GETNETWORK command.
- Added status byte after response string to C_NETSTAT
- Fix |cd,"/" to go to root if inside a DSK image.
- Fix SD hotswapping.
- Remove KM_RESET from cat/dir when pressing ESC, to continue listing one must use space now.
- Display current path when using cat/dir.
- Increased AMSDOS readspeed (using bigger buffer).
- Faster network speed when using netapi.
- Keep CPC in reset until init. done. (Fixes issue with C4CPC and M4 at the same time).
- Many amsdos compatiblity fixes
- Fix multiple network connections.
- Implemented |LS command for long filenames (15 mode 0, 35 mode 1, 75 mode 2).
- |cd can use long names too.
- autoexec.bas method changed, should not longer give problems with certain basic games.
src/url: Download http://www.spinpoint.org/cpc/M4FIRM_v110b9.zip
cyrillem
Message Publié : 07 Jan 2017, 08:27
Message(s) : 10
bonjour
est-il possible d'installer un os genre futuros dans cette carte ou faut-il autre chose ?
merci
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 118 invité(s)
