Nous sommes actuellement le 09 Mars 2026, 19:00
FLYSPY
 Sujet du message : FLYSPY
Pause the game, type THIS IS TOO HARD and finally press a key between 1 and 7 to get at the cheats.
1 You can fly through walls.
2 Infinite fuel.
3 You can pick up any object.
4 Infinite laser shots.
5 Infinite lives.
6 Infinite shield.
7 Gives you the teleport code if you press Control with the T key.
0 Takes you back to the game.
 Sujet du message : Re: FLYSPY
Message Publié : 17 Sep 2009, 09:45
POKE(S) pour le jeu AMSTRAD CPC "FLYSPY"
POKE &AE3A,&18
POKE &AB2C,&18
Message Publié : 17 Sep 2009, 09:49
F. Dentith of Great Sutton has sent in some playing tips for Flyspy
1) Always pick up telekeys and push any levers you find.
2) Alter pushing all the levers in a section, search it thoroughly tor telecodes or new doorways
3) When playing centipede try to destroy as many mushrooms as possible during the first wave Dead sections turn into mushrooms and clutter the screen, making it difficult to shoot the second wave in the tine allocated
4) The first lever you find releases the code lor teleport station A. Write it. and all others you lind. down.
5) Collect the oxygen from B and teleport to A
6) You can now get the bomb that is underwater Use it and drop it where you lind it. then get clear.
7) This opens the compartment above. Push the lever <you shouldn't need the oxygen).
8) Always use bombs on barriers that cannot be destroyed by the laser (which Is released by the second lever).
9) The code lor C is now released.
10) Teleport to C The other telekey is above the water corridor over which is written "You won't like il down here." Push the lever and return to A through the water system Return to the water corridor {now two way). Go down it and pick up the bomb and telekey.
11) Teleport to C. Use bomb on the barrier and then continue Remember to search each section thoroughly lor levers, telecodes and new openings.
12) Alter pushing the lever at D return to C. D is the only place at which you don t log your position
13) At C go down the smallest
water comdor to the grey square (down lett ol the telestation) Fire at the wall to the right in three dillerent places, this gives access to the compartments on the other side ol the wall. Pick up both telekey and bomb.
14) At station E the controls are reversed Also the guns now renew strength instead of decreasing it
15) Pick up the N-bomb.
16) Be very careful at the huge one way water system. Always check there aren't any levers in any other directions before going through a "door"
17) If you return to a place for a second time re-check the landscape lor new telecodes.
18) You can get past the rest ol the game in the same way as the sections written about above
19) Only use the N-bomb at the piece of machinery labelled The Brain"
